Author Topic: Mfk 700 modification by half inch shy  (Read 9611 times)
Offline DynaGlide
Re: Mfk 700 modification by half inch shy
« Reply #30 on: May 10, 2021, 08:24 AM »
I keep thinking I need to get a 0 degree base and try this as well. Don't own any fancy tools to mill the base.
Instagram @matts.garage
Online Cheese
« Reply #31 on: May 10, 2021, 09:42 AM »
I finally received my 0º base from Woodcraft last week, it took about 7 weeks to show up. I'm of the mind-set to do both of the bases at the same time. Then you're done with the project and you don't have to remember any quirks or oddities that need to be incorporated for the second base. Finished... [big grin]
Offline DynaGlide
« Reply #32 on: May 10, 2021, 09:46 AM »
What situation do you envision needing extra bit length for the 1.5 degree base?
Offline X
« Reply #33 on: May 10, 2021, 02:33 PM »
I used a oscillating drum sander to cut mine.
331365-0
Offline neilc
« Reply #34 on: May 10, 2021, 02:37 PM »
Great idea, X!
Offline Rick Herrick
« Reply #35 on: May 10, 2021, 04:25 PM »
Thats really nice.  I never would have thought that type of tool would do it.  What type of sleeve did you use?
Offline X
« Reply #36 on: May 11, 2021, 10:08 AM »
Rick
I did it last year, I think I used a 120 grit and a 1” sleeve. If you use this method take you’re time it gets hot. Good luck.
« Reply #37 on: May 11, 2021, 01:12 PM »
Appreciate the info.  I can see where going slow is the best method.
Offline Oso Rojo
« Reply #38 on: May 17, 2021, 12:39 PM »
Is there any trick to getting the two pieces of the base apart? My adjustment knob stops but do I just keep twisting to get it to come apart?
Offline X
« Reply #39 on: May 17, 2021, 05:40 PM »
Unscrew the large black knob all the way and that should let spin off the top section.
Offline Oso Rojo
« Reply #40 on: May 17, 2021, 09:43 PM »
I will add one addition for anyone in the future coming along. There is a piston under the black knob that locks into a keyway on the shaft of the green knob. If you have the green knob all the way counter clockwise or up position, it will jam the piston into the keyway and removing the black knob seems to have no effect. At that point screw down the green knob, clockwise, so that it releases the piston from the keyway. You may even need to how the hole from the black knob down to let the piston drop down. It's captured in the shaft so don't worry about it coming out.
Separating the two parts is defiantly the way to go. From here I'll either use the jigsaw or scroll saw and finish it off with the drum sander and about a 1" drum.
I guess Paul never realized how to separate the two pieces.
How important is it to remove the "bat wings" left by lengthening the chamber?
« Reply #41 on: May 17, 2021, 11:40 PM »
@Oso Rojo Thanks for the info.  Can you give us a picture or two ?  Thanks.
Offline Bugsysiegals
« Reply #42 on: May 18, 2021, 09:00 AM »
I see you never removed the “wings” ... I suspect you’re not able, or are barely able, to flush trim 3/4” edge banding?
Offline Oso Rojo
« Reply #43 on: May 18, 2021, 10:41 AM »
I've been thinking about the wings issue in the overnight and I think they need to be removed. The theory being the cutting edge is at the same height as the wings so the cutter can't efficiently cut where the wings are present. It likely would cut some but would require multiple passes because the cutter is restricted in how much it can cut in one pass.
Offline tjskinny
« Reply #44 on: May 18, 2021, 08:07 PM »
I started on some cabinets with 3/4 inch thick edgeband and had to perform this mod.  I used a hacksaw to start so it essentially removed the wings and made the fret saw work go a bit easier.
It was a doh moment though as I thought I had the zero degree base but it was the 1.5 degree.  [blink] It really shows when you trim 3/4 inch edgeband, luckily it was a test piece I used it on.  [eek]  I ordered the zero degree and did the same mod, so had some practice,  [embarassed]
331611-0
331613-1
I didn’t remove the movable base, just opened it to the max position.
Offline Oso Rojo
« Reply #45 on: May 19, 2021, 09:45 AM »
The first image shows the shaft on the lower plate and the keyway in that shaft. Notice that the keyway is stopped before the end of the shaft. So if the key is in the keyway, that shaft will be stopped before it can be fully extracted. This will be perceived by the green knob no longer able to unscrew past a certain point.
The second image shows the top plate inverted and with a pipe cleaner stuck in the hole where the black knob goes to push the key up to the top for viewing. To remove the green knob, you need this key out of that keyway be removing the black knob and making sure the key has dropped out of the way and it not jammed in place by the green knob.
Does this make sense?
Removing the top plate makes the modification much easier. I cut the access for the bit last night using the spindle sander method with a 1/2" 80 grit sleeve and it was simple and easy.
« Reply #46 on: May 19, 2021, 11:28 AM »
Thanks for the pictures and info.
