Author Topic: T-Loc inserts / inlays  (Read 523 times)
Offline Paul_HKI
« on: March 29, 2021, 02:25 PM »
Hoping folks could spare a minute or two to help a guy out.
Looking for the part numbers for T-Loc inserts to suit the following tools:
Rotex 150 FEQ (current type) - Answer:  700879 T-Loc 3 size
RAS 115 (all old now)
ETS 150/5 EQ (Not the 'newer' EC type)
RTS 400 R (current type)
Finally, not sure if it exists, but if there's an insert to suit a T18+3 and take a TCL6 or 8 charger instead of the TCL3, that would be most helpful.
If you have these tools supplied in the T-Loc systainer, the part number is the usual 6 digit number format, moulded into the insert.
Want to retire a couple of battered classic systainers and get rid of a couple of Sys3, which I really don't like.
If you could help out, I'd appreciate it.  Tried finding some sort of list of same but have had no luck so far.
« Last Edit: March 29, 2021, 02:33 PM by Paul_HKI »
TSC 55, TS 55, DF 500, DF 700 (XL), OF2020EB+, OF900E, CXS, TXS, T18+3, PDC 18/4, RO 150, RAS 115.04e, RTS 400, ETS 125, ETS 150/5 EQ, CTL MIDI, FESTO SR151 E-AS, CTL-Sys, MFT/3, Sys-Roll etc.
Offline squall_line
Re: T-Loc inserts / inlays
« Reply #1 on: March 29, 2021, 03:43 PM »
EKAT appears to have the inserts under the "workplace organization" section, under the TLoc Systainers.
Take this with a grain of salt; it would be beneficial if someone who has one of these could verify against the EKAT listing:
700839 - Bedding Sys RAS 115
700868 - Bedding Sys RS/RTS 400
708098 - Liner RS/RTS 400 REQ
Offline Paul_HKI
« Reply #2 on: March 29, 2021, 04:49 PM »
Total gent.  Thanks very much.  I tried looking in the EKAT before, but it's only in the past couple of days/weeks that they've made it possible to switch the language from Finnish to English.  Anyway, that's a great help - thanks again.
