Author Topic: Festool 1400 Depth Stop Movement  (Read 1872 times)
Offline mvish86
« on: April 15, 2019, 01:16 PM »
Hey folks, looked around and maybe I couldn't find the topic in search but was hoping for some advice.
I set the depth on my 1400 to be fantastically tiny, because I'm trying to erode a thin layer off my plywood so I can glue on some laminate (to create a slippery surface that is perfectly level with the rest of the plywood sheet: think half covered, half not). I've noticed after I set the depth, there's random low spots and high spots and as far as I can tell, all the screws are quite tight. Any advice folks can give me? I've never adjusted the turrets.
My conclusions: Plywood is plywood, not level -- Fair statement, but I should expect to see only subtle variations, not large (1/16 & 1/32 vs 1/64?) OR Something's up with my router and I'm not able to figure it out =(
Finally, I bought the infinity tools 1.5" planer/dado bit, but it's way too big for the existing dust cover - any aftermarket ideas? I'm using the world's smallest bit right now and it's taking forever.
Offline Birdhunter
Re: Festool 1400 Depth Stop Movement
« Reply #1 on: April 15, 2019, 03:23 PM »
Sounds like a job for a power planer.
Birdhunter
Offline harry_
« Reply #2 on: April 15, 2019, 06:55 PM »
maybe you should try it on a rail, a smoother surface to run on?
