Author Topic: SYSTAINER³ available from September  (Read 42897 times)
Offline tobiaskurz
« on: June 27, 2019, 05:58 AM »
Festool and tanos has announced the 3rd generation of there SYSTAINER. The new one ist called SYSTAINER³.
New is:
 - it has an integrated handle at the front (wehre the T-LOC sits)
 - the possibility to lock the box with a padlock
 - form Januare 2020 there is an so called Organizer available – Transparent latch to store screws and similar hardware ...
The new SYSTAINER³ is compatible with its predecessor, the SYSTAINER T-LOC. Its also Possible to place and connect it on top of a Clasic SYSTAINER.
more info can be found: https://systainer3.com
« Last Edit: June 27, 2019, 06:04 AM by tobiaskurz »
Offline Roachmill
Re: SYSTAINER³ available from September
« Reply #1 on: June 27, 2019, 06:13 AM »
Thanks for the heads-up. A front handle looks interesting!
Offline six-point socket II
« Reply #2 on: June 27, 2019, 06:30 AM »
For those using Instagram, keep an eye out for " #systainia "
Kind regards,
Oliver
Kind regards,
Oliver
Offline amcore
New generation systainers!
« Reply #3 on: June 27, 2019, 07:12 AM »
Festool addicted!
Offline ggc
« Reply #4 on: June 27, 2019, 07:33 AM »
Looks like the heights are different (except for 1) from the current system.
And the L size is a bit bigger than a Midi, I guess it's been done to fit in with the bott vehicle system.
Offline RKA
« Reply #5 on: June 27, 2019, 07:36 AM »
The organizer M is interesting.  If the top seals the contents of each cubby, I’m all about it!
-Raj
Online Peter Halle
« Reply #6 on: June 27, 2019, 07:42 AM »
Note:  I have merged the two different threads about the new Systainers into one.
Peter Halle - Moderator
Offline GarryMartin
« Reply #7 on: June 27, 2019, 07:42 AM »
Looks very much like Sortimo T-BOXX. I have several of those and they are excellent.
Offline RKA
« Reply #8 on: June 27, 2019, 07:48 AM »
Yup!  I have them, but they don’t play nice with systainers.  These do!  :)
-Raj
Online DynaGlide
« Reply #9 on: June 27, 2019, 08:00 AM »
I'm glad I haven't yet invested in small parts storage. I'll probably end up with some of those organizer M's in Sys-AZ drawers.
They're missing the mark by not making the Sys-Combi standard. Several of my tools would benefit from having a Sys-combi with drawer for expendables, accessories, etc but to convert over from my standard systainers would be absurdly cost prohibitive.
Instagram @matts.garage
Offline zapdafish
« Reply #10 on: June 27, 2019, 09:17 AM »
any idea if mini's will get a handle?
Offline DeformedTree
« Reply #11 on: June 27, 2019, 09:47 AM »
Of course this happens shortly after I invest a lot of money in a lot of systainers.  I was just telling myself the other day they will probably make a new version soon as the patents on the current version are probably about to expire. Maybe other companies will just start making T-lok style containers on their own once the patents are dead.
Updates are fine, but seriously, if you are going to make an announcement like this,  tanos/festool needs to put out some explicit/clear information on the changes/compatibilities from the current model.   It doesn't look like from a glance they are hugely different, maybe just some added aspects.  But if form factor/interfaces/heights changed, that's going to cause heartburn for folks.  I might rather see a side by side of the improvements/changes then "action photos" of them that tell folks nothing.
It looks like they added a front handle (makes sense on short ones I guess),  rounded the corners instead of the chamfers.  The Latch is different looking.
Down side is it looks like they down graded the label setup.  I don't see side label holders.  That sucks, as I put labels on on 3 sides. That was/is one of the really nice features.
Offline cpw
« Reply #12 on: June 27, 2019, 09:51 AM »
Yes, removing the side labels is definitely a negative.  The handle swings to the front instead of the back, so I wonder what this means for attic lids and how much space the handle takes up.
I'm a big fan of the sortainer IV for small parts and just in general having mobile drawers for smaller tools rather than needing to open a stack; hopefully there is a good replacement for it.
Hopefully, the partnership means the MIDI-like M will have the equivalent of a SYS-AZ available.
Online nvalinski
« Reply #13 on: June 27, 2019, 10:23 AM »
Love the van racking slides, even if I might not use it. Also those Bott systainers with the black and green latch look incredible. One thing that I don't love is that it looks like the front handle actually gets in the way of the T-loc latch from a box underneath... seems like a bit of an oversight.
Offline wheely
« Reply #14 on: June 27, 2019, 10:24 AM »
From Festool's Swedish site:
https://www.festool.se/kampanjer/microsites/mobilitet
Is there an overview table with all new designations, sizes and heights?
Product                                                              SYSTAINER T-LOC   SYSTAINER³   Difference
Old        New          Dimensions      New          Dimensions      Height with feet in mm
SYS 1 TL   SYS3 M 112   396mm x 296mm                                112               112          -
-          SYS3 M 137   396mm x 296mm   SYS3 L 137   508mm x 296mm   -                 137          New
SYS 2 TL   SYS3 M 187   396mm x 296mm   SYS3 L 187   508mm x 296mm   164.5             187          22.5
SYS 3 TL   SYS3 M 237   396mm x 296mm   SYS3 L 187   508mm x 296mm   217               237          20
SYS 4 TL   SYS3 M 337   396mm x 296mm                                322               337          15
SYS 5 TL   SYS3 M 437   396mm x 296mm                                427               437          10
SYS3 L is not the same size as the SYS TL Midi
496mm x 296mm
Offline wheely
« Reply #15 on: June 27, 2019, 10:29 AM »
UK Version of the New Systainer site here:
https://www.festool.co.uk/campaigns/microsites/mobility
Offline wheely
« Reply #16 on: June 27, 2019, 10:34 AM »
Systainer³ M
Technical data - Systainer SYS3 M 112
Dimensions with floor stand (L x W x H)   396 x 296 x 112 mm
Systainer³ L
Technical data - Systainer SYS3 L 137
Dimensions with floor stand (L x W x H)   508 x 296 x 137 mm
Organizer M
Technical data - Organizer SYS3 ORG M 89 6xESB
Dimensions with floor stand (L x W x H)   396 x 296 x 89 mm
Organizer L
Technical data - Organizer SYS3 ORG L 89 10xESB
Dimensions with floor stand (L x W x H)   508 x 296 x 89 mm
Offline Dusty.Tools
    • Dusty.Tools
« Reply #17 on: June 27, 2019, 11:45 AM »
I’m having the same heart burn! Just finished making an expensive switch to 100% Systainer setup!
It’s called Sod’s law :)
dusty.tools
@dusty.tools
Offline StanB
« Reply #18 on: June 27, 2019, 12:09 PM »
I like the fact that they have integrated drawer slides and do not neccearily need a sys AZ drawer. You could have some simiple splines or even use 2-3 dominos to act ask pins to store in a chaos wall.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
Offline Bob D.
« Reply #19 on: June 27, 2019, 01:58 PM »
Will they be available in the US the same time as the rest of the world?
Offline wpz
« Reply #20 on: June 27, 2019, 05:42 PM »
Unfortunately they will not be available in the US as they are only available in metric sizes  [big grin]
« Last Edit: June 27, 2019, 05:57 PM by wpz »
« Reply #21 on: June 27, 2019, 09:39 PM »
dusty.tools
Yeah, last year I had none,  now I probably have like 40-50.  I purposely didn't by some sizes so that I could keep consistent stacking.  This way when they are in cabinets on shelfs I can maximize the fit.  Now things will be all messed up.
I'm curious as to why they changed the heights, I get if they wanted to add some tween sizes from the old, but changing the heights just a little doesn't make much sense.
Like everything else, systems only work when they stay systems.
Offline mrB
« Reply #22 on: June 28, 2019, 02:24 AM »
What!? They've changed the heights of the regular sys1-5 ?! [scared]
That's ridiculous!! That's more than ridiculous. That's almost the whole point. The way i use mine with drilled mft type slabs 'cleated' on top of 2 or 3 matching stacks, the way I transport them, the way I store them both at home and the workshop... They changed the heights? Ffs.
It's gonna be a sad day when my first festool arrives in a systainer that doesn't match stackable  with all my others. In fact, I'm now more likely than previously to buy a non festool and a systainer separately.... There have been a couple of purchases at least where i bought the festool over the competition partly because the systainer came in the price... (Like the little plane and an RTS)
I thought festool were all about systems? These new heights don't even double up to equal another size in the range. Seriously?
EDIT:
EDIT #2
Thank to the post below I have realise these measurements previously contained the feet (7mm) now removed as only the bottom feet factor in stacking heights.
And as others I said I also hope there is method or reason in this madness!
