Author Topic: Systainer3 wins Red Dot award  (Read 509 times)
Offline Charles959
« on: July 24, 2020, 09:05 AM »
The Systainer3 system has won a Red Dot design award:
https://www.red-dot.org/project/systainer3-47429
It is interesting to see that Festool is credited with the design.
Offline Rene_H
Re: Systainer3 wins Red Dot award
« Reply #1 on: July 24, 2020, 10:57 AM »
2 things: It makes sense if Festool is Tanos' largest "client", then product direction could be driven by them.
In regards to the front handle not laying completely closed when stacked due to the T-Loc lock... From that photo, it looks as if the  Systainer3 T-Loc lock, because of its slight design change in shape, doesn't prevent the handle from being in the closed position when stacked. So I went and measured it, and the new T-Loc lock is not as wide. So when rotated, I can see how it will not be a problem.
Lastly, I did confirm the old and new locks are interchangeable. While not ideal ($$$), if it does bother you, you can replace the old locks with the newer style, if and when available from Festool.
