Author Topic: How to stamp finished woodworking  (Read 1548 times)
Offline Intex
« on: July 02, 2019, 01:21 PM »
I just ordered a branding iron to imprint Logo onto finished projects, but also wanted to incorporate a date stamp.
Any ideas of how to accomplish this? Rubber ink stamp will eventually wear off. If I use a steel stamp that I hammer the die into the wood, I am not sure that it will show clearly??
Offline Bob D.
Re: How to stamp finished woodworking
« Reply #1 on: July 02, 2019, 02:28 PM »
Couldn't you just sign and date with a Sharpie or similar permanent marker next to your stamp.
Offline six-point socket II
  • aka @the_black_tie_diyer
« Reply #2 on: July 02, 2019, 02:31 PM »
You could use a branding iron with interchangeable characters.
-> https://brandingirons.com/collections/interchangeable-characters
Not affiliated with them.
Kind regards,
Oliver
Kind regards,
Oliver
Offline ear3
« Reply #3 on: July 03, 2019, 02:42 PM »
Because of the interplay of light and shadow, steel punch stamping generally shows up pretty clearly, especially once a finish is applied.
By coincidence, I just stamped the angle gauge blocks on my sharpening box, so you can take a look and see.  My set doesn't have numbers, so I had to go with roman numerals:
Offline Dogberryjr
« Reply #4 on: July 03, 2019, 03:21 PM »
Use the punches, rub generous amount of shoe polish into the dents, wipe off excess.
Offline tomp
« Reply #5 on: July 03, 2019, 03:34 PM »
Get your logo printed on veneer and inlay into the surface
Printing Logo on Veneer
Offline Bert Vanderveen
« Reply #6 on: July 03, 2019, 04:08 PM »
Date stamps can be applied with punches. But they are hard to place correctly (although that has its charms). You could use a pantograph system — they produce reliable results (even though they are from the realm of metalworking).
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950
Offline Bob D.
« Reply #7 on: July 03, 2019, 05:13 PM »
I like this idea, and I already have a set of stamps, so good to go.
Maybe finish with a coat of shellac or lacquer to seal it in.
Online Mario Turcot
« Reply #8 on: July 04, 2019, 07:37 PM »
L.V. provide a ruler with their punches
URL: Ruler
URL: Punches
Mario
Offline Intex
« Reply #9 on: July 06, 2019, 07:07 PM »
Thank you everyone for the great replies. If I went with the branding iron ones it would be a couple of hundred $.
I have decided to take Mario’s advice and order from LV
Thanks all !!
Offline Intex
« Reply #10 on: July 24, 2019, 10:45 AM »
Received the Branding iron from Infinity, and it works fine. I purchased the steel stamp set for the date, and after filling in the indentations made by the dies with black shoe polish (as recommended here) It is both legible and should last a lifetime.
Thanks to all!
