Author Topic: Domino Knock-Down Connectors & Miters, Help!  (Read 921 times)
Offline efc616
« on: November 07, 2019, 11:13 AM »
I'm hoping to use our domino machine (500) and the quick-connect/knock-down domino connectors for a project using King Board - a plastic board that "no adhesive known to man" will stick to.  We're building 6-sided honeycomb structures that will be mitered along the long edges at a 60-degree angle.  I think I can run the domino slot straight-into the miter, parallel to the face of the board, allowing me to use the drilling jig for the knock-down dominos? Has anyone ever tried this?  Thanks
Offline ChuckM
Re: Domino Knock-Down Connectors & Miters, Help!
« Reply #1 on: November 07, 2019, 01:45 PM »
The best way to work out /verify the DJ settings etc. and to field test your design is to cut some test joints using scraps of the same thickness of your plastic material.
Offline efc616
« Reply #2 on: November 07, 2019, 01:47 PM »
That's what I'm going to try this afternoon.  Just hoping to verify it works before purchasing the kit.  Thanks
Offline Dongar
« Reply #3 on: November 14, 2019, 08:50 AM »
There is a way to glue polyethylene that is used to repair boats. here is one video.
 Don
Offline JMcFly
« Reply #4 on: November 15, 2019, 12:39 PM »
yeah, no adhesive will work so you need to chemically weld them together / solvent weld
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
« Reply #5 on: November 16, 2019, 01:25 AM »
Your plan should work just fine. Make sure you don’t mortise so close to the edge that you cut through the outside edge.
Chris Wong, http://FlairWoodworks.com
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
