Seems like everything lately has been about filters and over-doing it. "Good" shopping is not noticeable. Done right, you would never have known those hinges were there, and never miss them.
We have gone way off topic, so I will bring it back with a couple of timely pics.
After all of the talk about this, I had a job come up today with two long (114") miters, on HPL particle board. I did them exactly as I described. Table saw at 45, leaving a flat on the edge of about 1/16", then routing against a straight edge.
This material was over 13/16 thick, so the bit that I have was not quite able to clear off the short-point. I had to get out a Bosch Colt with a tilt base and a flush-trim bit to finish it up. A bigger diameter bit wouldn't have fit in the OF1400 anyway.
I did the main cut with the OF1400, using the chip-collector cup and the 36mm hose, and it did a great job, nearly dust free. Then came the Colt, for the little ridge at the top and it threw stuff everywhere.
I took one of the actual piece too, but I must have moved? it's all fuzzy. I get one tomorrow.
