Author Topic: HK 55 EQ Repair  (Read 416 times)
Offline daveva
HK 55 EQ Repair
« on: April 20, 2021, 10:35 AM »
Can someone tell me how to remove the bolt from the housing on this saw ? Its the bolt that connects to the housing to the guide plate.
Offline ElectricFeet
Re: HK 55 EQ Repair
« Reply #1 on: May 04, 2021, 03:58 PM »
In the absence (so far) of anyone else with direct experience of dismantling this, may I suggest you take a look at the ekat entry for the saw? https://www.festool.co.uk/ekat  The exploded diagram generally shows you what you are dealing with quite well.
