Author Topic: CT CYCLONE Pre-Separator: Coming to NA on October 1  (Read 30506 times)
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« on: July 09, 2018, 01:17 PM »
Coming October 1 to North America
CT CYCLONE
Less time changing Filter Bags. More time for doing what matters.
The new CT pre-separator with cyclone technology
For craftsmen who work with large volumes of dust and debris, the CT CYCLONE pre-separator is the simplest answer for increasing the efficiency of your CT Dust Extractor and minimizing its lifetime cost of ownership — all within a compact solution that fits seamlessly into the Festool mobility system. Compliant with OSHA’s Table 1 when used with a HEPA-certified CT Dust Extractor*, the CT CYCLONE is an anti-static** three-step filtration system that separates and collects large debris and coarse dust before it reaches the mobile dust extractor — decreasing the number of filters and dust bags that you’ll need to purchase to keep your CT running smoothly. Additionally, the CT CYCLONE reduces the overall dust load on the main filter and ensures consistently high suction power throughout the work process. Compatible with all CT Dust Extractors, it is a highly portable and compact cyclone solution that can be easily transported to wherever your work takes you.
-  When used with a HEPA-certified CT Dust Extractor, the CT CYCLONE is in full compliance with OSHA’s Table 1 rule for silica dust. Applications and details coming soon to festoolusa.com/osha
-  By removing larger dust and debris before it fills your filter bag, the CT CYCLONE reduces how often you need to replace filter bags and filters — saving you both time and money.
-  Engineered with a unique flat cyclone design to minimize necessary space, the CT CYCLONE fits securely within the Festool SYSTAINER modular storage system — allowing for easy storage and transportation.
CT CYCLONE
CT-VA-20
Item no: 204083
Catalog Price: $375 USD / $480 CAN
*Consult festoolusa.com/osha for applications and details.
** Anti-static system is effective only when used with anti-static design (Festool’s CT series) Dust Extractors.
« Last Edit: July 09, 2018, 01:20 PM by Festool USA »
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
Re: CT CYCLONE Pre-Separator: Coming to NA on October 1
« Reply #1 on: July 09, 2018, 01:21 PM »
Can't wait!!!!!
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Online Cheese
« Reply #2 on: July 09, 2018, 01:27 PM »
I like it...
Offline six-point socket II
  • aka @the_black_tie_diyer
« Reply #3 on: July 09, 2018, 01:28 PM »
So happy to see it's coming to NA in a very timely manner, too!  [smile] [smile] [smile]
Kind regards,
Oliver
Kind regards,
Oliver
Offline Corwin
« Reply #4 on: July 09, 2018, 01:55 PM »
What took you so long?   [smile]
I'm surprised that the hose between cyclone and CT isn't a larger diameter. And those 90 degree fittings are too tight a bend for my liking, but they do make for a more compact setup.
The way the hose going to the tool comes out of the front, it looks like it will be an awkward fit with a Boom Arm.
Offline ColossusX
« Reply #5 on: July 09, 2018, 02:00 PM »
Finally Table 1 compliance
Offline Shane Holland
  • Festool Dealer
« Reply #6 on: July 09, 2018, 04:21 PM »
Available for pre-order, free shipping.  [wink]
877-866-5688
Offline nvalinski
« Reply #7 on: July 09, 2018, 04:37 PM »
Curious how it meets Table 1 compliance... at least as shown, it's using a plastic liner bag on a CT 36 AC, which while capable of handling a HEPA filter, I believe is not rated as HEPA? So I'm assuming to reach Table 1 compliance you have to use the cyclone with the non-AC model?
Offline sprior
« Reply #8 on: July 09, 2018, 05:24 PM »
The product description first says compatible with all CT dust collectors and then says it can't be used with the CT-SYS, MINI, or MIDI - I guess they use the US Cellular providers definition of "Unlimited".
But I don't understand why it can't be used with the MINI or MIDI - is it simply that the connecting hose is a little too short given that it gets plugged underneath the systainer?
Offline c_dwyer
« Reply #9 on: July 09, 2018, 05:46 PM »
No thank you. I don't want to void the warranty on my vac on account of static electricity building up and frying the electronics. I'll stick with my Oneida UDD that has the built-in static conductive components.  [big grin]
Offline Peter_C
« Reply #10 on: July 09, 2018, 07:07 PM »
The boom arm extension hose is 5ft. I would guess it will wrap around to the back no problem. As shown in this photo the length of the 3.5m hose should still work with the cyclone mounted backwards. (Note: I haven't bought a boom arm setup and am speculating.)
Question: I might have missed it but can the "clear bucket" part be left out and just use the lower systainer part as the bucket, making it more compact, albeit with a more limited container size? (Still utilizing a bag.) Better for road warriors and all...
Offline Svar
« Reply #11 on: July 09, 2018, 07:15 PM »
Me neither. They are all equally untistatic. What's the problem?
Offline James Carriere
« Reply #12 on: July 09, 2018, 07:47 PM »
Looks good.  Any word on if it will be compatible with the WCR 1000?
Offline Svar
« Reply #13 on: July 09, 2018, 08:25 PM »
Just a thought.
Shouldn't the cyclone section go between the tub and the motor section of the CT? Then it'll drop dust straight into the tub. Of course the intake of the tub will need to be closed and the cyclone section will have its own intake. Don't all CT series, have the same tub opening shape and dimensions (interchangable)?
