Author Topic: Blade and Router bit cleaning  (Read 12320 times)
Offline TheTrooper
« on: June 14, 2015, 11:18 AM »
What does everyone else use?
RO90, RO150, DTS 400, LS 130, CXS, TS 55 EQ, CT 36AC, OF 1400,  Parallel Guides, Kapex Miter saw,  3 MFT Kapex tables, C18
Offline charley1968
Re: Blade and Router bit cleaning
« Reply #1 on: June 14, 2015, 11:22 AM »
CMT Formula 2050 blade and bit cleaner, for my part..
Just for today..
Offline neeleman
« Reply #2 on: June 14, 2015, 11:23 AM »
Boeshield Blade & Bitcleaner.
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Online Cheese
« Reply #3 on: June 14, 2015, 11:50 AM »
CMT 2050 in a Rockler tub.
223494-0
223496-1
Offline John Bates
« Reply #4 on: June 14, 2015, 11:51 AM »
CMT, quick, clean and bio degradeable.
Manufacturer's agent and importer, representing or importing, Flexifoam, Fastcap, Armor Tool Co, Cable Clamps, Bruns Tool holders, Rolgear screwdrivers, RevMark Markers, Occidental Leather and Martinez Hammers.
Offline Don T
  • Phoenix, Az
« Reply #5 on: June 14, 2015, 12:59 PM »
CMT like most everyone else.
Offline grbmds
« Reply #6 on: June 14, 2015, 02:33 PM »
Simple Green works well also and it is also biodegradable.
Randy
Offline gkaiseril
« Reply #7 on: June 14, 2015, 02:36 PM »
Not only must the blades and shanks be cleaned but also the bearings. The lubrication will also be removed and must be replaced. A dry blade lube on the cutting face might also be a good idea.
George Kaiser
TS 55 REQ, RO 90, RO 150, CT 26, PSB 420, MFT/3
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #8 on: June 14, 2015, 03:08 PM »
Another vote for simple green.  It can damage carbide if left to soak overnight, but a 15 minute soak always does the job for me.
BTW, my blade sharpener says that about half the blades he gets from hobbyists really only need a good cleaning.
Offline Sparktrician
« Reply #9 on: June 14, 2015, 06:45 PM »
CMT in a mud bucket lid for saw blades.
- Willy -
Online Cheese
« Reply #10 on: June 14, 2015, 06:53 PM »
That works for sure...and you don't have to find a place to store that big blue Rockler tub, because it is kind of clunky.
« Reply #11 on: June 14, 2015, 06:56 PM »
And I always have a spare mud bucket or two in the shop.
- Willy -
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #12 on: June 14, 2015, 07:06 PM »
I have been using the bucket lid for years. Best part is you can return the product to the bottle for later use. The blade is in CMT blade and bit cleaner.
Offline tjbnwi
« Reply #13 on: June 14, 2015, 07:49 PM »
What do you guys do with the cleaning fluid after it is all used up?
If it is used up there is nothing left.
Offline TheTrooper
« Reply #14 on: June 14, 2015, 09:07 PM »
I'll have to grab some of the CMT.  I just used Simple Green and it worked but took awhile
Offline TheTrooper
« Reply #15 on: June 14, 2015, 09:29 PM »
So,  you keep pouring the used cleaner back in the bottle?
Yes
Offline tjbnwi
« Reply #16 on: June 14, 2015, 10:11 PM »
Let me rephrase the question...So,  you keep pouring the used cleaner back in the bottle?
Yes I do. Use it until it is gone from wiping the cutters dry.
Offline tjbnwi
« Reply #17 on: June 14, 2015, 10:13 PM »
If you check Simple Greens website you will see they tell you not to use the green cleaner on saw blades. I've read it affects the brazing.
They make a blue or purple you can use on saw blades.
Offline live4ever
« Reply #18 on: June 15, 2015, 01:47 AM »
I use the purple Simple Green (I think it's called HD or something) on blades and router bits.  I keep reusing it until it starts taking too long.  Works great.
Online Cheese
« Reply #19 on: June 15, 2015, 03:11 AM »
I've used Simple Green in a pinch and it's fine, it just takes a bit longer. The CMT is just a 5-10 minute soak. This isn't a task that I want to prolong. Soak it, brush it, rinse it, get on to more enjoyable endeavors.
Offline Geoffrey
« Reply #20 on: June 15, 2015, 08:16 AM »
The Simple Green Extreme (I think it is labeled as Aircraft Cleaner) is supposed to be better for saw blades and router bits. Regular Simple Green can damage the carbide tips, but the Simple Green Extreme is safe to use. At least, that is what I have read.
Offline Charlie Mac
« Reply #21 on: June 15, 2015, 09:27 AM »
  Regarding the CMT, there isn't much for instructions but I'm averse to rinsing anything that rusts so I just wipe it down when I'm done. Adding to the list of things I don't know is how it effects the cutter bearings so I try to keep them out of the solution.
Offline mike_aa
« Reply #22 on: June 15, 2015, 09:39 AM »
Here's a much older thread on blade cleaning that references the Trend bit and blade cleaner.  Has anyone actually used it?
Thanks, Mike A.
Offline rst
« Reply #23 on: June 15, 2015, 11:08 AM »
I cut a lot of plastics and use conditioning belts and scuff balls to remove the residue, being careful to avoid the face of the teeth on my blades.
Offline CO_JCD
« Reply #24 on: June 15, 2015, 03:16 PM »
Yes, it works well (I have not used other brands so cannot directly compare) for both TS blades and router bits.
John
Offline jobsworth
  • Festool Baby.....
« Reply #25 on: June 19, 2015, 02:42 AM »
Trend Bit cleaner  and a tooth brush
« Last Edit: May 01, 2016, 03:08 AM by jobsworth »
Offline Dan Pattison
    • Dan Pattison
« Reply #26 on: April 30, 2016, 06:18 AM »
I just did a video on cleaning your blades and router bits and the process that I use.  I used to think that my blades needed to go out for sharpening when in fact they were just dirty.  It's amazing the difference in quality of cut after you clean a blade.  Hope you guys find it helpful.
Dan Pattison
danpattison.com
Offline jbasen
« Reply #27 on: April 30, 2016, 07:37 PM »
I also use CMT. I've used simple green in the past and had issues with it removing the red coating from Freud saw blades [crying]
Offline jobsworth
  • Festool Baby.....
« Reply #28 on: May 01, 2016, 03:09 AM »
Crud cutter works good to
Offline Twoodman66
« Reply #29 on: May 01, 2016, 08:22 AM »
plain ole oven cleaner /lemon scent