 New heights:
105mm
130mm
180mm
230mm
330mm
430mm
 Old heights:
Sys1 = 105mm
Sys2 = 157.5mm
Sys3 = 210mm
Sys4 = 315mm
Sys5 = 420mm
« Last Edit: June 28, 2019, 04:47 AM by mrB »
Offline Euclid
« Reply #23 on: June 28, 2019, 03:49 AM »
I'm struggling to think of a valid reason for messing with the heights of Systainers... was anyone routinely finding the sizes "just a bit to shallow"? I do "sometimes" find the Sys1 a touch to shallow - and I have long fancied a "Sys6" (for a very specific application) - but neither of those were sufficient reason for wanting the system changed!
I thought the base of the Kapex was arranged to be the same height as a Sys1 - so they could be used as out-field material supports. I don't have a Kapex (though I'd like one) - but what happens there?
Also, the business of Sys-stack combinations equalling the height of an MFT?
(It's a bit early in the morning here for pre-coffee mental arithmetic, but I can't readily see a combination that would work).
Makes a nonsense of this, from Sedge:
https://www.instagram.com/p/Bys1S0iDoDD/
Offline Jiggy Joiner
« Reply #24 on: June 28, 2019, 03:52 AM »
Wonder how the new height will work out for things like, supporting a work piece when using a Kapex on the floor? A spacer?
Stacking Systainers to a level height of an MFT top?
Does seem a bit odd, and if it ain’t broke........................
Offline ggc
« Reply #25 on: June 28, 2019, 03:58 AM »
Do the listed new heights include the 7mm for the feet?
Either way, it looks like only the SYS1 lines up height wise between old and new, unless there's a mixture of feet heights in the new sizes.
I'd like to think there's a good reason to stray from the existing sizes and it's not just some marketing bastardy.
Offline mrB
« Reply #26 on: June 28, 2019, 04:57 AM »
LOL!!  Never seen this perfectly demonstrated brilliance of how, the now Outdated, t-Loc and Classic systainers worked.
I'm gonna end up like one of those weirdos we used to get round here trading T-locs for Classics [tongue]
Offline Euclid
« Reply #27 on: June 28, 2019, 05:20 AM »
I had given up looking for an Classic plus the 'extender section' to make a case for my portable steam-cleaner... the new "Sys6" (?) might "just" do the trick (it was that close...).
At least, it appears, the new will stack and lock with the old - otherwise it's a bit disappointing, and messy... can anyone see some virtue in this  that most of us seem to be missing?
« Reply #28 on: June 28, 2019, 05:29 AM »
Maybe it has to do with the bott van racking. But I honestly don't know.
Kind regards,
Oliver
Kind regards,
Oliver
Offline tobiaskurz
« Reply #29 on: June 28, 2019, 06:12 AM »
Yesterday there was an extra page about the new SYSTAINER³ on festool.de today its gone. #edit the page ist still available (https://www.festool.de/kampagnen/microsites/mobility) but no reference to it is on the home page.
It looks like that the feet stay with 7mm the same.
The only hight combination wich makes sense if found quickly is:
SYS3 M/L 137 (the new one in between the 1 and 2) + SYS3 M/L 237 (previous SYS 3) = two times SYS3 M/L 187 (previous SYS 2)
Maybe the Organizer helps to compensate the upcoming hight differences.
The practical hight combinations we all know from the Classic SYSTAINER and although the T-Loc seem to stop with the new ones.
Valid for SYS Classic and T-LOC:
1+1=3
2+2=4
1+3=4
4+1=5
« Last Edit: June 28, 2019, 06:16 AM by tobiaskurz »
Online nvalinski
« Reply #30 on: June 28, 2019, 11:18 AM »
I hadn't thought about the heights stacking in a not really all that nice fashion... but I do see the appeal in having them in a consistent increment. I imagine the van racking probably takes up ~20 mm in between each. With racking set up to be height adjustable at maybe 50 mm, that would maximize the space with the systainer + drawer/divider being at 150/200/250/300/400/500 mm spaces (just the previously mentioned sizes + 20 mm, with the exception of the 112 height).
I think ultimately this is a change from everything being divisible by a common unit (52.5 mm for T-locs) and a move to a base height (feet+drawer) plus a common increment. Plusses and minuses for both, I suppose.
Offline SRSemenza
« Reply #31 on: June 28, 2019, 11:30 AM »
I notice that the sixth size is actually not the one in the number six spot. It is the one in the number two spot at 137mm. Though the actual heights are different from the T-Loc, the 137 is a new one within the "generality" of the Sys - I - V heights.  112 is Sys - I,  137 is a Sys- I and a 1/4, the 187 is a Sys- II etc.
I think, with the exception of the 112, 137 and 187, the front handle is really only for a pull out / slide around aid since on the taller ones it is still located near the bottom and not in the center of the height.
« Reply #32 on: June 28, 2019, 01:17 PM »
Like others, I'm trying to make some sense out of the new Systainer³ heights.
I took the combinations we're all familiar with;
1 + 1 = 3
1 + 3 = 4
2 + 2 = 4
1 + 4 = 5
3 + 3 = 5
I substituted the new height dimensions and there is not even one combination of Systainer³ heights that will yield the matching stacking height.  [sad]
Consequently, even the new Organizer M at a height of 89 mm will not produce a matching stack height with either the old Systainers or the new Systainers.  [eek]
« Reply #33 on: June 28, 2019, 03:47 PM »
Apart from the unlikelihood of Festool changing the height of MFT’s, Kapex’s and CS70’s etc etc, I cannot see any reason to change the height dimension?
There must be a reason, as they could have brought in the new design but, keep the heights the same?
If they have done this for van racking reasons, then surely two heights should be offered?
We often stack up systainers on site to help out with bench space, and when breaking sheet goods down.
Not sure whether stock up on more of the current ones, or maybe see what unfolds.
All a bit odd though eh?
Offline Svar
« Reply #34 on: June 28, 2019, 04:08 PM »
New systainer heights are at 25, 50, and 100 mm increments. Old ones are at 52.5 and 105 mm. Hence more flexibility with the new. Of course, they could have added 26.3mm to SYS1 to make 131.3mm and call it SYS1.5.
There are always compromises, but the priority is how various tools fit in the boxes to optimize internal space.
BTW you can still stack the new ones to match MFT for all practical purposes: 130+330+430+7=897mm.
Offline tobiaskurz
« Reply #35 on: June 29, 2019, 04:10 AM »
The main change in the hight system is that then number wich gets multiplied for each hight has changed drastically.
For the Classic and T-Loc SYSTAINERs all hight wehre a multiple from 52.5 mm.
SYS 1 – 2 x 52.5 = 105
SYS 2 – 3 x 52.5 = 157,5
SYS 3 – 4 x 52.5 = 210
SYS 4 – 6 x 52.5 = 315
SYS 5 – 8 x 52.5 = 420
This endet up with a System wehre many combinations reached the same hight.
For the new SYSTAINER³ the hight is always a multiple from 5 mm.
SYS³ 112 – 21 x 5 = 105
SYS³ 137 – 26 x 5 = 130
SYS³ 187 – 36 x 5 = 180
SYS³ 237 – 46 x 5 = 230
SYS³ 337 – 66 x 5 = 330
SYS³ 437 – 86 x 5 = 430
The drastically smaller common divisor from all hight has not only benefits. To get matching SYSTAINER hight you need to stack way more compared to the old system.
Offline demographic
« Reply #36 on: June 29, 2019, 07:54 AM »
Currently I have a load of T-loc boxes in my van toolsafe,  several are stacked so they work out at the same heights, can't see that working out so well with the new setup.
I do like the idea of the drawer slide capability and the front mounted handle helps that but can't help thinking they kind of just forgot about how usefull it is to have the heights the same.
Think I have a 4 and 2x2s beside it at the same height with my chopsaw on top of them and so on.
As a side note, does anyone else find Festools website to be all style and the content fairly hard to navigate/find details?
Their catalogues are the same. Nice paper, pretty photos but you get far better information from Peter Parfit and Dave Stantons Youtube stuff.
« Last Edit: June 30, 2019, 02:59 AM by demographic »
« Reply #37 on: June 29, 2019, 10:49 AM »
Yes,  they are a poster child for this.   It's really annoying when any company does pretty look, but won't just have nice clear PDF spec sheets there with all the info.  Give folks information they can print out, mark up, think about, even keep in a binder someplace.   It sucks having to make your own files, notes, etc on stuff.  Additionally their websites are massively slow, often don't fully load, and the photos of the items are often not very useful, and sometime there are no images, or they are not of the product you are looking at (different versions).  A lot of this is how companies have changed their websites for smart phones,  this just makes them useless junk far as being a website and being helpful.
Offline jimbo51
« Reply #38 on: June 29, 2019, 10:50 AM »
This is an opportunity for Woodpecker and others to create new router/drill templates to accommodate the new dimensions with greater precision/utility than the 32 mm and 1/4 inch systems currently available.
While they are at it, someone could produce a stamped steel tray to fit the Systainers. It would have depressions to hold the feet and a lip (same depth as depressions) going down in the front and back to provide rigidity. The sides would turn up and have mounting holes to match 32 mm slide systems. I think this would maximize the number of Systainers in a given vertical space.
|______|
|______|
|______|
I wonder when the discussions about matching heights of systainers and the MFT were terminated during the design team meetings? I would guess it was very early, if not at the very first meeting. This is about storing in racks where matching heights is not a major objective.
