I've watched countless videos on how to use the Domino 500. I keep bumping up against the same issues. Let me explain:
I have some 1/2" stock that I am glueing up for a night stand table top. I'm using the Domino to align the boards. I am using the smallest domino in the systainer Domino Kit I purchased from a festool dealer. The smallest domino size is a 4X20mm. I'm using the 4mm cutter. It is my understanding is that the depth gauge selection for each side SHOULD add up to 20mm. So, on the one half of the board, I select the "12" which to me means that the domino will go in a depth equal to a little over half the length of the 20mm domino and the other half of the board I should select "8"(but of course there is no "8" so I use "12" again) (12 plus 8 equals 20mm but 12 PLUS 12 equals 24mm which means the domino should be too deep in each side). But it does not work out. The holes I bored are TOO SHALLOW (the boards will not slide together making contacts instead I have a large gap. So than I re-set the gauge to 20 and it still leaves me a gap, so I have to select the deepest setting. Finally I glue it up and put it in my parallel clamps and all is well. But can someone please explain what I am missing.