In the current configuration the CT tub is not utilized (almost), most of the dust goes into this awkward and mostly redundant tower.
While at it, I'd make the cyclone itself more efficient. >99% is easily achievable. Yes, an efficient cyclone puts more drag on the system, but I'd rather spend the energy there than on pulling air through redundant box, stretch of hose, and two elbows.
« Last Edit: July 09, 2018, 08:59 PM by Svar »
Offline The.Handyman
« Reply #14 on: July 09, 2018, 11:51 PM »
Fully compatible. Even says so in the listing on the Festool products website. Imagine that.
Sent from my SM-G960U using Tapatalk
Offline SRSemenza
« Reply #15 on: July 10, 2018, 12:14 AM »
Just a thought.
So you are saying that the existing tub on a CT would be divided into a portion with a new bag size and a portion to take the larger particles and chips?
CT26 and CT36 are the same upper part. CT Mini and Midi are the same upper part. CT48 is larger.  CT22 and CT33 have the same upper part.
Offline Svar
« Reply #16 on: July 10, 2018, 12:24 AM »
Just a thought.
Cyclone section can contain a small 2-3 liter bag. We are talking about miniscule amount of dust making it through. At least this was my experience with cyclones. I understand its getting complicated, but Festool solution is just awkward.
Offline Chance B
« Reply #17 on: July 10, 2018, 12:26 AM »
Wouldn't it have been simpler and better for transport if the top (cyclone portion) systainer just connected to a sys-5 somehow for the collection bin? Heck, even make the bottom sys-5 clear so you can get the same visibility effect and allow liners inside of it.
Offline SRSemenza
« Reply #18 on: July 10, 2018, 12:48 AM »
  At least one person has built a collection bin from a regular Systainer with a cyclone on top (same idea as the DD for Festool unit). They had to line the inside of the Systainer with plywood to keep the sides from collapsing. As I recall it worked out.
  I think there are trade offs with the design. If the collection bin is a Systainer in size and footprint they stack and transport like any other Sys. But then they would not nest like the bin as shown for compact transport / carrying of a whole bunch of empty bins. If I just had one bin I'd want to be a Systainer. If I had three, five or more I'd want them to nest.
Offline Gregor
« Reply #19 on: July 10, 2018, 06:25 AM »
My view on it in the other topic. TL;DR: I'm not impressed, to put it mildly.
« Last Edit: July 10, 2018, 06:27 AM by Gregor »
Offline Bob D.
« Reply #20 on: July 10, 2018, 10:26 PM »
If they're running a bag in the dust bin, what keeps it from getting sucked up.
I don't see how they are addressing that though they must be somehow.
The only two ways I know of are:
1.) a wire frame that sits inside the bag to keep it from being drawn in or
2.) the method that Oneida uses (and may have patented) and that is to
     equalize the pressure inside and outside the bag using a small 1/4" hose
     that pulls a vacuum on the outside of the bag equal to that on the inside.
This works very well on the Oneida UDD and I bet one could rig up the
same setup on just about any vac.
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #21 on: August 04, 2018, 10:22 PM »
UPS Tracking said I'll get "MY " Demo Monday 8/6/18. I'll make a video after work and post. Ro sanders to 850 plainer. I'm going to try and put it on a CT 26 with boom arm and Work station. New Toy's !!!!!!!
Don Ware
Anderson Plywood Sales
Culver City, California
Offline Distinctive Interiors
  • Modern Kitchen Specialist
    • distinterior.com
« Reply #22 on: August 05, 2018, 05:08 AM »
It was me that fitted a Dust Commander Cyclone into a Sys5.
After my first initial trials with it out on site, there are a few air leaks due to the fact that the plywood lid isn't 100% airtight. I have already made a Mk2 version of the ply drop box that is hopefully going to be more efficient but have yet to try it out as the Mk1 still captures at least 90% of the fine dust I produce.
The size of my drop box is not as large as the containers appear to be on the Festool CT Cyclone (10 or 12 litres at a guess...?) and obviously, that can be rather limiting if you are producing larger quantities of material, such as chippings from a planer/thicknesser. As the majority of what I cut and machine out on site is man made board & sheet materials with fine dust, I check the drop box regularly and empty it.Ive never managed to fill it to overflowing as yet.
It does fit on a Midi though,....as you can see from the pictures in the other thread!  [big grin]
Tim.
« Last Edit: August 05, 2018, 05:17 AM by Distinctive Interiors »
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #23 on: August 06, 2018, 02:03 PM »
It's here !!!! Came in about half hour ago. I have it hooked up and it works Great !!!!!
I'll make a video after work tonight !!!!!
Don Ware
Offline RobBob
« Reply #24 on: August 06, 2018, 03:53 PM »
That's a slick setup with the workcenter.  The Deluxe Dust Deputy is too tall to work with the workcenter.
« Last Edit: August 06, 2018, 07:09 PM by RobBob »
Offline Peter Halle
  • Magnum - My new little boy
« Reply #25 on: August 06, 2018, 06:45 PM »
I saw this video yesterday:
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #26 on: August 06, 2018, 11:23 PM »
Don Ware
« Reply #27 on: August 07, 2018, 04:04 AM »
Thanks for the great live/candid, hands on video Don!
Kind regards,
Oliver
Kind regards,
Oliver
Offline Dick Mahany
« Reply #28 on: August 07, 2018, 09:05 AM »
Many thanks for the real life demo.  As a pre-seperator, it sure looks like it is doing the job well.  While I do like my dust deputy very much, the Festool modular design is an excellent design and I like the ability to use it in the compact arangement as well as with the taller bins.  I think this would be an excellent set up if paired with my CTL-SYS.
