Author Topic: festool stm 1800 horrible installation instructions  (Read 511 times)
Offline zapdafish
« on: January 07, 2021, 12:51 PM »
can someone tell me what order to use to attach this to the cart thanks
Offline Alex
Re: festool stm 1800 horrible installation instructions
« Reply #1 on: January 07, 2021, 01:58 PM »
A bolt?  [tongue]
Offline Alex
« Reply #2 on: January 07, 2021, 02:05 PM »
Ok, I get your question now.
The serrated ring is to lock the nut so it can't losen through vibration. So first the serrated ring on the nut, then the normal ring, then insert it into the bracket, and then screw it to the bottom of the leg of the STM.
Offline zapdafish
« Reply #3 on: January 07, 2021, 02:20 PM »
thanks! normally wouldnt mind trial and error but with the threadlocker didnt want to go that route
Offline neilc
« Reply #4 on: January 07, 2021, 08:34 PM »
That bolt is the stem into the leg.  There are other bolts for the wheels.  You do have to mount the brackets before installing the wheels.
The STM-1800 is a really useful accessory.  Use mine all the time and added a MFT style top with extra clips from FT parts to enable a very portable table with MFT clamping as well as use on larger pieces.