Do any of you guys in the US use the Bott system? As an amateur, I personally know only 3 small contractors. One uses a pick-up truck and the other 2 use vans without rack systems.
Offline mrB
« Reply #39 on: June 29, 2019, 11:05 AM »
We should remember here that Tanos is the systainer company. They are owned by the same group as festool, hence the integration on a level beyond any other tool manufacturer. However i can only assume that Tanos design their products for far bigger markets than tool boxes alone. I can imagine festool have little say over what Tanos decides to do.
Might have to go see Warren at the systemcontainer.co.uk sooner rather than later...
In fact Warren might be able to enlighten is on other large or larger scale users of the systainer.. I forget @Warren 's  handle is that it...?
« Reply #40 on: June 29, 2019, 12:41 PM »
Yeah, it's a clean slate verses backward compatibility issue.
Having 50mm or 100mm increments just makes sense, really it's an issue of why did they have 52.5 in the first place.   So I can see the issue of "do we clean this up, and cause breakage or do we fix an ugly from the past".
Part of my thinks they just never really planned things out very well.
Obviously sometimes its hard or just a jinx or bad messaging to call the first generation of something gen 1 from the get go, but if they hadn't made a mess of the names and just said
Systainer 1. (classic)
Systainer 2. (t-lok)
Systainer 3. (sytainer 3)
Or   Sys mk1,  Sys mk2.....
If the heights had been organized from the start they could have just had
Sys1.50,  Sys1.100,   Sys2.25,  Sys2.200,    Sys3.400. etc.
the Systainer  I , III,  IV. thing is just not good. It's back to the problem of "trade sizes",  which just seems odd for them to have done since things out of Europe are really good about getting rid of trade sizes/designations and giving them explicit numbers based on their dimensions.    (5mm thread, not #10,     x mm thickness, not gauge,   x mm^2 wire, not  AWG/Gauge/MCM,  etc).
So if in part they are just trying to clean things up, I get that, sometimes you don't know a product will take off like it will and then you have regret.   I almost wonder if they should just continue Tlok and the new ones.  Not a great answer.  I think most folks would have just asked for a short t-lock with the front handle to be added to the system.  If they wanted to beef things up, refine corners, etc, sure.
« Reply #41 on: June 29, 2019, 12:58 PM »
After some careful thought, I think this sucks.
Offline tobiaskurz
« Reply #42 on: June 29, 2019, 02:28 PM »
50 an 100 mm increments make sense when the hight from each SYSTAINER is dividable by 50 without a remainder. This is not the case and ends up wit a leek of combination possibility.
The old hight system had more sense then the new one. I understand that 52.5 mm isn't a very common measurement. They ware able to change to an 50 or even 25mm grid. The 5mm grid (5 is the biggest common divisor of all hights) seams to me as to narrow.
« Last Edit: June 29, 2019, 02:34 PM by tobiaskurz »
« Reply #43 on: June 29, 2019, 03:01 PM »
The current systainers were designed and built with multi function in mind.
The MFT SYS for example, is great for making up a bench extension or mini bench etc. If all they are worried about now, is how well they stow into a van, I really think it’s poor show, and from a company that is supposed to be innovative. Seems they are going backwards now?
« Reply #44 on: June 30, 2019, 01:34 AM »
So what is the history with systainers.  Did Tanos create them and then Festool adopted them,  did they created them for Festool and then expand, have the 2 companies been under the same parent the whole time?
As others have touched on, if Tanos drives the boat here and is focused on 3 dimensional units for the containment of smaller 3 dimensional units to be used by many, and not just for Festool and their stuff, then it becomes easy to see them not caring very much.  I wonder how long it will take Festool to convert all their stuff...if they do.  Some of the products aren't that old.
Offline demographic
« Reply #45 on: June 30, 2019, 03:15 AM »
Eh? More flexibility with the new?  Nope, sorry, the height changes is a massive fail compared to the old T-Loc boxes where two 1s made a 3 height and 2x2s made a 4 height.
I like the drawer slides and the front handle works with that drawer slide system but the few mm they have altered the heights by just lacked thought, jeez they didnt even need to think it up, just remember that it was already thought up.
1 + 1 = 3
1 + 3 = 4
2 + 2 = 4
1 + 4 = 5
3 + 3 = 5
Yup, kind of my thoughts on it.
« Reply #46 on: June 30, 2019, 05:38 AM »
This has really put a spanner in the works for a lot of people I’d imagine.
We have a good few systainers from various brands, with their main use as storage, and stacking for bench extensions and support etc.
The vans have compartments at the side doors, with basic ply shelve etc, so no big deal on van storage for me, no matter what dimension these plastic cases come in.
The workshop has home made carts that we stack systainers and cases on, so again no big deal.
But, and it’s a big but, what about the vast amount of people that have racked out their vans and workshops with custom sized cabinets, that house sliding draws etc to take the current systainers? This is a kick in the nuts for these people.
They will either have to stock up on some current spare cases, or eventually re build the cabinets, really?
Either we’re not getting the full story or this is a major boob!
The whole idea around Festool is it’s modular, Systainers are included in this as they are a modular system, that ties in with many Festool product and ideas, why on earth change it?
I guess the price of current Systainers will now soar as they become scarce?
Offline wheely
« Reply #47 on: June 30, 2019, 09:12 AM »
@Jiggy Joiner
I'm hoping the Bott van slides and Bott van drawers are the same size between uprights as the SYS-AZ drawers at 427mm, that way there are no cabinet / van racking alterations required to fit the new Systainer 3. Looking at some of the Bott and Tanos images it looks like the Bott Drawer and integrated slides are the same size.
It may be that you can open the drawer on a sys-combi too as the Bott drawers have a cutout
I guess we will find out once they start shipping. Bott suggests Vario 3 is available to order from 1 August.
Bott Vario3
« Last Edit: June 30, 2019, 09:19 AM by wheely »
Offline harry_
« Reply #48 on: June 30, 2019, 10:14 AM »
That really depends on the 'life cycle' of the van. I mean at some point we have to change out our ride, then we upfit accordingly.
As for the shop scenario, I would hope that those custom build-outs had some forethought in mind like on a 32mm system.
For me they should have just left off the backwards compat to the first gen systainers. Seems that about 1/2 of my second generation systainers have had the compatibility tabs broken off anyhow.
« Reply #49 on: June 30, 2019, 12:53 PM »
A lot of racking in a van goes into replacement van, especially if the new van is of similar spec and size.
Our vans aren’t racked for systainers like many are but, we have expensive frails and racking for carrying large sheet goods, and these aren’t cheap, so we usually remove them from older vehicles and have them fitted to replacements, providing they are in good order, which saves me a lot of money.
I know many remove their systainer racking for the same reasons.
I’ll not lose sleep over plastic cases though, as I only use them for storing and carrying tools, and stacking for bench work. I still think it’s a very strange decision though.
It’s the little, sometimes hidden ideas that set Festool apart, I just can’t see any positives in this?
Offline demographic
« Reply #50 on: June 30, 2019, 12:54 PM »
So, in short.
These new boxes will fit well into vans racking systems (yay, new sales opportunity for Festool)  but don't even play that nice with themselves.
They'll stack but try getting two stacks side by side the same height and you better be using the same combination.
I like it/detest it. Win/fail all rolled into one.
Part of the reason I'm not bowled oved by the mobile workbench is the drawer system wastes a fair bit of space and just stacking the boxes on the SYS ROLL and lifting them off when needed means I can carry a few more in a one'er. Oh and that its bleedin expensive.
Ideally Id rather have a beefed up SYS ROLL which is kind of what I'm pottering away at making mine into anyway.
Offline Euclid
« Reply #51 on: June 30, 2019, 05:34 PM »
I just stumbled across another backwards non-compatibility point...
https://www.instagram.com/p/BrqLAkjlM7h/
It seems as though a great number of little, but rather useful, points have been thought about along the way with the system (they cannot all be serendipitous) - but then forgotten about.
Pending further insights (or a curious strand of arithmetic I've not encountered), I'm still calling "dropped ball" (other sporting analogies are available...).
Offline tobiaskurz
« Reply #52 on: July 01, 2019, 02:01 AM »
The SYS 1 is tho only hight wich stays from the old system. Tow of the new SYS³ M 112 will still match the hight from the VAC SYS. Same goes for one SYS³ M 112 and the KAPEX 60.
With the T-Loc SYSTAINERs it was possible to use a SYS 3 instead of two SYS 1. This will not be possible with the new ones.
Offline mrB
« Reply #53 on: July 01, 2019, 02:21 AM »
I live in London, in a small flat, with a workshop that will undoubtedly have to move again probably sooner than later as all the industrial Estates become new homes..
My life is built around drawers and cupboards built with storage height for a sys5. Below are the combinations that can fit this height...
