Author Topic: How to use Copier Scanning Set  (Read 10639 times)
Offline newinwood
« on: April 02, 2013, 01:27 PM »
I am trying to find info if I can use Copier Scanning Set for 1400 router and some explanation- how to use it.
I am talking about this one - http://festoolusa.com/power-tool-accessories/routers/other-accessories/copier-scanning-set-486534
Thank you,
Ed.
I love what I do
Offline PaulMarcel
    • Voilà, my blog
Re: How to use Copier Scanning Set
« Reply #1 on: April 02, 2013, 03:25 PM »
It works just like a bearing on the end of a router bit except you use the bearing attached to the router via the arm instead of a bearing on the bit.
I don't use this set often, but it is really helpful when I need it.  Not a bad idea for a video
Online dicktill
« Reply #2 on: April 02, 2013, 04:01 PM »
See this thread too: http://festoolownersgroup.com/festool-tools-accessories/1400-accessories/
There is a Paul Marcel video in there. It makes reference to the book "Festool Essentials - The Routers" which is pretty good (at least for a beginner like me), which has good photos of the copier scanning set (and other accessories for all the Festool routers).
« Last Edit: April 07, 2016, 08:15 PM by dicktill »
Offline PaulMarcel
    • Voilà, my blog
« Reply #3 on: April 02, 2013, 04:25 PM »
Yeah, I saw that thread (thanks for the shout out!) I just mean one that shows how to use it specifically.  I don't remember doing that in that video...
Offline newinwood
« Reply #4 on: April 02, 2013, 09:12 PM »
AAA, I got it. I was thinking to use it for coping edge of wave-form band in the middle of the desk top. It would not help me.
Thank you guys !!
Ed.
I love what I do
Offline fdengel
« Reply #5 on: April 07, 2016, 01:02 PM »
For something like that you could try using a bit with a bearing on the end to make a template using a piece of material somehow clamped to the side of the desk top.
Then apply that pattern to the piece you want to copy to...
Just a thought.
See also the Angle Arm attachment (which for some reason is filed under "Template Guides Imperial" on the Festool USA web site, which doesn't seem right to me), which can be used in conjunction with the scanner set.
« Last Edit: April 07, 2016, 01:07 PM by fdengel »
Offline ear3
« Reply #6 on: April 07, 2016, 03:17 PM »
This is sort of a random revival.  But just to add to the record, here are some videos another FOG user alerted me to when I asked about the set:
Discussion of the above videos in this forum:
http://www.routerforums.com/portable-routing/17579-dai-rabbet-festool-style.html
Copier/scanner requires use of the the angle arm, BTW.
« Last Edit: April 07, 2016, 03:21 PM by Edward A Reno III »
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline PreferrablyWood
Copy Scanner set revisited
« Reply #7 on: January 01, 2017, 06:35 AM »
I'm looking at upgrading my OF 1010 with the accessories for edge triming and became interested in the Copy Scanner set. These thread just covers the most basic function of making rabbits and tongue and grooves. I think the Scanning ability for use of series production of parts to go into a latticework project could be interesting. But without any video documentation on this type of use I'd be hesitant to invest in the piece for 50 €..
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
