I’m just getting started with the LR32 system. On in balanced panel or even balanced, base distance off top of panel ever time. On my first panel, it was 639.5mm verses 640. That 1/2 mm put my holes off 1mm total. Then when shelf is put in, you are off 2mm because it adds from and rear. Shelf will rest on front left and rear right. The you have 2mm diiference on other two.
I did use the rapid clamps, which pull the panel. They are quick but one one side you pull to the top and when you spin the rail, you are pulling the opposite way. This compounds error.
Not to say the system is flawed, your panels need to be exact or at least base all dimensions off the same direction. Once all this gets worked out, it is a great and very quick system. I’m still trying to get doors with revels to line up. My doors are 4mm shorter than the cabinet to have upper and lower revels but my 35mm hinge holes didn’t line up.
