Author Topic: Kapex laser alignment  (Read 3287 times)
Offline sariq14
« on: April 13, 2015, 06:29 PM »
One of the lasers on my new Kapex is slightly off the cut line.  Has anyone on here ever adjusted this?  Apparently it can be done.
Thanks.
Offline Birdhunter
Re: Kapex laser alignment
« Reply #1 on: April 13, 2015, 06:55 PM »
The supplemental manual describes the adjustment procedure. My lasers were off the cut line when I fired it up. The adjustment process worked.
Birdhunter
Offline Stevec717
« Reply #2 on: April 17, 2015, 03:21 PM »
Yes, very easy. Tiny Allen wrench was in the packaging with the saw.
You do need to punch through the decal for adjustment the first time.
Luckily I didn't have any skew or angle adjustments to make - just a slight side to side offset. I like the edge of the laser line to just touch the outside of the kerf on each side.
Steve
Offline fp1337
« Reply #3 on: April 21, 2015, 12:13 PM »
I don't know how you guys use the laser. Adjusted or not, the line itself is bigger than my own tolerance. I just lower the blade to the pencil line to check for alignment.
Offline ryanjg117
« Reply #4 on: February 14, 2021, 02:09 AM »
Question - is the Kapex laser intended to only provide correct alignment at the full-up blade position? I've noticed as I bring the blade down, the laser wanders off the cut line.
I've poked holes in the label and attempted to fine tune it, but probably just made things worse. I tried to follow the steps in the Supplemental Manual but that didn't really work for me.
Offline kevinculle
« Reply #5 on: February 14, 2021, 08:50 AM »
I went through the alignments in the Supplemental Manual on my 12 years old Kapex last year.  The five cut squaring was so close to perfect I didn't do any tweaking.  I did go through the laser alignment and was able to get the cut lines to align very well...the width of the laser lines does limit absolute accuracy here.  I haven't seen any shifting on my saw between the full up position where I typically register the cut line and the down sawing position.  For very critical cuts I will align a tooth with the cut line.
Offline Claimdude
« Reply #6 on: February 14, 2021, 10:19 AM »
I aligned my lasers after receiving my Kapex 5 or 6 months ago (snagged one of the new saws with upgraded insides from Hartville for a grand or there abouts) and have no issues with laser line moving.
Jack
Offline Don T
  • Phoenix, Az
« Reply #7 on: February 14, 2021, 07:35 PM »
I had the same issue when I tried to adjust mine. I just kept tweeting it until it worked correctly.
Online Gregor
« Reply #8 on: October 17, 2021, 09:13 AM »
As a late reply (as I found this while searching for something else):  Set the lasers so the lines are directly beside the kerf, without shining into it. Then the blade will cut everything between the laser lines, without cutting into the areas illuminated by the laser.
Then the cut will be exactly where you want it to be.
Online Gregor
« Reply #9 on: October 17, 2021, 09:16 AM »
Kapex Supplemental Manual, Page 28.
Following that you'll have laser lines that do not move when lowering the head.
Offline ChuckS
« Reply #10 on: October 17, 2021, 10:15 AM »
The laser lines are as good as my eyes, and that means in my shop they're great for rough cuts, initial cuts (such as trimming the ends of a rough stock or squaring an end, starting the dado cuts, etc.) and may be one-time precision cuts. For repetitive, precision cuts, the laser lines are not sharp/reliable enough no matter how they are set or fine-tuned, so I use a stop block(s).
Offline SRSemenza
« Reply #11 on: October 17, 2021, 10:46 AM »
    Exactly this ^^^ .   I too, set mine so the blade / kerf is exactly between and touching (just touching) the inside edge of the laser lines. Very precise and functional this way.
« Reply #12 on: October 18, 2021, 08:58 AM »
+1  Besides, the Kapex can use 2 hold downs at the same time so using a hard stop becomes super easy.   [cool]
Offline SRSemenza
« Reply #13 on: October 18, 2021, 10:20 AM »
Merged topics.
