Author Topic: Grit progression RO90 to ETS 125 EQ  (Read 739 times)
Offline Dogberryjr
« on: July 16, 2019, 07:54 PM »
I'm working on a black walnut table top with some minor but notable fluctuations between the three glued-up panels. If I start sanding with my RO90 and finish with my ETS 125, what do you all think my grit progression should look like?
Offline Birdhunter
Re: Grit progression RO90 to ETS 125 EQ
« Reply #1 on: July 16, 2019, 08:52 PM »
If you are trying to smooth out fluctuations, I would think the 90 would be inappropriate. I would think that small pad would create more problems than it would cure.
I’d stick with the 125 and go from 60 grit to 180 grit.
Birdhunter
Offline Dogberryjr
« Reply #2 on: July 16, 2019, 09:00 PM »
I thank you.
Offline ChiknNutz
« Reply #3 on: July 16, 2019, 11:08 PM »
I have the RO150 and ETS 125 with a 150 pad so I can stick with 6" discs the whole time.  For table tops I use the Rotex in direct drive from 40 or 60 grit depending on the top and go up to about 150.  I then switch to the ETS and go BACK one grit (to say 120) and then go up to 220.
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Offline Birdhunter
« Reply #4 on: July 17, 2019, 05:13 AM »
The OP said he only had the RO 90 and the 125. A 6” pad would obviously be the best choice.
Birdhunter
