This is an excellent video.I was actually about to write a post about this as came across the same aspect lately when thinking about getting the TSO self-aligning connectors. Eventually decided against them and will got for additional Makita ones.
The problem with both the Betterley and the TSO seolf-aligning tools is they rely on the rails to be straight at the ends AND both the connected rails to be the exact same width /lets ignore bends and think of new rails/.
But that is NOT the case, it is not even something Festool guarantees /or can technologically guarantee if wanted to.
I have 3 rails, and all of them have a slightly different width - from the reference edge to the outer edge.
The difference is only in the 0.05-0.15 mm (0.0002 to 0.0007 inch) but this gets applied over a 20cm (8") length I use for alignment!
That video you made is the ONLY way how to accurately align any rails in fact - put a straight edge against the reference surface, put pressure/clamp it, secure the rail connectors. Anything else will be less accurate, which may be good-enough though.
[/quote]
Thanks! Glad you found it helpful! It's a shame that festool hasn't come out with a more streamlined solution. I really don't like having to bring/buy additional tools just to make the ones that I have now work properly. That sucks about have your rails different widths. I've got another video coming out this week (not that it will help you in this regard), but buying the longest rail possible, then trimming it to manageable lengths would likely solve your issue, no? Dunno if you're that dedicated to getting identical rails
