@ferrij I have never seen Festool branded slot cutters. Where did you get them?
I normally use Whiteside slot cutters and arbors. The one thing that you have to be careful about is the material you are cutting. Sheet goods and softer hardwoods are ok, but you need to be careful with harder wood or anything that might have knots in it. (Spruce, Pine, etc)
Cutting smoothly then hitting a hard knot can possibly slip the cutters. A single on the arbor is not that big of a deal, but two might bash the carbide into the steel backing of the other one.
This is potentially dangerous and may spoil the cut.
Not saying don't do it, just be aware of what's going on. If you can do this on a router-table with a fence, the bit is more surrounded, safer.
