Author Topic: How to Calibrate the Kapex Extensions  (Read 1215 times)
« on: September 22, 2020, 08:02 AM »
The Kapex extensions are such a game changer for my shop and I love owning a set. However, sometimes the calibration can be off - especially after transporting them. Here is a quick video on how to calibrate them:
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
Re: How to Calibrate the Kapex Extensions
« Reply #1 on: September 22, 2020, 10:00 PM »
Nice...
Festool Specialist at Woodcraft, Chattanooga, TN
Latest Festool purchase...TID18 T18 set....love them
Offline FestitaMakool
« Reply #2 on: September 23, 2020, 10:36 AM »
This is also explained in the manual provided with the extensions.
Loosen the 3 bolts under slightly, put a ruler which has an end that starts at zero and put the ruler against a tooth on the blade (head on saw dropped down and locked)
Adjust extension to match ruler - tighten bolts. Finished.
Offline Rogr
« Reply #3 on: October 12, 2020, 02:39 AM »
Anyone have to remove and replace the extension tapes? Curious if they just rip off and reapply or need to be replaced?
« Reply #4 on: October 13, 2020, 08:32 PM »
@jcrowe1950 thanks!!
« Reply #5 on: October 13, 2020, 08:33 PM »
I've not removed the tapes, and they seem like their glued down to the aluminum body - not sure how easy it is to take off and replace. You switching measuring units?
« Reply #6 on: October 13, 2020, 08:33 PM »
Yep! The process is pretty straightforward - clean and easy!
Offline Rogr
« Reply #7 on: December 02, 2020, 08:21 PM »
No, I just built my own crown stops with a short length of t-track between the saw base and extensions, so the tapes are both out by 3/4” now.
Offline hamsey
« Reply #8 on: December 11, 2020, 03:23 PM »
Thanks for this. Just had to go through this calibration after putting on a new blade. Your way is faster and easier.
« Reply #9 on: January 09, 2021, 09:06 AM »
@hamsey Nice! Glad it helped!!
