Well, the core issue is that Systainers solve a problem really well and there really isn't much in the way of alternatives. Other systems are limited, not nice dimensions and or just not available in the USA (part that matters to some of us). I've looked into things like "Euro norm" containers, those have a benefit of using the same footprint and being made by many companies. Problem is they too don't exist in the US for the most part, and what are sold here cost many times more than what is paid in Europe (basically depending on the size a systainer is about the same price). Some get better if your in the market to buy a few thousand of one size.
![Sad [sad]](https://www.festoolownersgroup.com/Smileys/default/sadsmiley.gif)
Also Euronorms don't have the latches and such, so good for some stuff, not others.
Systainers are expensive, it's hard to put a number on if they are overpriced but I'd wager they make a healthy profit. I was ok with the price if things stayed standard. This is/was my issue on this subject a while back. Basically the need for standard containers like these. In Europe there are options, in the US, things are very limited.
You also get into the situation where there is the midi line that never had all the sizes, I think they now went from 2 to 3 sizes, odd, and it's the size that doesn't make sense. Meanwhile the Maxi size never even got T-loc update. I'd prefer to see that get revised too, since it's the double to the systainer so the 2 can work nicely together.
It looks like the first gen went 17 years, then the t-locs came. That's typical, you change a few years ahead of patents expiring, this go is a bit soon on the cycle as it will be 10 years in. You need to launch a new model a few years ahead of patents expiring so people get use to the new and thus when patent runs out no one is interested in making the old any more. With this change it could be nearly 10 years before someone could make systainer t-loc designs and spawn a open design. So probably won't happen.
I do wish there were other options. But in the end, what is key is interchangeability. If someone else comes out with something similar but it's different footprint, or doesn't connect together with these ones, there is no point.
I spend a lot of money putting all my stuff in systainers the past few months. It is wonderful to have everything organized and it makes working so much better. Thinking about how many thousands I spent on this effort really was something hard to grasp and caused second guessing. It's certainly not any easier with things changing. I really wish there was an ISO standard option, something made by multiple companies. If there was, I would have taken festool stuff out of systainers and move it all into what ever standard design there was, just like I tossed all the blow molded cases of the other brand tools I had. But there simply wasn't options. Now a change would be rough. Tanos knows this, so they basically know they can break things and there won't be consequences. I can generally adjust to the heights, I just don't like having things mismatches, as it moves away from the goal. I really don't get the removal of the side labels, I'm not sure what all has been made better here, and how much more expensive will these now be. What becomes of the products out there, does things live in a dual world for many years? What about say Mafell, do they change over, make a deal to stick to old, or go some other brand which then hoses over folks who again want the interchange. What about those who make air compressors and such.
I'm sure some of this happened before with the previous update, but I wasn't around then. I worry that companies will bail and go to other systems and then were does that leave Tanos. Overall I guess those companies will adjust too and move on with the new system. It's going to be really frustrating though if I want to buy say a Mafell Dual Doweler and they decide to go to a different brand of case, that's not going to work well at all.