Offline rst
« Reply #29 on: August 07, 2018, 09:10 AM »
I have three Oneidas that work great at my stationary tools, I'll be getting the Festool for in my van.
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #30 on: August 07, 2018, 09:30 AM »
Thx Don - For a really informative demo.
While I’ve been a strong advocate/user of my two ALL STEEL Dust Deputies -
Which have seemed to have avoided the problems of grounding and Dust Extractor electronic “burnouts” -
I have to say that it looks like Festool really “listened” to its customers - Rose to the occasion - And “out Dust Deputied” the Dust Deputy.
Three observations were apparent to me from your video.
1.
It really works. So... Major savings on buying/using expensive Festool DE bags.
2.
It looks a LOT STURDIER than I originally thought it to be.
3.
It works “in unison” (fits nicely) with the Festool Dust Extractors.
Of course, “the rubber will meet the road” when it’s in actual use by end users on the job and in our shops.
But... On the front end... This looks like a real “winner”!
Hurrah for Festool... And for us. :)
« Last Edit: August 07, 2018, 09:33 AM by Joe Felchlin »
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline copcarcollector
« Reply #31 on: August 07, 2018, 12:36 PM »
@Don Ware
THANKS for the video!
Offline RKA
« Reply #32 on: August 07, 2018, 01:06 PM »
Thanks Don, that's helpful!  The cuts with the Kapex surprised me, it appears to have filtered out a good percentage of that dust.
-Raj
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #33 on: August 07, 2018, 01:18 PM »
Yes this thing really worked Great !!!!!!
Don Ware
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #34 on: August 07, 2018, 01:27 PM »
There seemed to be a lot of static from the clear bin.  I don't if that will be an issue or not.
Offline usernumber1
« Reply #35 on: August 07, 2018, 01:37 PM »
thanks for the video. this is still very early;
my question is how much pressure drop is there compared to the black or standard DD.
i'd also like to see how much gets past the cyclone into the bag
i noticed that static in the bin as well, maybe the plastic liner would remedy the issue.
Offline jobsworth
  • Festool Baby.....
« Reply #36 on: August 07, 2018, 09:29 PM »
Wow Don thats pretty slick. Im gonna try to make it out to your Festool Demo day and take it for a spin.
Offline guitarchitect
« Reply #37 on: August 07, 2018, 11:27 PM »
Yeah, pressure drop is my big question too - thien separators often lead to a drop of ~50% and the DD is more like 25%...
« Reply #38 on: August 07, 2018, 11:28 PM »
Do you have any photos of your setup? I'm hoping to use one underneath a workbench so that I can hide away my CT26E, I was planning to just run lines where I would need to hook up the vac to sweep up the floor, and maybe make a manifold like Peter Parfitt's
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #39 on: August 08, 2018, 12:07 AM »
Some days just don't go right..... I shot a new video tonight came home and I have no internet. I'm on my phone right now. I cleaned out the Cyclone and changed out the bag in the CT. Cut with the Planex and plained with the 850 and when I was done there was all most No dust in the bag !!!!! I was just in disbelief at how little dust made it to the bag. I will have video upload ASAP
Don Ware
Offline Dick Mahany
« Reply #40 on: August 08, 2018, 09:11 AM »
Looking forward to seeing the bag contents.  With all of the dust in the bin and a relatively empty bag, it tells me that it doesn't matter whether it is a cyclone or a Thein baffle, it gets the job done. [smile]
Offline RobBob
« Reply #41 on: August 08, 2018, 09:23 AM »
Amen to that.
Those people that say only a long cyclone with the magic math ratio can deliver acceptable fine dust separation just flat don't know what they are talking about.
Online Cheese
« Reply #42 on: August 08, 2018, 10:30 AM »
Amen to that.
Amen and I'll raise you a hallelujah.  [smile]
I learned my lesson years ago designing capital equipment. You want to start off a new design with theory on your side but you don't want to be handcuffed by it.  That's one reason model shops exist and thrive.  [big grin]
I know the recent demo at the Festool Roadshow using a Planex & CT Cyclone was pretty impressive. Impressive to the point where I'm now considering purchasing a CT Cyclone.  [huh]
Offline Steven Owen
« Reply #43 on: August 08, 2018, 10:36 AM »
I wonder if there will be a way to adapt this unit to the Midi.  I'm not sure why everyone keeps forgetting the MIDI Users.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline usernumber1
« Reply #44 on: August 08, 2018, 12:53 PM »
you can probably hook it up to a shop vac if you wanted to. i'd be curious how that performs!
« Reply #45 on: August 08, 2018, 01:03 PM »
Amen to that.
I don't want to rain on anyone's parade, but you aren't any farther ahead spending the money on a cyclone over buying bags unless you use a ton of bags.  Most people don't use a lot of bags and they will only lose money on the cyclone on top of having a much larger, bulkier vac setup.
Offline Dick Mahany
« Reply #46 on: August 08, 2018, 01:24 PM »
The break even point between the CT Cyclone and my CT36 is 39 bags.  That is MANY years worth of bags for my use.  OTOH, it would be a nice compact solution for use with my CTL-SYS, albeit a pricey one.
