Author Topic: 36 to 27 adapter  (Read 1418 times)
Offline JG
36 to 27 adapter
« on: November 02, 2019, 08:07 AM »
Hey Foggers.  I need some help with an adapter issue.  I have a 36 AC which I use with a planex.  I also have a DTS 400 delta sander which I want to use with the 36 to sand the corners of drywall.  The 36 AC has a special hose to work with the planex. I called festool to locate the correct part no for any adapters so I could use this hose with my track saw as well as the delta sander.  The track saw can accept the 36mm connector on the outside and the 27mm on the inside.  The delta sander can only accept the 27mm on the outside.
According to festool, the special plnex hose (which has the nubs on the exterior to connect to the planex is a 36mm hose so it will fit on the outside of the track saw.  They also advised me that there is no adapter to allow you to connect a 36mm hose to a 27mm tool.  In essence, you have to buy a separate 27mm hose. That did not make any sense to me.
Is anyone aware of any adapter which allows to conect a 27mm tool to 36mm hose?
I have seem some videos which people force the 27mm end into the 36mm hose as the 36 mm is rubber.  I expect that would eventually wear out the 36mm end.  Thanks!
Offline Alex
Re: 36 to 27 adapter
« Reply #1 on: November 02, 2019, 08:59 AM »
This is what exists and what you need:
https://www.festool.com/accessory/768135---dc-d-3627-as
But I believe Festool is too lazy to sell it in America.
It is a generic Nilfisk-Alto part though, which you can also buy from 3rd party vendors:
http://www.industrialvacs.com/Tool_Socket_connects_suction_hose_to_power_tool_p/h302000535.htm
Offline JG
« Reply #2 on: November 03, 2019, 10:12 AM »
Thanks.  I will see if I can get the part here in the US.
Offline RNEMTP
« Reply #4 on: November 21, 2019, 02:07 AM »
I use a spare cleantec adapter that came with my df500 domino. It's a snug fit but it fits inside the 36mm planex hose and connects to all the smaller Festool tools. It is just the tool end of a 27 mm hose.
