Author Topic: Attaching an OF 1400 router to a Kreg router table?  (Read 21738 times)
Offline Wax
« on: February 06, 2010, 01:06 PM »
Hello all. This is my first post on here, so please be nice to me [smile]
I am fairly new to Festool, but its a love-affair thats going to last, me thinks.
I have just purchased an OF 1400 EQ router, but it only seems to have two screw holes in the base that i can see to screw into the Kreg router table i have just had delivered. I realise i have to drill holes to connect the router to the table insert, but i don't feel that two little screws is going to be enough support. I noticed that the Festool router table set-up has some clamps that hold the router in place, but alas this was not within my budget.
Do i have to buy some kind of adapter base? Any help would be greatly appreciated.
Wax
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
Re: Attaching an OF 1400 router to a Kreg router table?
« Reply #1 on: February 06, 2010, 01:26 PM »
Welcome to the FOG!
I'm not aware of any type of adapter. I'd try removing the phenolic base and using its screw holes. The two mounting holes in the base of the 1400 are M5 (I believe). Or you could try the two M5s and make some sort of clips of your own.
« Reply #2 on: February 06, 2010, 02:35 PM »
Consider the Veritas router table.
The router is attached by the clamps so you don't have to drill holes or remove the plastic base etc. Sounds interesting but I don't have experience with it.
Offline Wax
« Reply #3 on: February 06, 2010, 02:53 PM »
maybe a few of those Kreg clamps and a few bits of their track might work?
« Reply #4 on: February 06, 2010, 02:55 PM »
Thanks for posting, I remember see this thing somewhere but I forgot all about it. Could be the solution but at nearly $200 USD is gonna cost ya.
Offline Daviddubya
  • Arizona, USA
« Reply #5 on: February 06, 2010, 04:04 PM »
Wax - If you have to spend some money to mount a router in the Kreg table, my advice would be to spend the money on a router that will live in the table, and keep your OF1400 for hand-held use.  I bet you would soon grow tired of removing the OF1400 from the table every time you have a need for hand-held use.
David W. Falkenstein
in Cave Creek, AZ, USA
Offline Wax
« Reply #6 on: February 06, 2010, 04:41 PM »
I have a Dewalt 1/4 inch router. Would that me 'man' enough for a router table?
« Reply #7 on: February 06, 2010, 04:56 PM »
I really like Dave's advice. Not know which model router you have I couldn't say with and certainty but your DeWalt isn't likely to be an ideal router for table work. I prefer a 2 1/4 hp or larger router for a table.
Offline Wax
« Reply #8 on: February 06, 2010, 05:00 PM »
I could always ebay the dewalt 1/4 inch and buy another 1/2" router. Are there any that you can adjust, height wise, from the top of the router table, with some form of screw?
Offline Steve-CO
« Reply #9 on: February 06, 2010, 05:06 PM »
If you want to avoid adding a lift, something like this model would work, Porter Cable Router,  or you could add a Router Raizer to almost any plunge router.
« Last Edit: February 06, 2010, 06:49 PM by Steve-CO »
« Reply #10 on: February 06, 2010, 06:01 PM »
The price includes this little bit, (as well as the clamps)
"Each Veritas? router table top is a 16" x 24" steel plate that has been hand tuned to have a slight upward curve. This curve is specifically set so that the weight of the router cannot deform the router table to concave. Whatever the weight of your router, the Veritas router table top will always be slightly convex, with the highest point adjacent to the bit, so your depth of cut will always be exactly as set. Because the plate is steel, it will not sag over time, as many laminate tables will. "
Offline RonMiller
« Reply #11 on: February 06, 2010, 10:49 PM »
I use the Triton on the Veritas table and it is an excellent combination. I leave the Triton under there and raise/lower it from above the table as noted. If I can answer any specific questions, I'd be glad to help. But for me this combo has worked very well.
Ron
Offline Daviddubya
  • Arizona, USA
« Reply #12 on: February 07, 2010, 12:25 AM »
Wax - You mentioned you have purchased a Kreg router table.  Which one?  Are you committed to the Kreg table, or can you return it and make another choice?  I would make the table and router decision together, if that option is still available to you.
There are lots of good choices for a router and table combo, but a 1/4" router is not among them.  As a general guideline, I would suggest a minimum of 2 or more HP with both a 1/4" and a 1/2" collet for a table router.  A through-the-top height adjustment option will save you the significant cost of a lift.  The Freud FT3000VCE is a candidate, and would likely work with your Kreg table.
I would keep the 1/4" router you have if you can for light hand-held work, like edge trimming.