Sys5
Sys4 + sys1
Sys3 + sys3
Sys3 + sys1 + sys1
Sys2 + sys2 + sys1
Sys1 + sys1 + sys1 + sys1
As joiner says, i won't loose sleep over this, but it's a real shame to lose such a WONDERFUL system. And it certainly might affect some future purchase desicions as having the
£50 systainer included did help justify the cost/decision in some tool choices...
« Last Edit: July 01, 2019, 02:24 AM by mrB »
« Reply #54 on: July 01, 2019, 02:59 AM »
Hi DT, If that is the case, surely Festool should be either be looking elsewhere for storage manufacture, or asking Tanos to keep the dimension the same in a bespoke range?
If Festool and Tanos are owned by the same company, somebody must be able to pull strings?
Also, what if Festool did decide to alter the machines to fit the Systainers, which I think is probably unlikely. Then Tanos fairly quickly decide to alter the Systainers again?
I would imagine that Festool are not happy at all about this situation. It really is an unnecessary change for change’s sake, without any obvious reason, unless we’re all missing something, or we haven’t got the full story?
Personally I think the Systainers are way over priced, for what in reality is a plastic case with a lock tab and handle. So I feel for the many people who have heavily invested in these plastic cases, as the people that make them, have decided a change is needed.
It really is an odd manoeuvre don’t you think?
« Reply #55 on: July 02, 2019, 12:37 AM »
Well, the core issue is that Systainers solve a problem really well and there really isn't much in the way of alternatives.  Other systems are limited, not nice dimensions and or just not available in the USA (part that matters to some of us).  I've looked into things like "Euro norm" containers, those have a benefit of using the same footprint and being made by many companies. Problem is they too don't exist in the US for the most part, and what are sold here cost many times more than what is paid in Europe (basically depending on the size a systainer is about the same price). Some get better if your in the market to buy a few thousand of one size.  [sad]    Also Euronorms don't have the latches and such, so good for some stuff, not others.
Systainers are expensive, it's hard to put a number on if they are overpriced but I'd wager they make a healthy profit.  I was ok with the price if things stayed standard.  This is/was my issue on this subject a while back.  Basically the need for standard containers like these.  In Europe there are options, in the US, things are very limited.
You also get into the situation where there is the midi line that never had all the sizes, I think they now went from 2 to 3 sizes, odd, and it's the size that doesn't make sense.  Meanwhile the Maxi size never even got T-loc update.  I'd prefer to see that get revised too, since it's the double to the systainer so the 2 can work nicely together.
It looks like the first gen went 17 years, then the t-locs came.  That's typical, you change a few years ahead of patents expiring, this go is a bit soon on the cycle as it will be 10 years in.  You need to launch a new model a few years ahead of patents expiring so people get use to the new and thus when patent runs out no one is interested in making the old any more.  With this change it could be nearly 10 years before someone could make systainer t-loc designs and spawn a open design.  So probably won't happen.
I do wish there were other options.  But in the end, what is key is interchangeability.  If someone else comes out with something similar but it's different footprint, or doesn't connect together with these ones, there is no point.
I spend a lot of money putting all my stuff in systainers the past few months.  It is wonderful to have everything organized and it makes working so much better.  Thinking about how many thousands I spent on this effort really was something hard to grasp and caused second guessing.  It's certainly not any easier with things changing.  I really wish there was an ISO standard option, something made by multiple companies. If there was, I would have taken festool stuff out of systainers and move it all into what ever standard design there was, just like I tossed all the blow molded cases of the other brand tools I had.  But there simply wasn't options.   Now a change would be rough. Tanos knows this, so they basically know they can break things and there won't be consequences.  I can generally adjust to the heights, I just don't like having things mismatches, as it moves away from the goal.  I really don't get the removal of the side labels,  I'm not sure what all has been made better here, and how much more expensive will these now be.  What becomes of the products out there, does things live in a dual world for many years?  What about say Mafell, do they change over, make a deal to stick to old, or go some other brand which then hoses over folks who again want the interchange.  What about those who make air compressors and such.
I'm sure some of this happened before with the previous update, but I wasn't around then. I worry that companies will bail and go to other systems and then were does that leave Tanos.  Overall I guess those companies will adjust too and move on with the new system.  It's going to be really frustrating though if I want to buy say a Mafell Dual Doweler and they decide to go to a different brand of case, that's not going to work well at all.
Offline Bob D.
« Reply #56 on: July 02, 2019, 05:22 AM »
"Personally I think the Systainers are way over priced, for what in reality is a plastic case with a lock tab and handle."
I like having the Systainer for storing the tool but I too think they are a little pricey. To me it seems that it is Festool who is pulling Tanos along with all the Systainer sales bundled with their tools, but I don't know what percentage of total Systainer production the Festool segment represents.
Still, if you had a choice of purchasing a Festool without the Systainer and saving some money (or having that cash available to invest in additional Festool accessories), I wonder how many would take that option. I say that because there have been a number of people on here who have said they don't use the Systainers because they don't fit their particular situation or storage method.
If you have a dozen empty Systainers sitting around taking up space, that's roughly the equivalent of one or two tools you could add to your arsenal. You can sell them and recoup some of your money, but you won't get full value so money lost for something you never wanted but couldn't opt out of.
« Reply #57 on: July 02, 2019, 06:34 AM »
@DeformedTree Yeah I can understand the predicament across the water. It does sound strange hearing somebody outside of the UK is getting fleeced on prices too, haha! I thought it was only us that paid too much  [big grin]
I think you’re right regarding the outgoing patent, that may even explain the height increase along with a new patent. It’s a bit naughty but, will keep the bean counters happy.
@Bob D. Yes good point about being offered a tool with or without a Systainer, I must be honest, I’d prefer with, mainly to carry and protect the investment.
We have a fair few Systainers, nowhere near as many as some, and I have thought about kitting the workshop out with banks of systainers in drawers etc but,a lit of ours are just stacked along the side wall, they’re labelled but not as convenient and tidy as draws and cabinets.
Some trades I’ve noticed throw away their cases and systainers, and carry their tools and chargers in big boxes or gorilla tubs? Which I think is crazy, I see it often though.
I also hear stories of large companies buying power tools in bulk for their factory floor etc, and dumping the cases or systainers in the rubbish! [eek]
« Reply #58 on: July 02, 2019, 06:41 AM »
I was and basically still am, baffled that Tanos/Festool would chose new heights for the Systainer³ models. I mean the Systainer is part of the system in so many ways, feels kinda odd giving that up. That said, I like the front handle, I like the wider models (long cordless ratchet with battery installed), I like the padlock option ...
But I think I like the new organizers best so far, and those will not interfere with "my" system but be a stand alone solution, just like I use the Mini-L-Boxxes. I'll definitely get some of those!
Then again, I'm fortunate to be pretty much set - I have tons of T-Locs. But I also have my workshop sideboard and sysport - while I could easily adjust heights (drilled complete 32mm hole pattern rows) I can't adjust width that easily.
Personally I can easily see people buying tools without systainer, especially in a workshop-only environment. + Not everyone likes them, anyway.
So yeah, I'm resting my head fairly easy as well. :)
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #59 on: July 02, 2019, 10:15 AM »
I'd like that option... [smile]
All of my drills are kept on the shelf, sans Systainer because they're used so often. The same goes for the Vac Sys and the sleeved vacuum hoses that arrived in Systainers. That gave me an additional 6 Systainers to use for storing items, unfortunately it also forced me to make room and save all of the plastic inserts "just in case" I wanted to sell the items later.  [sad]
Offline Encoded6
« Reply #60 on: July 20, 2019, 12:21 PM »
The Tanos.de website now lists October 2019 as the availability date for the new systainers.
I called Festool USA and the customer service rep was aware of the new systainer generation but was not available of the release date in the USA (in other words, stated the release date on the Tanos website is for Europe only).
Meanwhile I was about to switch all my tools over to the systainer system... but glad I saw this post! Maybe it's good I wait a little, since I've spent way too much lately on tools  [tongue].
Now the question is - when they make the switch, will the 2nd gen sys be priced a large discount? was this done for Gen 1 (I guess this was around 2012)?
« Reply #61 on: July 21, 2019, 03:29 AM »
Hi and welcome, I guess it will go one way or the other, either the current version will get sold off at discount prices to make way for the new or, the current ones will hold their price, and possibly rise in price depending on the seller, due to short supply?
I actually like the current ones, and I'm not over keen from what I've learned about the new ones. I certainly won't be rushing out to buy any, in fact recently I've bought a few of the current version at sensible prices, or at closer to what I think a plastic case should cost.
I think for anybody that's thinking of racking out a vehicle or workshop, and buying any Festool power tools in quantity, it might be good to hold fire. As soon the tools will come in the new Systainers, and if you've already racked a system, there could be some crossover issues.
Or build racks etc, to take the new cases, and wait for them to start appearing.
Offline Aniline_Kohlrabi
« Reply #62 on: July 25, 2019, 11:47 PM »
I have about 20+ generic tanos t-loc systainers. I’m OK with missing out on the integrated slide feature, but I do like the front handles.
I am still kind of ticked off about the height discrepancy.
