Author Topic: DTSC 400 Abrasives  (Read 418 times)
Offline cjsmith80
DTSC 400 Abrasives
« on: July 26, 2019, 03:28 AM »
Morning FOG!
I’ve just bought the new cordless DTSC 400. I already had the ETS150/3 and use Abranet abrasives with it. Am I right in saying that Abranet abrasives won’t attach directly to the DTSC and that another pad is required to make them compatible? Or have I totally got this wrong?
Any help is very much appreciated.
Many thanks in advance,
Christian
Offline Alex
Re: DTSC 400 Abrasives
« Reply #1 on: July 26, 2019, 03:35 AM »
They attach directly just fine, but because of the mesh structure the expensive pad of the sander is exposed to wear. It is better to use a padsaver in between.
Or just use normal sandpaper. I don't get this mesh fad of lately, it is not better than normal paper, it is structurally weaker so everything will wear faster and cost you more money for the same result.
Offline cjsmith80
« Reply #2 on: July 26, 2019, 04:11 AM »
Thanks Alex!
Any particular ones you recommend?
Offline Alex
« Reply #3 on: July 26, 2019, 05:39 AM »
Never used one, but I think Festool only makes one type for the DTS400 anyway so that's the one you need.
https://festoolshop.ca/FES-203347
If you mean normal sandpaper, Granat is always a good choice, available as normal paper and as mesh.