Offline Peter_C
« Reply #47 on: August 08, 2018, 02:02 PM »
True to a point, especially for a home woodworker. I find when sanding drywall with my regular CT36 the bags plug and suction is reduced. Right now my bag is less than 1/6 full and whacking it around, it still isn't producing the kind of suction it should, so I will be replacing the bag the next time I require full suction.
I have an Oneida bucket cyclone and it works very well for even fine dust. Unfortunately it is not as portable as I wish it was (Should really be using it).
Hoping this new design drops fine dust into a plastic bag and allows me to continue using my CT36 for sanding drywall. Didn't take much to convince me I need one. May not be for everyone, but it definitely has it's place.
Offline RKA
« Reply #48 on: August 08, 2018, 02:16 PM »
Even with wood dust, I'll typically replace at 75% full because there is a drop off in suction as the bag nears capacity.
-Raj
Online Cheese
« Reply #49 on: August 08, 2018, 03:00 PM »
Ya, I’m not looking to save money, just want to lighten my load. When sanding drywall, the CT 22 loses its goodness in a short period of time. After that it’s unpile the Systainers, open the 22, whack the bag a couple of times, check the filters...then repeat the process in 45 minutes. It’d be a lot easier to just dump a plastic bin of drywall dust.
« Reply #50 on: August 08, 2018, 05:17 PM »
FYI, there's an adapter available as an accessory part so you can use the cyclone with your sleeved hose:
575668
https://www.facebook.com/jared.jones.39142072/videos/532037707225785/
@Shane Holland , is this something dealers like you will have too..?
« Last Edit: August 08, 2018, 05:25 PM by copcarcollector »
  • Festool Dealer
« Reply #51 on: August 08, 2018, 06:14 PM »
FYI, there's an adapter available as an accessory part so you can use the cyclone with your sleeved hose: 575668
@copcarcollector, yes, I've added it to the website for pre-order. You should only need this if you have one of the sleeved hoses with the Plug-It running through the zippered sleeve.
Order CT Cyclone Plug-It Extender 575668
877-866-5688
Offline pettyconstruction
« Reply #52 on: August 08, 2018, 07:57 PM »
With my ct-26 I do the same,
But what I don’t like about both the Oneida and Festool versions , is the plastic box or bag is allowing the fine dust to get airborne when you dump it. I don’t have either so I’m guessing .
With my vac,I just toss the bag ,replace.
I don’t think  want a open container to deal with vrs a closed bag.
Charlie
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #53 on: August 08, 2018, 09:41 PM »
New bag in the CT 26, CT Cyclone all vacuumed out. Let's see how much dust get's to the CT 26 bag !!!!! ( So little it's hard to film, I expected a LOT more dust !!!!! )
Don Ware
Offline GoingMyWay
« Reply #54 on: August 08, 2018, 10:23 PM »
That's an impressive demo. Thanks for taking the time to record and upload the video.
Inquiring Minds Want to Know
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #55 on: August 08, 2018, 10:46 PM »
This is all new to me, I'm learning as I go. But I'm really enjoying making these video's !!!! Thank You for watching !!!!
Don Ware
Offline Dick Mahany
« Reply #56 on: August 09, 2018, 08:39 AM »
Thank you for the 2nd video demonstrating how effective the CT pre-separator is.  The miniscule particles that did make it into the bag looked to be the fines which makes sense.
I'm anxious to see such a test by someone who sands drywall as that will be the ultimate test.
Offline Gregor
« Reply #57 on: August 09, 2018, 10:34 AM »
Or sanding wood.
Given the videos of the thing in action I suspect extraction efficiency (for the finer stuff) will lessen with the waste container filling.
« Last Edit: August 09, 2018, 10:37 AM by Gregor »
Offline Steven Owen
« Reply #58 on: August 09, 2018, 11:06 AM »
Hi Don,
Here’s an idea for another video.  It would be interesting to see a quick video of the MIDI interfaced with the new Festool cyclone.  It would be interesting to see what accessories might be required to make the Festool Cyclone work with the Midi.
Online Cheese
« Reply #59 on: August 09, 2018, 11:26 AM »
My guess would be a longer hose with a 90º end connection.
Offline RKA
« Reply #60 on: August 09, 2018, 11:57 AM »
...that accomodates a 50mm hose (assuming that's what's used on the CT's).
-Raj
Offline Steven Owen
« Reply #61 on: August 09, 2018, 12:45 PM »
I think you would want an anit static hose about 5 feet long.  I would be worried about lost suction using a 10 foot hose back to the vacuum.
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #62 on: August 09, 2018, 01:10 PM »
I'm a Festool dealer. If Festool said CT Cyclone only works with CT 26/36/48. I can't make a video showing you how to do something Festool is telling you not to do. And if you do it and do it wrong and you break the ground between your CT and the CT Cyclone you could kill your Mini or Midi. And I don't want to be any part of that either.
Don Ware
Offline GoingMyWay
« Reply #63 on: August 09, 2018, 01:35 PM »
I've also very much enjoyed watching the other Festool videos that you have on YouTube!  Lots of good information!
Offline Steven Owen
« Reply #64 on: August 09, 2018, 02:42 PM »
I can understand the position you have to take as a Festool dealer.  You have to tow the line.
All it takes to connect this to a Midi is a longer Festool Anti Static hose.  I don't see how that would compromise the anti static protection as long as the hose being used was not anit-static.  The only problem I could see there would be a loss of some suction power using a longer hose.
Offline jobsworth
  • Festool Baby.....
