Author Topic: Angled plunge with a domino d500  (Read 493 times)
Offline LiranB
« on: May 05, 2022, 12:04 PM »
Hi guys,
I have a table to finish with angled legs and aprons.
I'd like to connect the table top to the base with z clips to mortises created with my d500.
Should I be fine with plunging when the face of the domino machine isn't entirely flush with the stock?
Angle is about 10 degrees.
In the drawing attached:
Brown- table top
Black - leg and z clip
Red - desired mortise
Offline ChuckS
Re: Angled plunge with a domino d500
« Reply #1 on: May 05, 2022, 12:23 PM »
Shouldn't you be mounting the clips to the aprons rather than the legs?
If you really want to mortise the legs, can't you set the machine's fence to the matching angle and plunge?
Offline Crazyraceguy
« Reply #2 on: May 05, 2022, 07:19 PM »
There is no problem with plunging into a surface that is not parallel to the face of the unit, as long as "something" else has a good register. That could be the fence or the base plate, either is good.
Just be aware/cautious as you begin the plunge, so it doesn't jump when hitting the angled surface.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline waho6o9
    • Garage Door Handyman.com
« Reply #3 on: May 05, 2022, 08:41 PM »
"Should I be fine with plunging when the face of the domino machine isn't entirely flush with the stock?"
Off hand I'd say no.
Make a jig and get a solid registration. Many ways to get to your 10 degree jig, simple is my preferred method
