Author Topic: Cleaning the Kapex Blade Guard  (Read 1430 times)
Offline deepcreek
    • TimberFire Studio
« on: August 29, 2019, 08:22 PM »
Has anyone found a procedure to remove and clean the Kapex blade guard?
Mine has accumulated enough crud over the years that is obscuring the laser.
I'm not asking about the laser dust lens.  I remove and clean that periodically.
Thanks!
Joe
Joe Adams
TimberFire Studio
Houston, Texas
Offline Jiggy Joiner
Re: Cleaning the Kapex Blade Guard
« Reply #1 on: August 30, 2019, 03:23 AM »
Without dismantling, I’ve found the easiest way is with a bottle cleaning brush. The body of the brush can be bent to get right around the guard. I just remove the blade, and give it a brush out, and vacuum.
That’s how I clean all my mitre saws without stripping them.
Offline ChuckM
« Reply #2 on: August 30, 2019, 07:46 AM »
I have not tried it, but I wonder if compressed air would work. Has anyone done it with compressed air?
Offline deepcreek
    • TimberFire Studio
« Reply #3 on: August 30, 2019, 10:13 AM »
I tried snaking Q-tips through the slots yesterday with limited results.
I assume the guard is spring loaded so disassembly may be risky.
I'll try the bottle brush and compressed air.
Joe Adams
TimberFire Studio
Houston, Texas
Offline rst
« Reply #4 on: August 30, 2019, 10:45 AM »
Citrus based cleaners work well, remember the guard is polycarbonate and will scratch easily.
« Reply #5 on: August 30, 2019, 02:01 PM »
@deepcreek Yes you’re right, there is a spring.
The guard removal on the Kapex seems more tricky to me than other saws, just because of the way the return spring is mounted.
It is one of those tasks though, that gets easier the more you do it. The spring is the fiddly part.