« Reply #65 on: August 09, 2018, 11:28 PM »
Im interested in this cyclone as do go through a lot of bags. I do have the long life bags in both my CTs but I find I have to empty the main one CT 26 about every week or so. To me If I can just lift off a box from the CT and not having to open up the halves it would save me a bit of time. i think if something will save me some steps or time its worth it.
So Im gonna tell the kiddos to get me one for Xmas.
Offline ben_r_
« Reply #66 on: August 10, 2018, 12:02 AM »
Man... So now with the Plug-It accessory its a $415 setup. Wow... Makes me glad I bought the Oneida back with it was $199.
Offline tallgrass
« Reply #67 on: August 10, 2018, 12:58 AM »
A simple test of how well it separates would be to fill the bucket up half way and weigh it. Vacuum the the contents of the bucket  and weigh the bucket in the separator. the difference will give a good idea. I know you have vast amounts of saw dust in the accumulators you guys run at Anderson.  I would expect it would do a very good job. Not trying to ruin your day Don. :)
Offline Peter_C
« Reply #68 on: August 10, 2018, 10:21 AM »
A very reasonably priced triple tap solves the issue. Personally I see no advantage to buying that expensive extension cord, and I often have multiple tools plugged into my dust extractor. What I want is automatic blast gates.
Could also just weigh the bag and the container, then go to work and weigh them again after. Difference in weight can be figured as a percentage.
Offline tallgrass
« Reply #69 on: August 10, 2018, 02:45 PM »
True, however I do not know if Don has bags yet. The 2 container idea is simply vacuuming from and to  identical containers and measuring the difference. There are many ways to figure out efficiency. Though I expect that this set up works just fine. I am already on the hook for one.  :)
Offline jonathan-m
« Reply #70 on: August 10, 2018, 02:55 PM »
the real test will be drywall and concrete grinding dust...
Festool: 2x MFT/3 // OF-1400 // MFS-400 & 700 // RO-90 // SYS-ROLL // VAC-SYS SET SE1 // CT-ASA CT 26/36/SB // KS 120 EB & UG-L & R //  VECTURO OS 400 EQ-Set  // DSG-AG 125 // DSC-AG 125 // DSC-AG 125 FH // HK 85 EB // HK 55 EB
Protool: 2x VCP 260 LE AC // PDP 20-2 // WCP-32
Mafell: MT55cc // P1cc // DD40P // Erika 85 Ec
Offline RKA
« Reply #71 on: August 10, 2018, 05:20 PM »
I was waiting for that when Don mentioned Planex earlier in the thread.  But it looks like he accidentally interchanged planex for kapex.  But, if he has some time on his hands and some of the walls in the new Festool display area need some touching up....   [big grin]
-Raj
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #72 on: August 10, 2018, 09:35 PM »
No I don't have a Demo Planex ……….. And I don't have any freshly mud covered walls LOL
And I don't have a scale that would weigh that little bit of saw dust I only have a postal scale.
And more saw dust fell out of the hose when I was putting every thing away than was in the bag.
And the cyclone it self had dust stuck on it. So if you had a scale that would weigh things down to a very small weight. You could weigh the bag before and after. But I all so have some bloodwood and some ebony and a littel of that saw dust weighs a lot, and I have some Balsa ( personal use, I like to make mock ups with non for sale ) and a whole bag full of that sawdust weighs almost nothing . So you saw the look on my face when I looked in the bag...... I could not beleave that there was almost no sawdust in the bag ....... My first tought was How can I film something thats not there. And yes some one said " Cut the bag open " You do known I pay for these bags out of my pocket, I bought the camera and do this because I find it fun. So if anyone wants to send me a brand new CT 26 bag I'll do the video again LOL !!!! ( Just Joking don't be mailing me CT 26 bags !!!!! ) I am very glad most people that watch my video's like them !!!!!! If you like them Thank You !!!! That's what keeps me going every day. If you would like to see something and I have a Demo tool I will try and make a video for you.
« Last Edit: August 10, 2018, 10:13 PM by Don Ware »
Don Ware
Offline tallgrass
« Reply #73 on: August 11, 2018, 01:17 AM »
your work is much appreciated. you are just going to have to put up with your adoring fans. The life of a celebrity. :)
Offline grainhaus
« Reply #74 on: August 11, 2018, 01:51 PM »
Its a bummer the Midi/Mini are never included in the big accessory upgrades like this, very annoying. Why Sell something to limit it out of the gate from new accessories, no bluetooth, etc. All it needs to work on the midi is a little longer hose. Why say it isn't compatible unless theres another reason they aren't saying?
Offline Steven Owen
« Reply #75 on: August 11, 2018, 03:27 PM »
The hose the included might actually be long enough to reach the Midi hose port if you mount it backwards.  I don’t think it’s an anti-static issue.  It would be more of a loss of suction issue.  The MiDI motor is slightly less power than the CT26.
Offline JD2720
« Reply #76 on: August 11, 2018, 04:15 PM »
My guess of why Festool does not want it used on the MINI & MIDI is a weight issue. The MINI & MIDI have a much smaller footprint than the full CT 26, 36 & 48. The MINI & MIDI would not be very stable with 50+ lbs of drywall dust setting on top of them.
Offline Steven Owen
« Reply #77 on: August 11, 2018, 05:01 PM »
There is another possiblilty for the Midi:
The other possible option would be to sit the cyclone on a Festool roller cart and attach it behind the MIDI.  Using a Festool cart would be a cheaper option than buying a longer hose.
