Author Topic: CMS-GE with VB extension (how to mount an Inca Positioned)  (Read 2510 times)
Offline abates
« on: December 30, 2017, 10:32 AM »
Hi All, I know there is quite a bit of discussion on the CMS with an Incra positioner, but it appears that most are using the cms for an MFT or couple the CMS-GE to an MFT.  I am wondering how I can mount the positioner directly to the VB extension?  Pictures will be helpful. Thanks!
Abe
Offline abates
Re: CMS-GE with VB extension (how to mount an Inca Positioned)
« Reply #1 on: December 31, 2017, 09:04 AM »
Has no one out there put a Incra ls positioned on there CMS-Ge?
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: January 01, 2018, 04:59 PM »
have you tried the search function? I dont know much about what your asking but I tried the search function key word INCRA and I got a lot of info.
Offline macrutt
« Reply #3 on: January 01, 2018, 05:48 PM »
Abe,
Here is a link to the only one I’ve found.
https://www.fine-tools.com/incra-base-assembly.html
Take care, George
Offline abates
« Reply #4 on: January 01, 2018, 09:36 PM »
Hi George, I saw that post already.  Seems quite nice but the kit is not for sale and the picture don't give a clear indication as to how it mounts to the CMS.  Thanks for the input!  I will keep pondering till I figure something out.  The Incra will be great for both the ts-75 module and the router table, helping speed up change overs. Cheers,
Abe
Online Bohdan
« Reply #5 on: January 01, 2018, 09:58 PM »
I have my Incra fitted with short headless dogs that just drop into the holes on the MFT. I don't use Incra's Precision Plate as I made my own dogs that fit.
It can be removed when not needed and replaced in seconds.
The MFT is clamped to the CMS by a pair of threaded rods and nuts in the T slots.
Offline GarryMartin
« Reply #6 on: January 02, 2018, 04:07 PM »
It's not a CMS - it's a Precisio CS 70. It wouldn't work for the CMS.
If you really want the Incra LS on a CMS-GE, then you'll need to create something yourself. I'm not aware of anything available for purchase that would allow it. There is a base for use with the MFT that makes use of the 20mm holes, but nothing for the CMS-GE.
You could attach it to an extension table by drilling and bolting through the aluminium I guess?
Offline abates
« Reply #7 on: January 04, 2018, 09:01 PM »
Do you have pictures of how you bolted the CMS to you MFT?  I was trying to avoid that, but worse comes to worse I could mount the MFT to the CMS.  Cheers,
Abe
Offline abates
« Reply #8 on: January 04, 2018, 09:02 PM »
Thanks for the Clarification on that one Gary.  If I figure something out this weekend I will let you know. Cheers.
Online Bohdan
« Reply #9 on: January 05, 2018, 01:20 AM »
Abe
It's just two lengths of allthread and four nuts and washers on each. The allthread is set with a nut on each end and this is inserted into each of the T tracks on the side. A second nut is then spun from the centre of the allthread to clamp the allthread to each of the T tracks.
You choose whatever length of allthread suits your requirement, mine was 5/16" allthread about 5" long. Can't show a picture cause they are not currently connected.
