Makita says this chuck is to be opened and closed by using the impact driver's (which it is designed for) forward and reverse settings and grabbing the chuck's sleeve. The way an impact driver works, this is pretty safe - do not try this with a regular drill/driver! An be careful not to make contact with the drill bit.
But if the shaft diameter of that drill bit is 10.06mm and it's a 10.00 mm chuck, this will prove interesting.
If you have a key for a standard jacobs chuck, chance is good the round part will fit in that little hole and allow you to counter the chuck while opening it. But any rod that fits the hole will do in the end, just be careful to not hurt yourself if it slips out ...
Kind regards,
Oliver