Many people, including me, evolve through multiple generations of router table and router combinations.  The router table in my home shop is now the second most expensive tool I own, next to a cabinet-style table saw.  Personally, I like the Woodpecker router table products and accessories.  A great shop project is building your own router table, at least a cabinet and top.
There are about a bazillion threads on this subject in general woodworking forums such as Sawmill Creek.  Give us a few of your own guidelines, and I'm sure folks here can help with your decision.  The amount of money you are willing to spend will weigh heavily in the solution.
« Last Edit: February 07, 2010, 12:30 AM by Daviddubya »
Offline Wax
« Reply #13 on: February 07, 2010, 06:13 AM »
I just sold a load of sound recording equipment that was gathering dust and blew the lot of Festool gear. Oh the price of being a tool junkie! I am slowly coming to the conclusion that a need another router to stay permanatly under the table. From the advice given so far, the Titan seems great. Are there any other options, at that kind of budget?
Offline Forrest Anderson
« Reply #14 on: February 07, 2010, 08:18 AM »
Before you rush out and buy a Titan router from Screwfix in the UK...
...the router the members here are talking about comes from Triton and will either be the large TRA001, TRB001 or TRC001 machine  (often referred to in the USA as the 3 1/4 HP model)...
...or the smaller MOF001 model (often referred to in the USA as the 2 1/4 HP model):
Both Triton routers are well-regarded for fitting in a router table.
For good illustrated reviews of the larger Triton router, see...
http://www.raygirling.com/triton.htm
http://nhwoodworker.com/triton/index.html
http://nhwoodworker.com/triton/update.html
...and for the smaller MOF001, see:
http://www.raygirling.com/triton14.htm
http://nhwoodworker.com/triton2/index.html
Forrest
« Last Edit: February 07, 2010, 08:31 AM by Forrest Anderson »
Compiler of the Consolidated List of Festool Links - the place to go for Festool reviews, manuals, brochures and videos!
Offline Wax
« Reply #15 on: February 07, 2010, 04:08 PM »
That was a 'typo' as the Americans say.  The Triton is an ugly brute though, but sounds ideal for my needs.  [tongue] Thanks for all your help chaps. Nice work.
Offline bill-e
  • Rindge, New Hampshire, USA
    • New Hampshire Woodworker
« Reply #16 on: February 08, 2010, 12:42 PM »
By the way the new TRC-001 (3.25hp) model now has the above table winder.  I havent seen it yet and apparently they cant keep them on the shelves.  The next manufacturing run is due here in April so that's the soonest I'll get my hands on one.  I'm hoping they improved the handle winder to that of the MOF001 too.
« Reply #17 on: February 08, 2010, 01:39 PM »
Bill, isn't this what you reviewed years ago?
Triton TRC-001
3.25hp Plunge Router
a review by
Bill Esposito
17 Jan 2004
Or, do they make changes and keep the model designation and just call it new?
Offline bill-e
« Reply #18 on: February 08, 2010, 03:39 PM »
Michael,
There is an updated version which was recently (last few months) released and is difficult to come by right now.
The one totally new is the above table winder (crank).
I've recently established contact with the HTC US distributors as things have changed since their buy out.
As for the part number. I think they call the US version TRC though the original one I reviewed was TRA....I always assumed that the "A" was for Australian and that the early models just had cut and paste Australian manuals and hence the part number confusion.
Offline Wax
« Reply #19 on: February 08, 2010, 04:39 PM »
I am a bit confused now: Is it only the TRC model that has the winder handle for adjustments above the router table, or do the others too. Also does anyone in the UK stock them, and more importantly in the Midlands area? Any clarification would be great. I don't want a third router thats not upto the job in hand too!
Offline bill-e
« Reply #20 on: February 08, 2010, 04:46 PM »
There are plenty of Triton dealers in the UK   http://www.tritontools.com/find-a-dealer/
The 2.25hp MOF-001 has an above table winder
The brand new 3.25hp TRC-001 has an above table winder.  Old stock will not have this so if you want the larger model you should either pick it up locally or ask to make sure it's the new updated version.
Offline Wax
« Reply #21 on: February 09, 2010, 04:21 AM »
Thanks Bill-e. It might be worth holding out for the more powerful model, as the price difference is quite small. If anyone knows anyone stocking the new one in the UK, please let me know.  [big grin]
Offline hs
« Reply #22 on: February 17, 2010, 05:42 AM »
I have the kreg precisio table with a Freud ft3000 router, you can adjust it from above,
works really well.
ps if you get it, mount the router on an angle so that you can adjust the height even when the fence is close to the bit.
