Author Topic: Face Frame Attachment  (Read 542 times)
Offline Mike Goetzke
« on: May 23, 2020, 09:25 AM »
I'm a hobbyist but have built many cabinets over the years. I'm currently working on a bathroom corner vanity with storage cabinet.
I have brad nailed/glued, pocket screwed/glued, and just glued and all have been a success (ha- not failed). I have a Domino 700 but have never used it for this attachment. Always been worried about depth of cut into the frame and how to accommodate a face frame that is proud of the cabinet.
Do many use Dominos for FF attachment? If so share technique?
Offline scholar
Re: Face Frame Attachment
« Reply #1 on: May 23, 2020, 09:59 AM »
Hi I have a Domino, but don’t use it for face frame attachment. My preference is a continuous spline in 6mm birch ply.
Rather than repeat what’s been said elsewhere, here is a recent discussion on the subject
https://www.ukworkshop.co.uk/forums/post1346902.html#p1346902
Incidentally, I have used various methods of assembling the face frame itself - now I favour (small) dominos for alignment plus pocket screws  - the latter is possibly overkill, but it is a good way of cramping the frame up (you need to plan where your groove for the spline is going).
Cheers
« Reply #2 on: May 23, 2020, 10:29 AM »
You have to have all your sizes buttoned up very tight to be able to use Dominos on all four sides of a face frame. And or have developed the ability to micro adjust the Domino fence height.
Sometimes I use Dominos to match the top of a face frame to the top of a cabinet carcass but biscuits or splines work just as well.
I use pocket holes mostly.
« Last Edit: May 23, 2020, 10:35 AM by Michael Kellough »
Offline ear3
« Reply #3 on: May 23, 2020, 10:32 AM »
I don't do a lot of face frames, but when I do I use the domino.  Since for me it's primarily about alignment rather than strength, I just do two perpendicular sides of the frame rather than all 4, with the wider mortise setting, which relieves the worry about having to get the offsets correct on all 4 sides.  Here's a picture of the face frame I did for my hand tool cabinet, from this thread.  If there's concern about the strength of the undominoed sides of the frame, it's easy enough to add a few pocket screws at strategic points around the opposite corner.
Since the DF700 has a 15mm minimum depth, you should be good if you're working with a 3/4 frame.
« Last Edit: May 23, 2020, 10:34 AM by ear3 »
Offline fshanno
« Reply #4 on: May 25, 2020, 10:19 PM »
I usually have a face frame on wall my cabinets.  And I domino them.  And my face frames are proud of the case side.  And yes it's a pain because you have to adjust the fence or shim.
I use face frame hinges so the face frame needs to be well attached.
The good news is that once all the mortises are done assembly is a snap.  And it makes a nice job.
You're going to need to get the Seneca small mortise kit.