What I am really curious about is the new parts organizer. If it is competitive in price and function with the Sortimo T-Boxx, I may buy into it. I never used any of Tanos or Festool’s rather small, mismatched, and higher-priced assortment of small parts storage solutions. The colored bins don’t even fit in the recesses of the sortainers!
Offline Shane Holland
  • Festool Dealer
« Reply #63 on: September 18, 2019, 08:50 AM »
FWIW, I posted on the Tanos Facebook page about the Systainer³ to see if they would answer if the T-LOC was being discontinued. Their answer was that it would not be discontinued.
877-866-5688
« Reply #64 on: September 18, 2019, 10:18 PM »
(Attachment Link)
But they don't say that.    They say they will be continued, which is what manufactures do all the time when new model comes out.  The old model dies off before long though.  Just like pickups with heritage/classic edition they make for a year or 2 after the new model comes out to sell cheap.
In the end consumers figured this out years ago and know unless a company gives clear direction to their plans, their "continuation" statements just me "for the moment".
I really do hope they do keep the T-locs around.  But if this was the situation why would they call these systainer 3.   It's a 3rd gen product called 3.  If these were van rack only, it would have made more sense to call them Systainer R (rack), and keep systainer 3 for the replacement for T-locs  at some point.  But the name they gave them implies replacement.
Apple wouldn't have  iPhone, iPhone 2, iPhone 3, iPhone 4, etc   where iPhone 5 was a desktop computer and iPhone 6 is a phone again. If it was similar and lives in parallel, say a really large iPhone like thing that doesn't replace the iPhone you would call it something like iPad.
Again, love to be wrong, but I don't think anyone is going for the idea that they aren't replacing the T-locs. Might take years
Offline Euclid
« Reply #65 on: September 19, 2019, 03:00 AM »
Call me cynical, but I can't help wondering if the question was misinterpreted (unintentionally or otherwise), with the response signifiying that T-Loc - the closure mechanism - will continue. After all, the new Gen 3 series are still 'T-Loc' aren't they?
Offline ryanjg117
« Reply #66 on: September 19, 2019, 04:21 AM »
Agree. I really like the Sortimo T-Boxx but their distribution in the States is very poor. If it's priced competitively (less than the $70 T-Boxx but a premium over the DeWalt and Makita storage options) I could see gravitating to it.
Offline xedos
« Reply #67 on: September 29, 2019, 11:10 AM »
(Attachment Link)
Well, that response was either misleading, lost in translation, or very carefully worded to be pacifying because their micro site states they are going to "convert all products to systainer3"
Now, this also, could be lost in translation.  I rather suspect that t-loc as we now know it in the U.S. is going away to be replaced with Systainer3. It will take its place along side Classic in the archives.
Offline Spandex
« Reply #68 on: September 30, 2019, 05:15 PM »
Quote from: xedos link=topic=59953.msg589788#msg589788
I thought the statement about ‘converting all products’ referred to Festool moving over to the systainer3 for all their products. I.e. eventually all their tools will come in the new systainer.
« Reply #69 on: September 30, 2019, 05:51 PM »
You are correct...it was Festool stating that they would be moving their product into Systainer³ boxes.
« Reply #70 on: September 30, 2019, 11:23 PM »
Yeah, but it's all intertwined in the end.  What would be the reason to change everything over?  That said, they have things that really have nothing to do with van racks, like the cyclone, and the sys-vac and so forth. Those take a lot more effort to change.
It's hard to see t-loc's survive. To do that they would have to maintain runs for both types. Swapping around dies in the molding machine is no simple thing.  Having now to do this for twice as much stuff is less than ideal unless they add a whole new line in parallel, but at the same time the previous line would be making less because of the new cases.
It's just hard to see the t-loc's  "Systainer 2" staying around, no different than anything else.   It wouldn't be so bad if it wasn't for the new ones having de-provements and not much in the way of improvements.
I do think making a systainer line more purpose built for racks/vans is a good idea, I'm just not so keen on that being forced on everything.  Front handles serve little purpose, loss of labels on the sides is no good.
« Reply #71 on: October 01, 2019, 02:17 AM »
I agree with you 100%...I think Festool switching over to the 3rd generation Systainer will be a death knell for the 2nd generation version as Festool is without a doubt, the largest purchaser of the 2nd generation Systainer.
So get ready folks for some really weird stacking heights and a lot more amped up discussions on the FOG. [popcorn]
« Reply #72 on: October 01, 2019, 09:58 AM »
Well, I contacted Tanos a few days ago and asked them if the T-loc was going to be discontinued and replaced with the Systainer³. Here's the reply:
Thanks for your request.
At the moment we will still keep the 2nd Generation systainer® (systainer® T-Loc) and they are compatible with the 3rd Generation.
In the future 2nd Generation will be replaced but there is no date yet for replacement. We will definitely still offer them in 2020.
Mit freundlichen Grüßen/Best Regards
TANOS GmbH
« Reply #73 on: October 01, 2019, 12:08 PM »
TANOS GmbH
How long is “the moment”?
They’ll be offered “in 2020” so “the moment” is at least 4 months more.
Offline xedos
« Reply #74 on: October 01, 2019, 07:29 PM »
TANOS GmbH
Seems to me to be at odds with with what their own site says.  Perhaps it's translation, but wouldn't it be more consistent (and accurate) to say "yes, we ARE switching to Gen3 in 2020 and t-loc will be in production until that point. After that it will no longer be produced for sale"
Given that the new CT mini/midi are now taller than those they're replacing ; it appears Tanos/Festool have been contemplating this switch for some time.
« Last Edit: October 01, 2019, 07:33 PM by xedos »
« Reply #75 on: October 01, 2019, 10:17 PM »
Folks are over thinking this.   They don't know when because they don't know how long it will take inventory to run out. And gauging that gets hard because retailers will be wondering if they want to place an order for the systainer 2's for fear of being stuck with them.  So they can't project a burn rate of the systainer 2's because it won't match the historical tend.  So convergence on when the inventory runs out, when stores run out and what the calendar says can't be predicted.
Add to this companies that leverage the current systainers.  Think of all the companies that need to re-tool their products (like those who make Air Compressors in systainers).  They have to figure out what to do.  Look at say Mafell, the lid is custom on their systainers. They now have to figure out what they are going to do and the switch over.  Plus it means Tanos has to go cut tooling for all the companies they make special parts for all at the same time, not over a period of time like they have done during systainer 2 lifetime.  But even before that, all those companies have to sign on to the change, or they might say decide to switch to someone else.  Maybe those companies are currently asking to get the old model continued.
Sure the new ones are compatible, but that doesn't mean other companies who use them are going to go "oh, ok, no problem".  This is going to cost them money, it's going to cause those companies to have to discontinue products, re-tool, etc.
I'm concerned some companies will use this as a good reason to base off a different container, which then hoses those who are in systainer land.
« Reply #76 on: October 01, 2019, 10:47 PM »
Ya it is what it is...I'm just repeating words directly from the horse's mouth. Tanos will do what they do..they're German, and they're rogue, Festool will gradually transition their products to be placed in Systainer³ containers...they're German, and they're also rogue, and life will then go on.
I will continue to refinish lumber/windows/doors outside on the patio and life will be good...now about that Norton...and that Bultaco...
« Last Edit: October 02, 2019, 09:36 AM by Cheese »
Offline Spandex
« Reply #77 on: October 02, 2019, 09:48 AM »
I don't really get the drama around this.
The only real issue seems to be the stack height, and if you are one of the people who care about that (and that is only a certain group of people) then carry on buying T-Locs until they're not available from Tanos/Festool, then start buying them from eBay (because for every person who wants to stick to T-Loc, there will be many more people who want to sell old T-Locs so they can move to Systainer³ - Same thing happened with the Classic Systainer).
For everyone else, why does it matter if you have a mixture of T-Loc and Systainer³? I've moved loads of my tools to T-Loc and have cabinets full of SYS-AZ drawers, but I have no interest in stack heights so the change to Systainer³ will have no impact on me at all.
As for how long it will take to migrate over... put it like this, Tanos STILL has the Classic line on their website, and you can still buy them new from some European retailers. The idea that the original T-Loc will be phased out some time in 2020 is fanciful.
Offline xedos
« Reply #78 on: October 02, 2019, 10:26 AM »
Seems more like a healthy discussion to me.  I think it's better to get the customer's displeasure out in the open early instead of ranting after the fact.  At that point there is no going back.
That's you.  Many of us have invested in custom mobile solutions that rely on the current heights to function well.  Sure, some could be changed; but at what cost ? I suspect it's more people than they think are affected by the height change.   I'm also guessing that practically no-one in the USA is going to go for the BOTT racking system.  Tanos already has a racking system and Sortimo does too.  I'll wager nobody has ever seen a van installation of one of these systems out in the wild.
While technically correct, realistically speaking they do not offer "classic systainers" .  There are the MAXI and the older 4/6/12 SORTAINERS which were never updated to t-loc and still available.  There's also the vac pumps that come in the modified "classic" but I can't get a classic SYS1 or SYS5 to round out a collection.   And while older, dead stock might be a great find for a collector, unsupported products don't have much use for the daily user going forward.  So for all practical purposes, "classic" has been discontinued.
