hi,
first post here.
i have used the surfix oil system a handful of times with decent results. however, i really dont feel confident i understand the process i am doing. i have a couple questions which i will list right here:
1) the instructions say to wait 15 minutes before buffing. should i buff after exactly 15 minutes regardless of what the work piece looks like? is the oil supposed to be wet, starting to dry, or totally dry when i buff?
2) how can i tell when the vlies pads are used up? are they still good to use if they are coated in wax? i'm attaching a photo of a pad after buffing 30 square feet of hard maple. is this pad trash?
3) what is the work piece supposed to look like immediately after buffing? how long do i buff the piece for? should it be wet, dry, sticky, something else?
4) is it okay to wait longer then 8 hours between coats or is that timing important?
thanks for any help,
solomon.
