« on: September 30, 2022, 03:06 PM »
I just ordered a couple of sets of the Sys-AZ drawer systems. I've used them before but mounted the rails in a fixed position instead of using 32 mm shelf pin holes. I'm building a new rolling cabinet for my Dash-Board and I think this time I want to build in the flexibility in case I need to change my systainer heights. The instructions say to install the first row of holes 58 mm from the front. However, and I don't have an LR 32 system, I can't find a shelf pin jig that has a 58 mm setback. This jigs I have been able to find all use a 37 mm setback. What would be a good way to accomplish this task? I suppose I could draw a pencil line at 58 mm and set a jig over it and clamp it. Not perfect but I suppose it would work.
« Last Edit: September 30, 2022, 03:20 PM by HowardH »
Howard H
Mark Twain: "I didn't attend the funeral, but I sent a letter approving of it." "If you tell the truth you don't have to remember anything."
P1cc, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1400 holey, 1900 rails, OF1400, OF1010, CSX, C18, LR32, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, PM 1500, Jet J/P, FS-WA, Shaper Origin. Felder AF-14, TSC 55 KEB, Dash-Board bench system