Offline Spandex
« Reply #79 on: October 02, 2019, 02:36 PM »
There’s already no going back. Tanos aren’t going to change anything about these products based on this discussion. The drama I’m referring to is people talking like their entire T-Loc collection is now somehow obsolete.
Well, yes. I covered that in the bit of my post you cut out. There will be people who care about stack height and they will be able to buy T-Locs either new or used for many years to come.
Classic Systainers are still all available new from retailers. Not just the maxi and sortainers. All of them. How long ago were they ‘replaced’ by T-Loc? Like I said, getting hold of T-Locs is not going to be an issue for a very very long time. People saying otherwise are exactly what I’m referring to when I talk about ‘drama’.
Offline xedos
« Reply #80 on: October 02, 2019, 02:46 PM »
OK , which dealers are advertising new classic systainers for sale ?
These guys are one of the largest most complete dealers I know of anywhere in the world and they don't carry any classic I-V.
https://www.kofferfunshop.de/en/systainer/systainer.html
Offline Svar
« Reply #82 on: October 02, 2019, 03:39 PM »
I agree on all points.
I also think front handle is a big improvement if you store your systainers on shelves, particularly high above. That was a major drawback of standard t-loc comparing to l-boxx.
Also, integrated side slot simplifies racking and saves money and space.
Offline cpw
« Reply #83 on: October 02, 2019, 03:53 PM »
The front handle and side slots are a good idea.  Having a wider variety of larger footprint systainers is a good change.
The height change and removal of card labeling slots are a step backwards.  Also, AFAIK there are no drawer/combi versions available.
Offline xedos
« Reply #84 on: October 02, 2019, 04:29 PM »
Great resource; have you ordered from him before ?
Front handle has been avaialbe for t-loc for some time as an accessory.  Not as elegant, but I don't have to have it or pay for it if I can't use or don't want it.
https://www.festoolproducts.com/festool-auxillary-handle.html?SID=e789dq5q0buroujuj2g36cnrv5
-or-
https://www.amazon.com/Festool-497856-Auxiliary-Handle-Systainer/dp/B003ZX7UJS
« Last Edit: October 02, 2019, 04:32 PM by xedos »
« Reply #85 on: October 03, 2019, 12:52 AM »
Some place selling some old thing someplace doesn't mean a thing to anyone.  Unless a manufacture is making them new currently, it's dead, that's all that matters in that regard. You don't do anything in life where you need to continue to procure something and they are no longer made.
I don't most people care so much about the new models or changes being made, everyone understands revisions,  and the sad part here is they didn't change very much. But the way Tanos has got systainers into the ecosystem of many companies and used in many different ways a change can cause a large issue.  If it means that products that exist today will no longer exist in the future because of this change, that is a big issue.  If it means some companies decide to base their products of non-systainer options, that's a problem.
I don't think the change would have been much of a  concern to folks if the heights didn't change and the side card slots stayed.  The changes were made for Van racking, which is fine if it was a parallel line, but since it comes at a break in compatibility with the old, it's bad.   Yes most of what happens with the boxes is compatible, much like how T-loc's are largely compatibly with Classics, but folks are generally not going to want a mix.
If the new ones added a front handle, and added side rail features, but everything else stay'd the same, I doubt much of anyone would have an issue.  Sure they would look a bit different, but that's a minor concern.
This is always going to be an issue when people spend a lot of money on and build around a proprietary product.  I think Tanos could have planned the heights of systainers originally much better, why they now changed it is confusing.  They could have made heights that fit in with the old ones (half sizes).
Offline Svar
« Reply #86 on: October 03, 2019, 01:34 AM »
The point made earlier was that classic systainers are still easily available from a number of retailers some 10 years after t-loc introduction. Tanos is still making them now.
« Last Edit: October 03, 2019, 11:14 AM by Svar »
Offline Spandex
« Reply #87 on: October 03, 2019, 03:04 AM »
Exactly. People are acting like having a large ‘investment’ in T-Loc is suddenly a huge issue, when clearly it’s not.
If anyone out there needs stack heights to remain the same, their current T-Loc collecting isn’t going to suddenly explode, and any new tools they buy can easily be moved to T-Loc if needed (there will be people willing to swap if someone doesn’t want to buy new, just as there are now with Classic and T-Loc).
Or, you just swap your new tool into a T-Loc you already own, but don’t need to take on site and use in certain height stacks.
Everything else about the new Systainers is compatible, so having a mixture will have absolutely zero effect on you as long as you manage the stacking height issue. If having non-matching systainers DOES affect you, that’s something you need to discuss with a psychologist, not Tanos ;)
And finally, you do realise that the vast majority of people will already have a random mix of T-Loc, classic systainer, L-Boxx, Toughbox, whatever? Most people think having a collection of matching systainers is a bit mad. Being nerdy and passionate about something is fine, but you need to understand that most people aren’t. This change is going to have absolutely no negative impact on Tanos ability to sell systainers to other brands - in fact, it should help. Van racking is pretty common in Europe, but the only Systainer racks I’ve seen have been custom made ones posted on here. But Sortimo is a relatively common sight when you walk past an open van. Utility companies kit out their vans in bulk with it. Tanos currently can’t even begin to compete with Sortimo, but clearly they want to.
« Last Edit: October 03, 2019, 03:07 AM by Spandex »
Offline Vladiator
« Reply #88 on: November 23, 2019, 08:43 AM »
I understand that some T-LOC owners are freaking out, thinking the world is about to end.
SYSTAINER³ offers only 3 major improvements: front carry handle, integrated racking slides, and slightly bigger heights.
You can get the carry handle for T-LOC SYS-1 and SYS2, so that takes care of it. Will you carry next 3 new systainer  sizes by the side handle? Nope... the only reason the handle is there is to lift it up and get it out of the van racking system, since it's missing slides. So for anyone who is not investing in the van racking system, third generation update is pretty useless.
I have about 20 systainers all in T-LOC size and i'm not planning to upgrade anything to new ones.
As far as bigger heights are concerned, yes maybe that's an improvement for some people who aren't obsessed about stacking equal heights between second and third generations. I tried to adapt storing non-festool tools in t-loc systainer and I wasn't happy with how things were working out. Milwaukee M18 impact driver can't fit into a SYS1 with the belt hook attached, so each time I needed to take off the belt hook before storing the tool nicely.  Milwaukee angle grinder could only fit in a SYS2. Milwaukee M18 gun could only fit in a SYS 1 or 2 diagonally and it had to be completely disassembled, with push rod unscrewed and removed from the gear assembly. So in terms of size and adapting T-LOC's to different tools, second generation of systainers kind of sucks, maybe third one would be better. If i could fit a tool that resides in T-LOC 2 in a third version sys1, there would be some advantages of newer higher sizes. Having broken some systainers, I think they are only designed for the shop. I also have a Milwaukee Packout and it's much more durable storage solution at a third of the price if you consider how much storage space you are getting.
Offline Spandex
« Reply #89 on: November 23, 2019, 09:58 AM »
Completely agree that the updates aren’t of benefit to people who aren’t interested in some kind of racking - although plenty of people on here are very interested in workshop racking, so I would imagine the integrated slides and front handle are just as useful there as they are in a van.
But on the flip side, the front handle and integrated slides aren’t a negative for people who won’t use them either. The only downside to the new design is the stacking heights, and as I’ve said, this is so easy to work around that it’s not going to have any real-world impact on anyone who currently makes use of it.
« Reply #90 on: November 23, 2019, 07:29 PM »
How many people will have classics? I technically have one because Maxi was never updated.  In a market like the US Festool wasn't very big by the time they switched to T-loc.   I think I have around 50 systainers, only odd ball is the one maxi.
I have no other brands because well, most tools don't come with any case, so I have to put them in something. A lot of the brand cases that exist in the Europe don't exist here.   Dewalt and Milwaukee each have some sort of system, but I've never seen them in a store or anyplace. In general sounds like the dewalts are complete junk.  When I buy non festool tools and other items, I buy systainers and set them up for the tools.  Mixing different brand cases wouldn't work as they general are different form factors.  I did  look into a system from a competitor to Tanos, but they don't ship to the US.
This all spins back to folks understanding that folks use such containers differently. If your primary focus for them is consistent storage, maximizing that aspect of things, changes do matter.  If your need is Van usage then things will be different than the storage person.  Thus why just thinking people will just have mix of brands and types doesn't fly for a lot of folks because that's the very thing they set up not to have.  It's why all my blow molded cases tools came in ended up in the recycling bin. The goal is not to have a tool in a case, it's to have the same form factor case for all the tools and other items.
Ideally there would be an ISO standard for such containers. The basic form factor is a quasi standard (Euro-norm), but the other aspects of the design like the latches and such are not.
Obviously people will transition over to the new ones. That doesn't change the matter that for a lot of folks how they get used, they are very much a down grade.  Things like the loss of the side label is a big deal for as it a key to my usage. I make labels for all 3 sides.
