Well I have a question for those that are familiar with the scoring function on a large panel saw.
When properly adjusted, the Festool TSV 60 will leave a .35mm (.014") margin on both sides of the cut.
Oldwood prefers achieving a .12mm-.25mm (.005"-.010") margin on both sides.
So...why is there such a brouhaha about the Mafell MT 55 leaving a .1mm (.004") margin on one side? Is it because it only leaves that margin on one side? Would that .1mm margin be acceptable if it was left on both sides of the cut?
Certainly, a .004" margin is a lot more difficult to see than a .014" margin.
I have used several different models with scoring blades. The one we have now is a Laguna. It has the shim style adjustment for width and a screw (knob) that adjusts the entire assembly left to right. It also has to be raised manually, though some machines do this automatically (when the blade is turned on)
It can be adjusted to literally perfect, though it may not be necessary. It entirely depends on what you are going to do with that edge. If you are butting 2 of them together, closer matters, but with something like PVC edge banding, it doesn't matter at all.
The machine we had years ago, in the old shop, worked with a tapered blade. It made the wider kerf as you raise it, cutting deeper.
That's how it works on the beam saw too, though all of the adjustments are done through the software/touch screen.
As far as the TSV60, I wonder why it couldn't be adjusted closer? Seems like it should be able in some way? .014 is almost 1/64", that would be visible, especially joining 2 of them.
Even if you had to do some kind of workaround, there has to be a way.
