Author Topic: CS70 outfeed  (Read 701 times)
Offline Big Dave
CS70 outfeed
« on: November 05, 2022, 04:00 AM »
Does anyone know if the mw1000 extension table will fit to the back of the cs70 securely and act as an outfeed table?
Offline papa365
Re: CS70 outfeed
« Reply #1 on: November 05, 2022, 01:41 PM »
It connects. They are at the same height. But not securely. Maybe ok for 1 or 2 cuts. But will drop as it only relies on the plastic connector. The bottom part doesn’t touch the cs70, unlike mft/3.
Offline FestitaMakool
Re: CS70 outfeed
« Reply #2 on: November 05, 2022, 01:52 PM »
As pictured by papa365, it fits, but won’t lock as it relies on hooking onto the same profile itself is made of.
However, make a couple of home made brackets that lock the plastic connector down by utilising the one of the two t-tracks on the MW 1000 table. If these brackets are spaced to each corner it will also stabilise the MW 1000 from tilting - even on the MW 1000 itself.
I’m planning to do so, but haven’t gone doing it yet.
Offline Big Dave
Re: CS70 outfeed
« Reply #3 on: November 06, 2022, 02:59 AM »
Ok thankyou for the advice.
I’ve got to say I’m very tempted to go down this route and rig something up to make it secure.
