Author Topic: Tips for painting a systainer  (Read 2367 times)
Offline Systainer.Store
    • systainer.store
« on: July 18, 2019, 01:25 PM »
I'm looking to do a one off paint scheme on a systainer.  I'll certainly post results once I get it done.  As I plan out this project, I'm thought I'd ask around for tips on painting the systainer.  What prep work have you done?  What paints?  Did you primer first?
-Sys Tim
Offline SRSemenza
Re: Tips for painting a systainer
« Reply #1 on: July 18, 2019, 03:01 PM »
-Sys Tim
I have not painted a whole Sys but I have painted latches. I used spray paint. Some are supposed to be better for plastic. Not sure it really matters.
But clean thoroughly with something that will strip and residue and oil.  I like plain 70% rubbing alcohol.
I would be inclined to prime.
I would not expect any type of paint / method to not end up getting scratched.
How intricate is the paint scheme?
    • systainer.store
« Reply #2 on: July 18, 2019, 08:48 PM »
Thank you Seth for the quick response.
I'm thinking two colors, not too intricate, kind of like some strips.  I don't want to give the design away, but we are getting close to football season.   [cool]
This is mostly a for fun project, not necessarily something to last forever or even a specific performance requirement.
Offline reidbailey
« Reply #3 on: July 18, 2019, 08:52 PM »
I’ve used https://www.semproducts.com/ for automotive interior plastics. They offer primers and adhesion promoters. Might be worth looking at for your project.
Offline notenoughcash
« Reply #4 on: April 04, 2020, 12:47 PM »
scroling through this bord looking for ideas and would love to see the result of this
wishlist:    take a look at every page in the festool website.
Offline Dan C
« Reply #5 on: April 04, 2020, 12:58 PM »
Whenever I’ve painted plastics I always use adhesion promoter. Found it to make a significant improvement over not. Could always clear over the color too.
Remember light coats of all products rather than thick.
    • systainer.store
« Reply #6 on: April 04, 2020, 01:59 PM »
Here are the results of what I did last summer.  I tried some light sanding and and then cleaning and wipe down.  I didn't use a primer or a clear coat.  This unit is really more for display.  I use it lightly around the home.  There are several good suggestions in this and other threads and next time I'd consider those more such as automative paints and setting up a spray booth.  I just used spray paint I got at a local supplier.
Offline gunnyr
    • Compass Custom Creations
« Reply #7 on: April 06, 2020, 07:59 PM »
Looking at your results it came to me that there are some really good chemical paint strippers available.  [big grin] [big grin]
« Last Edit: April 06, 2020, 08:42 PM by gunnyr »
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
