You don't want any moist though the machine, it will trap and build up.
But maybe this is helpful, since I don't epoxy polish that often I wrote myself a simple step guide to remind me;
- Put on green pad
- Spray with water, sand with Platin pads from necessary 500, 1000, 2000 Rotex mode (first grid takes longer then the finer after)
- Paper rag, clean off
- Check if scratches are off, otherwise rougher grit
- Wool pad, apply orange polish, cover polish on surface with pad
- Spray a bit water on surface, slow down at first between speed 2-3 in Rotex mode
- Same cross motion, first horizontal then over vertical. Bump up the speed
- Spray some water, wipe off with microfibre cloth
- Go to finer polishes and combined pads, polish is always in Rotex mode
