Author Topic: Festool parrallel guides  (Read 1017 times)
Offline john molloy
« on: November 13, 2021, 08:11 AM »
What have people done to improve usingthe parrallel guide
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
Re: Festool parrallel guides
« Reply #1 on: November 13, 2021, 11:44 AM »
Read the instructions…
Watch the video - Several times.
 [wink]
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline heidtwd
« Reply #2 on: November 13, 2021, 11:44 AM »
I added a tabs made from an RC40 chain link to the stops to prevent the parallel guide from tipping.  There's a disc spring under the tab to hold it in place either extended or retracted.
Offline john molloy
« Reply #3 on: November 13, 2021, 08:00 PM »
Very good
Offline xedos
« Reply #4 on: November 14, 2021, 08:19 AM »
Got the TSO version.
Offline twistsol
  • A shop full of tools and no talent
    • The Sawdustzone
« Reply #5 on: November 14, 2021, 06:17 PM »
I used a red sharpie to make the alignment arrow much easier to see.
Offline Brewstermmc
« Reply #6 on: December 01, 2021, 10:13 AM »
Great idea! That issue always made me scratch my head. Now I’m balding.
