Assuming you are boring with the 15mm setting, the center of the mortise will be 16mm (the bit swings so 15 on the edges, 16 in the middle).
The cut edge of the 45º miter of a 3/4" board is 1.06" (27mm). 5mm thick Dominos means you'll want the center of the Domino
at most 7.5mm from the inside edge of the joint. Remember that the height setting gauge is only accurate for the fence tipped down 90º. At 45º, the height gauge's "10mm" setting is really 13.5mm. That 3.5mm difference is regardless of the height setting (it has to do with where the hinge is located... 5mm in from the milled face). So you'd need a height setting of 4mm, which the fence doesn't do. You'll want a shim board taped to the fence face to compensate.
Sorry for all the crazy numbers
![Blink [blink]](https://www.festoolownersgroup.com/Smileys/default/blink.gif)