If you don't understand why people have issue with the new ones, or some make a big deal of it, just stop and realize not everyone uses them the same way. Things like the height changes are annoying to me, but not a deal breaker, but I absolutely understand why it is a big deal for others.  Given a choice I'd prefer them not have change the heights.
And yes changes to them do impact the investment in what you have. Since you invest in items like Systainers to have the stability in design and to be able to keep buying the same thing. Now when things change you loose a core part of what people are going for. Some folks really do want to be able to buy the exact same thing any time they want for the rest of their lives.  If you want to see a similar example of this, look what has happened with Rubbermaid discontinuing the rubbermaid roughneck totes.   Rubbermaid made the exact same product (ignoring color) for decades, I think I read they go back to at least the 1970s.  They were never super great, the part that made them great was that you could just keep buying the same product forever. People built the way the use them in their business around them, they organized their home storage around them and only them.  A lot of stuff was built around that product because it never change in design.  Then a few years ago they discontinued them, the fallout and anger from this has been massive.  I had over a 100 of them some folks and businesses vastly more. It's not like you can just change to something else and nothing else has that stability in design.  It wasn't about being a great design, it was about always being the same design. They were a pretty poor design, and expensive for what they were. But being able to run to the corner store and pick up a couple more year after year and they integrate in with what you have perfectly was the key.
A systainer is not a perfect design, but what it had is consistency.  Are the new ones a massive change, no, not really.  But they are design changes to target a completely different application. When the changes don't benefit those who will continue to use them the same way they have, that is where you get issues.
Offline Spandex
Re: SYSTAINER³ available from September
« Reply #91 on: November 24, 2019, 05:51 AM »
I don’t think we actually disagree on the fundamental point.
I agree that the changes aren’t massive. I agree that they’ve done it to target a different market. What I disagree on slightly is the ‘issue’ with them doing it. Yes, there will be people who are annoyed by this because the changes don’t benefit them, but they will be a minority and they will be able to carry on with the standard t-loc for the rest of their lives without issue.
Given that standard t-locks will be available one way or another for many many years to come, and given that you could easily sell any systainer3 you got with a tool and buy an equivalent old t-loc (and probably make a small profit), how are these new systainers going to cause a single issue for people who only want t-locs in their stack?
That’s the point. I’m not trying to persuade people that the new design isn’t a problem for them. I’m not trying to persuade them they’re wrong. I’m trying to point out it is a completely avoidable problem.
Offline yetihunter
« Reply #92 on: November 24, 2019, 11:10 PM »
Remember when there was a twenty page collection of rants over imperial scales?
Nevermind that nobody uses scales on those kinds of tools...
Foggers are afraid of change.  The new systainers look great.
Offline Darius
« Reply #93 on: February 17, 2020, 11:55 PM »
It seems that tanos is in partnership with bott van racking systems. New systainers are built to fit bott system, they are specially made to fit drawer racking system. Cut outs are based on bott system. Why they would do that doesn’t make much sense since outside of Europe bott systems are not really available. Same t-loc just different corners and three hinges on a back instead of two, which will help from twisting on uneven surface. That they changed the sizing, yeah sucks but that’s all to fit bott racking system in vans.
Offline Gregor
« Reply #94 on: February 18, 2020, 07:08 PM »
'Look great' is pointless when they're incompatible with what you already have. As it happens to be with the sort boxes:
Classic colored: 49mm grid, 71mm height
SORT/3 (2015): 60mm grid and 71mm height
Systainer³ (2020): 50mm grid, 69mm height
Having two types of insert boxes for small parts already being a huge annoyance (as it gets in the way constantly since you often can't simply move an insert box from one container to the other), turning that into three incompatible insert boxes is that high disregard of the customer that this figurative middle finger is illuminated and blinking. I for one have lost my will to give Festool/Tanos any more money for everything even remotely related to 'sort' they might come up with and will switch to a supplier (like Auer) that doesn't introduce incompatible changes to their boxes every some years because whynot.
Offline Maťo
« Reply #95 on: February 19, 2020, 05:45 AM »
You may want to check out ESSVE essbox system. For practicality superior to TANOS, AUER or any other similar system I know of. Transparent boxes and each box can (does not need to!) be closed separately with a lid. Very well thought out system.
Offline mrB
« Reply #96 on: February 19, 2020, 06:38 AM »
Just looked at the Essve Essbox system on YouTube. Don’t even understand how they’re comparable to tanos & Auer systems? As far as I see they’re not.
As for comments that the new Systainers aren’t even an issue because one can just sell the new and buy an old. . . Lol - you’ve got more time on your hands than I. That is one pita solution.
I don’t think anyone has blown up too much about this size change. Just commented on the inconvenience of the change. How about letting those comments stand rather than invalidating them with such drivel.
Offline Svar
« Reply #97 on: February 19, 2020, 10:54 AM »
That ESSVE essbox system looks good. Great alternative to Tanos, Auer, and others with some refinements.
« Reply #98 on: February 19, 2020, 11:30 AM »
What’s interesting about Essve’s storage system is that they’re mainly a fastener/hardware supplier and they wanted a more functional way to package the supplies. So, it’s most practical if you are buying supplies from them, already packed into their handy boxes.
Offline mrB
« Reply #99 on: February 19, 2020, 12:05 PM »
Can someone link me whatever I’m missing in the Essve system that makes them comparable. All I’m seeing is nice fixings boxes, nothing that can hold tools. .
Offline Maťo
« Reply #100 on: February 19, 2020, 12:33 PM »
I was comparing ESSVE Essboxes to new TANOS/FESTOOL Organizers. ESSVE doesn't make interlockable boxes comparable to Systainers. As for assortment boxes, Essbox system is ultimate IMO.
Offline Spandex
« Reply #101 on: February 19, 2020, 02:09 PM »
How many new tools in systainers do you buy a year that selling them on would be such a chore?
Because that’s the only way you’ll end up with an unwanted systainer3, isn’t it? When buying a new Festool tool?
Offline SRSemenza
« Reply #102 on: February 19, 2020, 02:27 PM »
There is an Essbox Systainer with interior fitment to hold the brands hardware boxes.
 I can't make the link work ..................................  search for Essbox Systainer.
« Last Edit: February 19, 2020, 02:31 PM by SRSemenza »
Offline Maťo
« Reply #103 on: February 19, 2020, 03:57 PM »
This new XXL sized Systainer came as big surprise to me when I last checked Festool site. Haven't seen any comments on it on this forum, no one noticed yet?
Offline mrB
« Reply #104 on: February 19, 2020, 04:56 PM »
Ah, I see, my mis understanding.
And given seths comment on systainers to hold the boxes I can understand that preference!
Offline FestitaMakool
« Reply #105 on: February 20, 2020, 10:47 AM »
There is an insert that is made for Tanos/Festool Systainers wich are compatible with ESSVE boxes. I didn’t think that ESSVE was available I’m the US.
The boxes are as mentioned nice, in that you can chose to remove the lid and place it under the box itself, and then place the box in the case. Should you choose to bring just one box the lid will follow. I have decided to choose the new Festool system for my “inside” screws and the ESSVE for “outside” screws. I can get a Systainer insert for the ESSVE boxes if I like.
« Reply #106 on: February 20, 2020, 11:06 AM »
Essbox Systainer insert
https://www.essve.com/essvecom/en/products/storage/essbox/systainer/essbox-systainer-insert-1
Offline Coen
« Reply #107 on: February 20, 2020, 06:15 PM »
Nice photoshop
« Reply #108 on: February 20, 2020, 06:34 PM »
It is out, in Europe. Most likely it is primarily made for the new polishing machines (The new machines needed a longer NEW systainer) They may also make a couple of even longer ones, so we don’t need to build plywood cases for KA-KS, UG wings and other long things.. [big grin]
Offline SRSemenza
« Reply #109 on: February 20, 2020, 07:04 PM »
Nice photoshop
No, it is real.
Offline Coen
« Reply #110 on: February 20, 2020, 08:53 PM »
Nice photoshop
No, it is real.
 [eek]
You are right.
https://www.festool.nl/producten/systainer-en-transportsystemen/systainer/204851---sys3-xxl-337#Overzicht
Offline phase3
« Reply #111 on: February 26, 2020, 10:02 PM »
Hi. 3rd post here.
Any word on availability of the rail system for the new recess to slide onto? I see that Bott is making something for vehicles. I Googled like crazy but haven't seen an image of it. Seems to have a way to catch the Sys3 on that back lower lip. I'm not seeing anything yet for using in workshop storage. Maybe I'm over thinking it (per usual), and it's simply expected that I'd make some ~1cm x 1cm wood/MFT rails for that slot?
Pre-apology: I'm gonna gratuitously add a photo to get used to adding images, even though you all know that recess I'm talking about.
311323-0
« Reply #112 on: February 26, 2020, 10:52 PM »
The rail system you're talking about is currently available for vehicle racking, I believe it's not yet available and doubt it will even be offered for in-shop racking as that's not what Bott does. For in-shop racking, Bott offers some beautiful metal stuff that's very similar to Lista but priced at an even higher level.
You may have to fab your own or some enterprising individual out there may decide to offer it.
