Author Topic: 20 huge garden benches made with the DF500  (Read 1633 times)
Offline ChuckS
« on: May 14, 2022, 12:46 PM »
The cross stop (a must in my opinion for repetitive work/multiple pieces) is indispensable for his project, and at 10:20, he cleverly used a shop-made guide to position the machine. 2 placement lines instead of 80.
Double/twin tenons are the key to super strong joints if you don't have the DF700.
« Last Edit: May 14, 2022, 04:36 PM by ChuckS »
Offline Crazyraceguy
Re: 20 huge garden benches made with the DF500
« Reply #1 on: May 14, 2022, 07:34 PM »
Twenty at a time of something like that is definitely worth putting some time/effort/thought into jigs and fixturing. That's a good looking bench, I wonder what they sell for?
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline ChuckS
« Reply #2 on: May 14, 2022, 08:24 PM »
I save almost all my Domino jigs.
I started with 2 of these ladder shelves using a jig. In the end, about two dozen (different wood and sizes, and number of steps) have been made over time, some for family and some for friends, and some even made by others using my jig. Like the garden bench jig, placement lines are scribed on the jig, saving so many pencil lines to be marked on the rails. Because of the consistency offered by the jig, all mortises were cut with the tight setting.
« Last Edit: May 14, 2022, 08:28 PM by ChuckS »
Offline JINRO
« Reply #3 on: May 14, 2022, 09:32 PM »
Looking great! :) I'm so glad I have DF500 ready to serve me whenever I have time, plan, and skill.... :p
« Reply #4 on: May 15, 2022, 08:28 AM »
I save mine too, some are effectively permanent. Others, I save for a while and when the stack gets too big, I go through them and throw out the ones least likely to get used again. I have learned, over the years, to clearly mark what they were for, what bit and template guide was used, etc.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline ChuckS
« Reply #5 on: May 15, 2022, 11:25 AM »
Snip. I have learned, over the years, to clearly mark what they were for, what bit and template guide was used, etc.
For furniture makers/woodturners, equally important, if not more, is to date and sign every major piece of your work.
« Last Edit: May 15, 2022, 11:37 AM by ChuckS »
« Reply #6 on: May 15, 2022, 02:28 PM »
Oh, yeah. I have been doing that for many years. Everything I build gets the job number, which is assigned when the job comes in. That is only a partial clue though, because some big jobs don't get to me for a long time. The custom pieces are usually done last.
Then the name of the job itself, along with the date that I take it down to the floor from the blocks, followed by my scribble of an autograph, with a black marker.
What is really cool is getting to rework a project after many years and finding the original date/autograph on the back or inside, depending on what it was. We have re-made cabinets that were damaged by a water leak and find name and date from 10 years back or more sometimes.
This is a habit that started when we first started using a second cabinet carcass press. One of them was clamping slightly out of square, which became noticeable to the installers on long runs of uppers. Marking them with "who" assembled them would tell us if it ever happened again. Also, since the cabinets themselves are CNC cut, they have stickers identifying each part. Most of them are peeled off during assembly, but the ones on the backs and nailers are left on. They have all of the job name, room number, sequence number, etc too.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
