As MikeGE said, mill one board with the narrow setting, and the mating board in wide setting EXCEPT the first mortise in narrow setting for alignment purposes. That means start with the narrow setting and only change it after cutting all the mortises on the first board and the first mortise on the mating board (remember that for the DF700, you switch off the machine before changing the width setting (for the DF500, it's the opposite)).
By "black guide," do you mean the cross stop?
It's an indispensable tool for me because it eliminates marking placement lines in larger work. However, no instructions come with the cross stop, and many people may find the mortises out of alignment in using it and give up as did this fellow:
https://youtu.be/m-6GTIMsEgM?t=240If you follow the proper procedures, all the "problems" he suggested don't exist. This is how I do it with my DF500 (print it out and try it on some scraps if you want):
The Domino Joiner does a lot more things than aligning boards. You may buy the third party adapter to use the DF700 with the smaller cutters like a DF500 too. Once you've mastered the cross stop, you can use it on joinery work (e,g, butt joint in casework, etc.).
Remember this: When using the cross stop, only use the tight setting (with the paddles/spring stops) for the two "alignment mortises," the rest in the wide setting.