« Reply #78 on: August 11, 2018, 05:47 PM »
I’ll add to the ‘Why not” speculation, how about putting the CT CYCLONE on top of a SysRoll dolly powered by a CT SYS on top. Don’t have firsthand knowledge of either CTs but I agree with Steven that a Mini/Midi ought to be functional with the CYCLONE.
Offline JD2720
« Reply #79 on: August 11, 2018, 06:52 PM »
The CT Cyclone will function with any brand of vacuum. It just cannot be used on top of other vacuums the way it can be on top of the CT 26, 36 & 48.  I like the idea of using it with the SYS-Cart or the Sys-Roll & CT-Sys.
« Last Edit: August 11, 2018, 08:59 PM by JD2720 »
Offline Steven Owen
« Reply #80 on: August 11, 2018, 07:42 PM »
The CT Cyclone will function with any brand of vacuum. It just cannot be used on top of other vacuums the way it can be on top of the CT 26, 36 & 48.  I like the idea of using it with the SYS-Cart or the Sys-Roll & CY-Sys.
I think the sys cart would be a more practical way to connect the Festool Cyclone to the Midi.  A longer hose with the unit stacked on top would create stability and possible suction loss of the hose connecting the Midi to the cyclone is too long.
There’s actually more options to connect a Festool cyclone to a MIDI than the Onieda.
Offline Eorlingur
« Reply #81 on: August 12, 2018, 05:05 AM »
Thats what I'm hoping is possible. It would be a very flexible way of solving very different needs with fewer parts. If it would fit under a CMS unit as well it would be the perfect setup for me. It would also enable separation, for recycling purposes, of different types of dust with a single extractor. I would use the separator for all wood dust and just use the CT vac for paint and plastic. That would reduce the need for two separate vacuums for some projects.
« Reply #82 on: August 12, 2018, 12:48 PM »
To get even more modular,
Units are Systainer forms
Mix and match as needed
Hose storage unit
Power unit (gasketed)
Filtration/bag unit
Diverter unit?
Separation unit
Dolly
Offline JimH2
« Reply #83 on: August 20, 2018, 10:18 AM »
Can it be used with the CT22 and CT33?
Offline JD2720
« Reply #84 on: August 20, 2018, 10:35 AM »
It can be used with any vacuum as far as dust separation. If the CT22 & CT33 can support the weight of a full tub of drywall dust, than it may be able to be set on top of them.
Online Cheese
« Reply #85 on: August 20, 2018, 10:39 AM »
Yes...this was confirmed by Festool.
Offline ronen
« Reply #86 on: September 03, 2018, 02:49 AM »
Hi everyone,
I'm new here...
Great Forum!
I need some help:
Does anyone know if the festool ct pre-separator ct-va-20 is compatible with the cleantec CTL-mini and/or the cleantec CT 17 ?
Can it be mounted on the CTL-mini?
Thanks a lot
« Last Edit: September 03, 2018, 02:52 AM by ronen »
Offline jobsworth
  • Festool Baby.....
« Reply #87 on: September 03, 2018, 03:25 PM »
I dont think it can.
 I think its designed to work with a regular CT
I would call Festool to be sure.
Offline Bullterrier
« Reply #88 on: September 04, 2018, 02:54 AM »
I see that Festool UK has updated the description to state separation of:
Up to 80% mineral dust (to be used with Autoclean vac).
Up to 95% coarse dust (sawdust shavings chips)
I assume MDF dust would fall across the 2 categories?
It will be good to see some real world video reviews soon!
Offline ben_r_
« Reply #89 on: September 04, 2018, 10:16 AM »
And some comparisons with the Oneida!
Offline Gregor
« Reply #90 on: September 04, 2018, 11:00 AM »
I just saw the CT CYCLONE live on a roadshow.
Still not impressed.
Comment from another visitor: great idea, but why does it need to look that pieced together?
Offline wilde737
« Reply #91 on: September 07, 2018, 09:17 PM »
Anyone know if this can be used on a CT36 for use with the planex without having an Autoclean vac?  I would like to buy one but just can't justify buying another vac as well, I already have two for my little hobby shop.  Thanks
Offline Bullterrier
« Reply #92 on: September 08, 2018, 03:44 AM »
Festool state up to 80% separation of fine dust and recommend the AC. There’s no physical restriction but the 20%+ passing through would soon affect suction.
Offline rst
« Reply #93 on: September 08, 2018, 09:41 AM »
Remember, that 20% is going into your bag, not the filter.
Offline jobsworth
  • Festool Baby.....
« Reply #94 on: September 08, 2018, 12:08 PM »
@rst
That is true. What I like is the increase capacity. Since I use my CT 26 to suck up the chips from my CMS Ts 75 module, and router modules, plus suck up the chips that dont make it in the trash when I use my Makita thicknesser/Planer and Jet jointer.
So there is a advantage to haveing the larger capacity for me. Especially on larger jobs/projects
Offline JimH2
« Reply #95 on: September 09, 2018, 08:59 AM »
Unless you are a production shop it probably is a lot cheaper to keep buying new bags or to buy one of the ones that is reusable. You'd have to run through a lot of bags to offset the cost and even with this you still need to buy bags (just not as many).
Offline Peter Halle
« Reply #96 on: September 09, 2018, 09:20 AM »
Obviously this as @JimH2 points out will not be for everyone.  Neither will using just bags or even the long-life bags.  I could see myself potentially getting one for some scenarios but then again, not for all.  I have never gone the long life bag route because I do drywall repairs and the finer dust does clog the pores of the long-life bags.  I don't use the router enough to justify that bag either.
