Author Topic: ATF 55E - How does the flange and counter flange come off?  (Read 1902 times)
Offline Richtes
Have an old beaten up saw that I want to check out. Most of it seems straightforward. Does the part 36 counter flange unscrew or is it pressed on with the #37 flange?
Thanks,
Rich
Offline SRSemenza
Re: ATF 55E - How does the flange and counter flange come off?
« Reply #1 on: July 29, 2013, 11:30 PM »
Happy first post  [smile]
I used have an ATF. If I recall the #35 screw holds the #36 flange on. The #36 flange does not screw on, just fits on and presses against the blade.
I take it is stuck in place and you want to know before prying it?
Offline Richtes
« Reply #2 on: July 30, 2013, 08:13 AM »
Seth,
Thanks. Was eying it with a small bearing puller but wanted to be safe.
Rich
