Author Topic: attaching breadboards  (Read 3510 times)
Offline clydeb
« on: May 03, 2017, 09:18 AM »
Questions for the experts, I'm building a large conference table  4 ft wide in middle and two sections of 7ft,  total length 14 feet. Tapering to 40 inches on each end (Boat style)  Made from inch and half cherry.  The customers (law firm) asked if I would wrap the whole table in contrasting hard maple about 3/4 inch thick.  Question is how to attach the maple on the ends.  I though about using my domino cutter but thought about the whole wood movement senerio. With maple only 3/4 of an inch thick I dont think a tenon arrangement would work.  Maybe oversize pocket holes for pocket screws???? Any help would be appreciated  Thank You
Offline justaguy
Re: attaching breadboards
« Reply #1 on: May 03, 2017, 12:16 PM »
I have not tried it but there is this on YouTube
Offline RL
« Reply #2 on: May 03, 2017, 12:24 PM »
I would use a 3/4" bearing guided rabbeting bit to route a tiny rebate and veneer it. Then use veneer to do the edge as well. You wouldn't have any wood movement problems but it would look like a 3/4" solid piece of maple.
Offline clydeb
« Reply #3 on: May 03, 2017, 08:24 PM »
Could you expound some on your idea please. Thanks
Offline richk
« Reply #4 on: May 03, 2017, 09:21 PM »
I used the @justaguy method above for a dining room table, about 38" wide, and which has shown some movement without developing any cracks or problems. It's been about 3 years and so far so good. Located in San Diego so no extremes of weather, but previously without breadboard ends it was a problem...
Offline Terry Fogarty
« Reply #5 on: May 03, 2017, 09:48 PM »
I've done countless breadboard table tops and always use the widest setting into all the top and middle end board and make my own tenons using the same species timber, then manually move the domino to achieve the wider mortises on the rest of the breadboard end.
I also glue the middle third of the breadboard to the table as minimal contraction/expansion will occur.
The one thing he didn't show was to give the end of the table and length of the breadboard a slight arris because their will be natural movement and if it's flush then a glueline will occur and it looks and feels terrible.
Offline Dovetail65
« Reply #6 on: May 03, 2017, 10:06 PM »
Are we talking only a 3/4" wide border? Maybe I got it wrong. I dont really consider 3/4" a bread board, is it? It's more like a border.
IMHO if its truly only a 3/4" border of contrasting wood around the edge I would just glue it up that way from the start(1.5"x3/4" thick Maple glued to the 1.5" cherry), not attach it like a breadboard at all.
Now a 4" breadboard, that's a different animal.
« Last Edit: May 03, 2017, 10:12 PM by Dovetail65 »
Offline Untidy Shop
« Reply #7 on: May 03, 2017, 11:22 PM »
These two links may assist -
The @thebicyclecafe  and my adaption of his method. He uses hand made dominos and a router, I used a D500 and Festool dominos.
thebicyclecafe -
http://festoolownersgroup.com/festool-how-to/loose-tenon-breadboard-ends-demonstration/
Reply #1
Untidy Shop -
http://festoolownersgroup.com/member-projects/my-magnificent-failure-(and-recovery)/msg281207/#msg281207
Reply #2
This is essentially the same method on the UTube video posted here by @justaguy .
Also note @Tezzer 's Reply #6 in this Thread.
_______________
If you are trimming and breadboarding, have a look at -
https://m.youtube.com/watch?feature=youtu.be&v=wVBEJF15Uxc
« Last Edit: May 03, 2017, 11:44 PM by Untidy Shop »
