Author Topic: CMS sliding table and TS55R  (Read 2938 times)
Offline rod_carr
« on: August 30, 2018, 06:54 PM »
I wonder if anyone can help me - I have a problem with the sliding table when using my TS55R - probably my own lack of understanding, but I've been searching for a bit now.
Problem is this.
With the fence set exactly 90 degrees to the saw plate, the table is not running parallel to the saw. If i set the edge of the fence against the plate at the front of the saw, then slide the table forward so that the fence is at the back of the saw, there is a 1/2mm gap - it's almost impossible to get a square cut, regardless of fence adjustment.
Am I being a complete blockhead and missing something? Any help/pointers gratefully received.
Offline Svar
Re: CMS sliding table and TS55R
« Reply #1 on: August 30, 2018, 07:14 PM »
It appears the rail, on which the table slides, is not parallel to the saw blade. I don't know whether there are adjustments, but you could use shims to make it parallel.
Offline Peter Halle
  • Magnum - My new little boy
« Reply #2 on: August 30, 2018, 07:21 PM »
Hopefully a UK or other non-North American member can chime in here whereas these are not distributed here and most of our members are here.
Offline jobsworth
  • Festool Baby.....
« Reply #3 on: August 30, 2018, 10:31 PM »
Problem is this.
Could you post photos? It will make it easier.
Offline Bert Vanderveen
« Reply #4 on: August 31, 2018, 07:41 AM »
Are you using the sliding table accessory on a standalone CMS or on the MFT/3 add on? The latter needs two plastic thingamingies that slide into the side, before you attach the sliding table.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950
Offline Gregor
« Reply #5 on: August 31, 2018, 08:18 AM »
IIRC: When puttin the TS into the CMS plate you should tighten the two green knobs on the TS that are to make the TS slop-free on a FS rail - the rail on the CMS plate where the TS registers on could be a bit thinner than the one on the normal FS - so the saw might turn a litte out of alignment.
When pausing https://youtu.be/E83flEmkGBQ?t=194 at the linked time (3:14) you see the two green knobs I refer to (and unpausing you can see Frank ingoring them, most likely as of them already being set correctly for his plate).
In case that dosn't explain the issue: release the two screws holding the sliding rail to the CMS, then re-tighten them while pushing the rail down (hard) from above at the screw you're working on, start with the short (not overhanging) side of the rail. Then rail then registers correctly into the v-grove.
In case it isn't completely seated down into it... sidewards movement can occur.
« Last Edit: September 01, 2018, 04:26 AM by Gregor »
Offline jobsworth
  • Festool Baby.....
« Reply #6 on: August 31, 2018, 10:32 AM »
Thats very true Gregor. When I bought my TS 75 CMS module in the UK,I had a issue getting straight cuts. I even had the festool rep to look at it. We could figure it out. Then I had a chat with  @Phil Beckley and he told me to tighten up those knobs when mounting the saw to the CMS.
I couldnt find that info anywhere in the manuals or Utube.
 But it is necessary when installing the saw in the CMS as the CMS track (for lack of a better name) might be different then the guide rail.
« Last Edit: August 31, 2018, 10:41 AM by jobsworth »
Offline jobsworth
  • Festool Baby.....
« Reply #7 on: August 31, 2018, 10:39 AM »
Problem is this.
I just thought of something. I was having a issue with the CS 50 fence on my CMS. A good friend of mine ( a very good pro wooodworker) visited my shop and we talked about it. What we realised is when I adj the fence I didnt account for the toe in of the saw.
So that is something you might want to look at. I suggest using some feeler gauges to check to see if your fence is aligned to include the toe in.
Offline rod_carr
« Reply #8 on: August 31, 2018, 07:22 PM »
Many thanks to all, especially Gregor. The saw was set to run my guide rails, but I had not thought to check it was sitting tight in the TS55R CMS mount. Also, a good call on making sure the slide rail was down tight in the groove before tightening up.
I will try these in the shop on Monday and report back - hope you all have a great weekend.
Also a good shout on the toe-in, thanks Jobsworth.
regards, Rod.
Offline rod_carr
« Reply #9 on: September 20, 2018, 04:12 PM »
Many thanks all for the suggestions - problem solved by tightening the saw using the rail guide tensioners - turns out the 'rail' in the module is a good 1/2mm thinner than the rails on the guide.
Cutting spot on now.
Cheers all.
Offline Gregor
« Reply #10 on: September 22, 2018, 08:50 AM »
Thanks for the feedback, good to hear that it works now.
Have fun with the tool!
Offline jarbroen
« Reply #11 on: September 24, 2018, 11:48 AM »
Sounds like you almost need a 2nd saw. That would be a lot of fiddling every time you installed it into the module.
Glad to hear you got that working.
Offline Gregor
« Reply #12 on: September 24, 2018, 01:48 PM »
Takes 5 seconds to adjust it between rail and CMS plate (or the other way around), one just needs to remember doing it.
