Author Topic: Festool 36mm hose repair question  (Read 1424 times)
« on: October 28, 2018, 08:49 PM »
I shortened a 36mm hose and now I want to rejoin the ends. One hose has a rubber 36mm tool end on one end and the other has the vac connector. The other hose has a 36mm tool end on one end and just the raw spiral hose on the end I want to join.
This is a topic I don’t know much about so hopefully someone can clue me in to what the options are and what I need to buy.
Offline SRSemenza
Re: Festool 36mm hose repair question
« Reply #1 on: October 28, 2018, 08:58 PM »
I think the only way to do that without customizing is to put a vac end connector on both ends and use a D50 hose coupler. So basically it would just be an attachable extension hose.
Might be able to use the thread on portion of two tool end connectors and glue them / plastic weld them together.
Maybe the best option if you really want a single piece D36 is to sell the two pieces you have for Kapex hoses and buy the new style super flexible D36.
« Reply #2 on: October 28, 2018, 11:37 PM »
I like the last idea! Time for a new hose. Too bad that $100 card isn't here yet...
