Author Topic: 3 MFT joined together  (Read 491 times)
Offline RHC
« on: January 23, 2023, 05:09 PM »
I am setting up 3 tables to make a work bench. The center table is out of line by at least 1/16th of an inch via the dogholes. Any solutions?
Re: 3 MFT joined together
« Reply #1 on: January 23, 2023, 05:57 PM »
The MDF tops are held in place by screws from underneath. First I’d try removing the middle top and turning it around. If that doesn’t work loosen all the tops and try to align.
In the worst case you would have to trim a little off one side of the middle top.
Offline RHC
« Reply #2 on: January 23, 2023, 07:19 PM »
I appreciate the response. I may flip the whole table around and see if that helps. Was a little suprised to see it out that much. Over the whole span of 3 tables it out 1/8 inch.  [eek]