I have one of the plastic Oneida cyclones that I rigged up a way to attach it to my older CT but stopped using it because it was clunky.  To get rid of the larger bulky stuff in a non disposable bag situation was great.  It did elongate the intervals before bag replacements for me even when sanding drywall.
I think that the new Cyclone will appeal to a large part of the market but obviously will not be for everyone.  I am now traveling with my current model Midi so unless I switch back to my larger CT I am not a candidate for the Cyclone unless I mod things.
Online Cheese
« Reply #97 on: September 09, 2018, 10:25 AM »
I'm considering purchasing one for my CT 22 just so that I can monitor how much dust has been generated and empty the vac EARLIER and EASIER.   With the conventional setup, it's out of sight, out of mind and the bag gets packed full.
Miele has had "full bag" indicators on their vacuums for the last 10 years.  [cool]   Never understood why Festool didn't offer that feature.
Offline Peter Halle
« Reply #98 on: September 09, 2018, 10:53 AM »
My experience is that although it happens to “brick” a bag, performance is probably slipping as the bag pores are getting clogged.  I wouldn’t pay one dollar more for an indicator on the Festool vacs because personally I feel that it would send the wrong message.  By the time the bag is full it isn’t working as well.
I am admittedly a bag slicer or cleaner who has tried to extend the life of bags although I haven’t done that on the newer fabric style bags.
« Reply #99 on: September 09, 2018, 12:13 PM »
@Peter Halle, why not? (I haven’t yet bought a fabric bag)
Offline Peter Halle
« Reply #100 on: September 09, 2018, 12:43 PM »
@Michael Kellough, Is the question was why haven't I slit a fabric bag yet?
« Reply #101 on: September 09, 2018, 02:44 PM »
@Peter Halle, yep. I open paper bags to re-use when the debris isn’t so fine as to plug the filter medium bit thanks to usually using a Dust Deputy I’m still working through a stash of paper bags so I’m wondering about the fabric bags. Tape won’t stick?
Offline Peter Halle
« Reply #102 on: September 09, 2018, 03:11 PM »
@Michael Kellough , I don't know yet if tape will stick.  I have always assumed that I was going to have to sew or use slit pvc pipe.  This week I will be doing a large mantle out of MDF sheet so I might have a full bag soon though.  That will be the fifth bag on this job - GROWL!
Consolation is that the homeowner has commented on how clean I am versus others working on the job.
Offline RKA
« Reply #103 on: September 09, 2018, 04:14 PM »
Your point is valid, but the Miele feature is less than advertised.  I find the indicator hasn’t moved enough to indicate a drop in suction, but I can tell when the performance has dropped.  A visual check of the bag confirms it’s 75% full and changing it out restores the performance.  So I don’t find that implementation useful at all.
-Raj
Offline rst
« Reply #104 on: September 09, 2018, 04:23 PM »
I haven't slit any of my bags yet but I replaced a lost Makita bag clip by splitting a length of polypropylene tube cutting angles into the ends and slipping it over the folded bag...still using it 15+ years later.  Split tube like this is also great for slipping over saw teeth to protect the sharpness and other tools in tool boxes.  Usually the tube is sold in the plumbing sections of hardware stores and it is better to heat and straighten it before splitting.
« Last Edit: September 09, 2018, 05:21 PM by rst »
« Reply #105 on: September 09, 2018, 05:08 PM »
I haven't slit any of my bags yet but I replaced a lost Makita bag clip by splitting a length of polypropylene tube cutting angles into the ends and slipping it over the folded bag...still using it 15+ years later.  Split tube like this is also great for slipping over saw teeth to protect the sharpness and over tools in tool boxes.  Usually the tube is sold in the plumbing sections of hardware stores and it is better to heat and straighten it before splitting.
Great tip! Didn’t know you could do that.
Online Cheese
« Reply #106 on: September 10, 2018, 12:35 AM »
Well to each his own... I rather like the indicator and while it’s not a hammer in the head “change this bag now” statement, if you monitor it’s action, it is a litmus test as to how far you’ve travelled down the “is this bag almost filled” road.
While a speedometer doesn’t prevent you from exceeding the speed limit, it is a nice option and certainly better than no speedometer at all.
I’m old enough to remember when wind shield wipers, wind shield washers and seat belts were all additional extra cost options on a car.
So maybe this “bag getting full” feature on a vacuum comes under that jurisdiction...good ideas that just need to wait out their time and at some time become adopted as “finally the time has arrived” for this idea. Just a thought... [big grin]
« Reply #107 on: September 10, 2018, 10:33 AM »
I’m with @Cheese sure would like to know the bag is getting full before it becomes a brick on the CT 22 with it’s stupid rigid pipe into the bag design. When using that vac for sanding there is still enough suction (especially if you’re at the end of a project and working with fine grits and lower suction) that there isn’t even a subtle indication that the bag is full. And when the bag is packed tight with dust (especially when the dust is reinforced with planer shavings) you aren’t getting that bag out until you’re run a long auger into that stupid pipe.
Online Cheese
« Reply #108 on: September 10, 2018, 01:39 PM »
Pulling a "bricked out" bag out of a CT 22 is futile. It's only happened a couple of times but I remember it like it was yesterday.
