Author Topic: How to Dismantle Festool 36mm hose connector?  (Read 215 times)
Offline John Russell
« on: February 22, 2021, 11:21 AM »
After I remove the larger connecting piece on the hose, there is another plastic part that I can't sort out how to remove.  It is the part on the inside of the connector piece on the very end.  Does it screw off or do you just use brute force to pull it off, or what?  Thanks
Offline Alex
Re: How to Dismantle Festool 36mm hose connector?
« Reply #1 on: February 22, 2021, 11:26 AM »
You screw it off. Shouldn't be too hard.
Offline Ivan T
  • Tool Rich, Project Poor
« Reply #2 on: February 22, 2021, 11:44 AM »
I believe it is a left hand thread
« Reply #3 on: February 22, 2021, 11:46 AM »
Ah Yes, it is reverse threaded, comes off easy when turned the right way, thanks...
