Author Topic: am I using my VAC SYS incorrectly?  (Read 1068 times)
Offline online421
« on: July 30, 2019, 10:24 PM »
I bought my my VAC SYS over 6 months ago and finally took it out of the sealed box start using it with the OF2200.
Due to the work piece size I have to change the suction head to a smaller one.
When I place the OF2200 on top of the work piece, and push the router around the template, the work piece will start to tilt - it is still clamped onto VAC SYS, just the weight of the router causing the clamping head/suction cap to tilt.
am I using the VAC SYS properly?
PS. The F clamps to clamp the work piece to the template has been taken off when I took the pic
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55300
SCM 5 RCS1100
Casadei FV110
Comatic DC40
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, LEX3, OF1010, OF2200 CT36
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
Offline neilc
Re: am I using my VAC SYS incorrectly?
« Reply #1 on: July 30, 2019, 10:29 PM »
That piece is large enough to work with the round head it looks like.
I would not use that head on the Vac Sys with that large a piece when trying to route with the 2200 router.  You will get movement.
It looks like you are vacuuming to the table as well.  I assume you are not seeing any leakage from scratches or other imperfections on the top that might leak air?
« Reply #2 on: July 30, 2019, 10:39 PM »
Like Neil said, I’d definitely use a larger vacuum chuck. In this case...size does matter.  [smile]
Offline online421
« Reply #3 on: July 31, 2019, 06:09 PM »
Thanks Neil. the work piece is just slightly over the round head... I will make adjustment and use the Round head.
The table is relatively "flat", however it is not perfectly flat - it leaks air. I had to find a sweet spot for it, the bit that wont leak air happens to be at the corner which is a plus.
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55300
SCM 5 RCS1100
Casadei FV110
Comatic DC40
Ceccato CDX 12
Holytek DC006
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
Online DynaGlide
« Reply #4 on: July 31, 2019, 07:41 PM »
Turn off the suction on the base and use some clamps to secure it to the table. It should make a big difference.
Instagram @matts.garage
Offline online421
« Reply #5 on: July 31, 2019, 09:51 PM »
should have read my manual.
with the suction cap I have installed in the pic above, it can only hold 30kg when work piece is horizontal to the ground.
doesnt take a lot to move 30kg...
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55300
SCM 5 RCS1100
Casadei FV110
Comatic DC40
Ceccato CDX 12
Holytek DC006
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