Even worse, is trying to remove a 15 gallon "bricked out" bag from a Milwaukee stainless R2D2 vac. It's impossible, I don't even attempt it, I just take a knife to the bag and start to scoop debris with my hands. What a mess...  [crying]
Offline rst
« Reply #109 on: September 10, 2018, 06:26 PM »
Broke down and ordered mine today.
Offline dlu
« Reply #110 on: September 14, 2018, 04:43 PM »
I think I read somewhere that the sys-cyclone has a static conductive pathway.
Offline jobsworth
  • Festool Baby.....
« Reply #111 on: September 15, 2018, 12:09 PM »
Im with Cheese and Michael K to. I want to know when the bags getting full. Hate being in the middle of project then lose suction bc the bag is bricked and dust going everywhere. Then I have to stop empty the bag clean up the mess before i go on. This with the box makes life easier that way.
plus If I get a real large job I can just get some more bins. Pop one out pop one in ad go on.
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #112 on: September 15, 2018, 01:02 PM »
OK one last video. I vacuum up 25 pounds of saw dust then weigh the bag and cut it open to show you what made it into the bag.
Don Ware
Offline Dick Mahany
« Reply #113 on: September 15, 2018, 01:37 PM »
Well that pretty much says it all.  Impressive indeed !  Thank you Don.
Offline GoingMyWay
« Reply #114 on: September 15, 2018, 01:43 PM »
That is impressive!  Thank you for sacrificing that brand new bag as well.
Offline Don T
  • Phoenix, Az
« Reply #115 on: September 15, 2018, 05:40 PM »
That definitely makes up my mind. I will be buying from Anderson since Don took the time and materials to do a demo.
Online Cheese
« Reply #116 on: September 15, 2018, 06:00 PM »
Thanks 🙏 for the demo Don...that was pretty impressive.
Offline RKA
« Reply #117 on: September 15, 2018, 08:06 PM »
Thank you Don!  That was very helpful!  This is worse than a real world scenario because you’re flooding the cyclone with dust.  I would not have been surprised to see more in the bag under these conditions.  These results are far better than I would have expected.  Thanks for sacrificing the bag, now if you’ll just post your address you’ll receive a lifetime supply from all the grateful FOG members!   [tongue]
-Raj
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #118 on: September 15, 2018, 09:21 PM »
@RKA  Yah I've been throwing things at this for a month now, And it been blowing my mind how well it works. And I have already over filled the cyclone ( Not paying attention …… Hickory live edge slab making it flat with the 850 planer ) I didn't think the bag would be that hard to cut. And after 14 years of trying to make a bag last as long as possible 1st CT 22 and after CT 26 bag  cutting a good bag open hurt LOL !!!!! This thing has amazed me !!!! I film these real time and it's still does better then I thought it would. Glad this helps !!!!! I am having fun making the video's !!!!
Don Ware
Offline jobsworth
  • Festool Baby.....
« Reply #119 on: September 15, 2018, 11:46 PM »
Thanks for doing this Don. A lotof folks were getting hung up with loss of suction, but this video clears that up. Who cares if there is a little loss , it does a great job. Come on Santa....
Oh nice knife to  [big grin]
See ya next month at the road show
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #120 on: September 15, 2018, 11:54 PM »
@jobsworth I thank you for that knife !!!!!! One of my most used " Festool Things "
Don Ware
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #121 on: September 16, 2018, 01:50 AM »
Don's results show a far better percentage being trapped by the interceptor than I achieved. I think that his test was more thorough than mine:
I am looking at the performance with the CT Sys which should be completed soon.
Offline rst
« Reply #122 on: September 16, 2018, 08:58 AM »
Fantastic video, thanks Don for justifying my faith in Festool engineering as I just ordered mine from Toolnut last week.  I knocked the inspection light out of first place for gotta haves.
Offline jobsworth
  • Festool Baby.....
« Reply #123 on: September 16, 2018, 04:25 PM »
@Don Ware
no worries buddy Ill see ya next month. I may have a little sumptim sumptim for ya then to :>D
Offline dudeabides
« Reply #124 on: December 15, 2018, 01:55 PM »
I am looking at picking up a CT. If I get a ct-cyclone, would there be any reason to get a CT36? being that the CT 26 is the same?
thanks for any input
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #125 on: December 20, 2018, 05:59 PM »
If your getting the CT-Cyclone the CT 26 would work just the same as the CT 36
Don Ware
Offline Simon O
« Reply #126 on: January 24, 2019, 06:51 PM »
After trying a number of times over last few months - the answer from Festool UK is, there's no reason why the pre separator can't be used with the Sys/Mini/Midi. The reason why they don't recommend this use, is the device was designed to fit with the 26 and above models - there's no engineering reason why it won't work with the smaller machines, just perhaps less efficiently due to lower flow rates.
Offline morts10n
« Reply #127 on: January 24, 2019, 08:19 PM »
I used a Ultimate Dust Deputy with my CT26 from day one and had zero dust in the bag for 3 years.
I recently replaced it with the Festool cyclone because I liked the flat top on it and the ability to stack other systainers. After one month my CT bag was almost full
Offline Ordewin
« Reply #128 on: January 25, 2019, 05:33 AM »
I use mine with the midi and the SYs with no issues at all. I was informed by Festool at one of the shows over hear, was that on the Midi it could be top heavy and potentially topple over, really not an issue for me as I don't see myself using it whilst pushing it around. The SYS has a different power to the CTs but I cannot see any visible  drop in collection
