Author Topic: New product teaser on Facebook  (Read 5676 times)
Offline Koamolly
Re: New product teaser on Facebook
« Reply #30 on: June 30, 2020, 11:14 AM »
An inside source has let slip what's in the box. Pricing should be around the $400 / £450 mark and a release date of Q3.
It also explains the extractor in the photos to pick up the sharpenings  :)
Can only be used with Festool's proprietary sized marking instruments made from the same wood as the Sipo Domino Tenons and graphite that impregnates the anti static fittings. There’s also an optional dust collection system available and a cordless Bluetooth rotating motor attachment.
Offline HarveyWildes
« Reply #31 on: June 30, 2020, 12:11 PM »
Cool - Are the new marking instruments also battery operated?  And what about lead - Do we have a variety of colors and hardness?  If so, will there be variety packs or will we have to buy them in packs of 50?  What about inks?  An ink sharpener would be a huge technology advance.  Do all the leads use the same eraser, or are there specialty erasers for different leads?  And of course we all want to know if there is a Leadotec system for quickly changing from one lead to another - if so, I would expect it to flawlessly align with the rotating motor attachment so that the point is always precise and perfectly centered.  I'm also thinking that a track attachment would be useful for drawing straight lines, and perhaps a Shaper Origin accessory that allows you to use it as a large-format printer.
Woohoo!  I see a job opportunity designing stuff for Festool in my future!  (or not...)
« Last Edit: June 30, 2020, 12:16 PM by HarveyWildes »
Offline elfick
« Reply #32 on: June 30, 2020, 12:14 PM »
I think the background of the photos is the key, un-sanded drywall mud. My money is on new Planex that combines the capabilities of the LHS and LHS-E into a single unit that doesn't need to be assembled to use with the reach of the LHS but the ease of the LHS-E. The machine and all attachments plus the hose being able to fit in the systainer XXL.
Offline threesixright
« Reply #33 on: June 30, 2020, 03:27 PM »
Just rumor around the brand. Whats inside is irrelevant. IMO.
As long as they (us) talk about it....
Offline live4ever
« Reply #34 on: June 30, 2020, 03:37 PM »
Definitely cordless Planex.
Offline Master Carpenter
« Reply #35 on: June 30, 2020, 05:39 PM »
The background is just to throw you off. It’s a table saw.
Offline GarryMartin
« Reply #36 on: July 01, 2020, 03:52 AM »
From the social media posts this morning, looks like it's a new Planex with LED ring light on the head. Still corded. Somewhat disappointing to be honest unless there are some other great new features.
Online Alex
« Reply #37 on: July 01, 2020, 04:29 AM »
Hmmm, looks like one of those things where it doesn't mean you should, just because you can.
First, when you put a light source this close to the material it will not improve your visibility because now the shadows are all distorted. When you look at a wall you don't put your eye on the wall, you look at it from a distance. When you want to MAKE the wall to look nice, you must do it under the same circumstances as when people look at it when it is finished. This means people look at it from a distance, and light comes from a distance.
Second, on the video the LED light looks pretty yellow. There was once a time all there was were these huge 500w & 1000w halogen building site lamps, and while they gave a lot of light, it was always very yellow, in the 2700K range. Now we've got these perfect small LED bulbs, 15 watt and an output of 2000 lumens at 5000K. These make a perfect lighting for building and painting, colours look very natural and they are so bright everything is very well visible. I always have 2 or 3 of them burning when I work. This Planex LED light would interfere with that light.
Putting a light on everything is ridiculous and counterproductive. I severly dislike lights on drills, I mean, sometimes they're useful when you quickly want to put a screw in a closet somewhere, but when you're doing some serious work you have good lighting anyway, and then most of the time that drill light is distorting the natural light that's already there. But for a Planex, who's going to do a professional wall job with very expensive equipment and then pass on bringing good light?
Offline Svar
« Reply #38 on: July 01, 2020, 06:17 AM »
That's the point. It's not about visibility or color. If you want to inspect the surface and highlight defects, you put the object under raking light, a light at an oblique angle almost parallel to the surface. Festool even makes STL450 specifically for this purpose.
« Last Edit: July 01, 2020, 06:24 AM by Svar »
Offline Roachmill
« Reply #39 on: July 01, 2020, 07:15 AM »
Offline Spandex
« Reply #40 on: July 01, 2020, 07:54 AM »
As Svar says, if you want to highlight surface imperfections, you want the light source as close to the surface as possible, so that even tiny defects cast a disproportionately large shadow. Inspecting the surface under ‘normal’ viewing conditions (from a distance, with distant natural or domestic lighting) is the last thing you want to do, because as soon as the customer stands close to their wall, or runs their hand over it, they’ll notice all the defects you missed.
Offline mrB
« Reply #41 on: July 01, 2020, 08:34 AM »
Offline jimbo51
« Reply #42 on: July 01, 2020, 08:40 AM »
Back in the day, when I was young and making good money working, I would be very tempted by the right angle sander. On the other hand, maybe I will be tempted anyway.
Offline DeformedTree
« Reply #43 on: July 01, 2020, 03:00 PM »
Does a planex take down material like that in one pass or is that editing magic?
So does this mean the routers might get a light by 2030?
Offline PaulMarcel
    • Voilà, my blog
« Reply #44 on: July 01, 2020, 06:42 PM »
@Roachmill That "positioning aid" for the ETS-125 would be so useful if it fit the Pro-5 sander. Will have to bug HQ when that comes out. I'd get the 90º jig and leave it on that sander.
