Author Topic: Bent loft ladder using domino  (Read 610 times)
Offline Philr99
« on: August 01, 2022, 05:32 PM »
I want to make a bent loft ladder. The ladder itself is at 12 degrees and at the top I want to put vertical handrails. After a lot of reading I'm wondering if the domino would be the correct tool to join this angle.
Many thanks
Phil
Offline ChuckS
Re: Bent loft ladder using domino
« Reply #1 on: August 01, 2022, 06:10 PM »
If your question is about whether the DF can do angled joinery for a ladder, then the answer is yes:
« Last Edit: August 01, 2022, 06:26 PM by ChuckS »
Offline Crazyraceguy
« Reply #2 on: August 01, 2022, 07:26 PM »
Absolutely. It may take some creative fixturing to position it properly, but it is very possible.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline ear3
« Reply #3 on: August 06, 2022, 07:14 AM »
@Philr99 I posted about a domino jig for doing a ladder a few years ago if you're curious: https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/domino-ladder-jig
Many thanks
Phil
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
