I use a CMT drilling template with a dedicated drill holder (but a plunge router with a 14mm bushing will work well).
I could not find this in the USA. I think I bought it from Amazon.DE (Germany), but the parts were shipped from Amazon (Spain).
You can easily clamp this to the work surface. Spacing is automatic. But this has to be done prior to assembly in most cases. The piece is about 30” long and will not fit inside many assembled cabinet boxes.
I also bought the CMT jig for dowel cabinet construction. Not as fast as Dominoes in narrow width, but might be just as fast on wider spans. It was my choice to go with dowels. Not better maybe, but a choice.
By and large, I have found CMT products to perform excellently. A good, simple piece. It is made from a sheet of 1/2” thick phenolic (reinforced with some sort of fabric).
Addendum: Re-reading, I think we are talking about a different type of hole pattern. Sorry for the confusion.
Since this type of construction is used more in Europe than in the USA, you might want to look at Amazon.de or Amazon.es. (Germany and Spain). These sites will work with your Amazon account. The German site will translate to English and is easy to use. Freight costs were not bad and shipping was quick. You might try Amazon.UK also. No translating required.
