Author Topic: Drilling Domino holes at angle.  (Read 654 times)
Offline freddmc
« on: January 26, 2023, 07:34 PM »
I'm wondering if there is a good way to drill domino holes at an angle in an upright post.
Visualize and upright post with dominos inserted vertically. I'm making a clothes tree with legs that angle downward. I know now I should have drilled the holes before I cut the leg at an angle but I didn't. ;D
Offline ChuckS
Re: Drilling Domino holes at angle.
« Reply #1 on: January 26, 2023, 08:47 PM »
I think you did well by cutting the leg to the desired angle first. That'd be the way I do it, too.
Does this sketch describe your situation (invert the diagram since your leg points downward)? If so, mill the post at right angle, and mill the leg also at right angle to the endgrain:
If you provide a sketch or photo showing the dimensions of the post and leg and how the joint looks like (i.e. how the mortises are oriented), the mortising advice could be different.
« Last Edit: January 26, 2023, 09:01 PM by ChuckS »
Offline freddmc
« Reply #2 on: January 26, 2023, 08:59 PM »
I can see how that would work BUT I'm using 10mm dominos and they are wider than the stock(legs)
Offline ChuckS
« Reply #3 on: January 26, 2023, 09:03 PM »
Wider? Then make the mortises parallel to the post.
Offline freddmc
« Reply #4 on: January 26, 2023, 09:40 PM »
Oppps.Look like I had a brain fart. ;D ;D ;D
Fred.