Offline phase3
« Reply #113 on: February 26, 2020, 11:07 PM »
Good info. Thank you!!
Offline Darius
« Reply #114 on: February 27, 2020, 12:59 AM »
New Systainer was specifically made to fit bott racking system. It’s crazy popular in Europe, and if I’m correct tanos partnered up with bott then creating new systainer. That’s why they all have new heights.
Hi. 3rd post here.
(Attachment Link)
Offline rylim
« Reply #115 on: March 01, 2020, 08:46 PM »
Does anyone have any idea when the Systainer 3 will available in NAINA? Also, would all the new tool kits come with updated Systainer 3 box?
Besides that, would consumable kits be getting systainer 3 as well?
Sale: Festool 498899 Assorted Domino Beech Tenons Set with Cutter Bits (5-Bits)- New - $265
  • Festool Dealer
« Reply #116 on: March 01, 2020, 09:09 PM »
Festool USA is slowly transitioning tools to the Systainer³. So far only the ETS 125 REQ has transitioned and we now have inventory of this sander in the Sys³. It looks like this transition will be quite slow over the next year.
Festool USA has also indicated that they have no intention of introducing any empty Systainer³ in 2020. Of course, this may change but it's the latest info I have to share.
877-866-5688
  • Festool Dealer
« Reply #117 on: March 05, 2020, 02:00 PM »
Now available in Systainer³ M 187, order now:
ETS EC 150/3
ETS EC 150/5
DTS 400
RTS 400
877-866-5688
Offline tsercitpo
« Reply #118 on: March 05, 2020, 02:43 PM »
Shane, does that include the Systainer3 Organizers too?
  • Festool Dealer
« Reply #119 on: March 05, 2020, 02:46 PM »
@tsercitpo, welcome to the forum. Festool USA has indicated that the only Systainer³ we will see during 2020 will be the ones that come with tools. No other Systainer³ products will be available this year. Again, that's the latest word and is always subject to change I suppose.
877-866-5688
Offline tsercitpo
« Reply #120 on: March 05, 2020, 02:56 PM »
Thanks for the quick reply, Shane. Please convey my disappointment to big green...
  • Festool Dealer
« Reply #121 on: March 05, 2020, 02:57 PM »
@Festool USA
They monitor the forum, so you can tag them using the format above to make sure they see your comment(s).
877-866-5688
Offline tsercitpo
« Reply #122 on: March 05, 2020, 03:10 PM »
@Festool USA Please make the Systainer³ Organizer available in the US in 2020!
Offline Coen
« Reply #123 on: March 05, 2020, 05:13 PM »
So Festool is big with the "ecosystem" but in the US you cannot buy major parts of the system for a year? That doesn't make any sense.  [unsure]
Offline mschmidt10k
« Reply #124 on: March 07, 2020, 12:35 AM »
+1 on this. Please get them stateside asap!
Offline rylim
« Reply #125 on: March 08, 2020, 10:13 AM »
Ughh. Why NAINA always so slow...
By the way, thanks for letting me know
« Reply #126 on: March 08, 2020, 11:12 AM »
Actually, inventory is the Achilles heel. Suppose FT USA is doing the same as here, old inventory out first before introducing SYS3. It is the same told here, only a few tools in the beginning and a slow transfer during 2020. There may be some empty SYS3 available here first, but I suppose those also will find its way over during the year. Tools in “old” Systainers will probably be sold before replacing successfully with new Systainers.
Offline phase3
« Reply #127 on: March 12, 2020, 08:25 AM »
I'll chime in that because I'm completely new to Festool, and actually it's especially because I'm new to Festool, the delay in Sys3 for USA makes me a little bummed. I'm buying Festools relatively rapidly as I'm ramping up my (very enjoyable) new job function, and as each tool comes in the older format Systainer, in the back of my mind I'm thinking of them as even a bit more expensive, because I know I'd actually prefer to invest in the newer racking of the Sys3 when those are available.
I do recognize it's just unfortunate timing on my part.
I now have about 10 "last-model" Systainers from the tools I've bought since about November last year, plus one Classic style because my amazingly fantastic local hardware store salesman handed me a dusty old LR 32 demo kit they'd stopped using. I'm appreciating how efficiently these things let me move my tools from job site back home every day, so I'd also ideally switch the other non-Systainer tools from the pile of random bags & blow-molded cases to Systainers. I'm also now sick of stacking & unstacking them, so I want to make some cabinets with drawers. Just as folks commented in other threads I'm finding that stacking & unstacking gets old pretty quick! I have in mind building some rolling storage cabinets with MFT tops, same height as my MFT/3, having the more efficient-looking Bott style rails as their racking, which also would let me get to a bottom drawer in a combo Systainer without pulling the whole thing out. I guess I'll be buying now about 10 current type Tanos/Festool drawers, then hoping to change those to rails later if I have the funds to switch to Sys3. Plus probably one in the base of my MW 1000 because as soon as I put that together last night, it was really awkward sliding the bottom Systainer in & out.
On the plus side, it looks like the Sys3 are being sold in sets, and I think they're discounted. Any word on whether the USA will get a deal when they arrive?
Off-topic sign-off: I hope everyone stays healthy. My kids are being told their colleges are switching to online-only, sports & trips are cancelled, and one of my kids needs to move back home today because the campus is shutting down.
Also my tool budget is probably about to step-function to zero as the food budget explodes, so my gripes about Sys3 not being here yet is probably all moot.  [unsure]
« Reply #128 on: March 12, 2020, 12:13 PM »
I’m kind of in the same boat. Recently, within half a year shifting to Festool, selling a lot of my old tools. I even like the old two latch Systainers, as they feel more substantial than T-Lock ones. Especially for heavier loads. The new Sys3 seems more rigid, apart from T-Lock.
I did buy some Festool drawers as I was also tired of stacking and restacking. One did go to the bottom of the MW1000, and I also bought a second drawer that fits the MW1000. It will constrict max possible sys in the MW1000 but it is very ergonomic with two more drawers. So I’ll happily advise you to do so.
Offline phase3
« Reply #129 on: March 12, 2020, 08:45 PM »
You've brought up something I hadn't fully realized. I agree the 2-latch one I have does seem thicker and generally more sturdy than the more recent version. The clips require an inconvenient amount of force to lock into place and unlock, though. At least on mine.
LOL -- I'm sure you're right. The Festools aren't perfect, but more is usually better. Hehe.
« Reply #130 on: March 12, 2020, 09:30 PM »
That’s always been an issue since day 1. Some use sandpaper to fine tune the latches. I’ve tried both a chisel and a scalpel to fine tune mine.
A great Systainer, very sturdy/strong but clunky to use.
« Reply #131 on: March 13, 2020, 03:20 PM »
Here’s my MW1000 with the two extra drawers. The good thing about these drawers is that complete with drawer slides and tray in a pack of 5 the cost isn’t too bad. Buying just the drawer sliders is not cheap, and the materials and labour when making your own comes in also. They also don’t mind wich systainer you’ll load, even Makita’s thrives in them.
(Never mind the Traxxas UDR.. it’s drying out after wash down [wink])
Offline phase3
« Reply #132 on: March 14, 2020, 05:41 PM »
Thanks, Cheese. I'll give that a try. It's a freebie, plus its contents, so I'm certainly not complaining about it!
Haaaahahaha! That looks great. Complete with the truck on top. I guess that'll get its own SYSTAINER³ XXL when those are available.  [eek]
On a different note, on most sizes the new front handles sort of interfere with using the T-Loc. I hope I haven't missed someone else mentioning that. I'm sorry if I have.
311978-0
« Reply #133 on: March 14, 2020, 06:31 PM »
(Attachment Link)
Haha.. you’re not far out! [big grin] - But thinking more of my new and older scale Tamiya’s.. there’s a lot of work in them, even paintwork - like a 1:1 car.. They will be very happy to be transported in one of the new SYS3 XXL  [wink] - maybe my Traxxas TRX4’s too..
The new XXL is very interesting to build inserts for, there’s tools that are just too long for most tool caddy’s IE; Japanese pull saws, levels and so forth (I really don’t like banging tools around [embarassed]) Hand tools or electric, I take care of them.
Edit: Having shortly handled the SYS3 - I too thought the handle in front got in the way.. it is a bit “flap, clack, rattle” thingy. There’s a catch to lock it, but hard to fasten and unfasten again. I guess those that don’t need it will remove it.
« Last Edit: March 14, 2020, 06:41 PM by FestitaMakool »
Offline nicholam77
« Reply #134 on: March 14, 2020, 07:12 PM »
Are the new handles easily removable?
« Reply #135 on: March 14, 2020, 07:39 PM »
I have one of the new SYS ORG M, and it is doable, but the handle in the way it is attached is quite rigid - so it’s not easy off - easy on. It feels secure, but it is snapped on, in one piece.
Offline phase3
« Reply #136 on: March 15, 2020, 10:32 AM »
Do the handles lock in a straight outward position too, or only in the downward position?
« Reply #137 on: March 15, 2020, 11:41 AM »
Only in the downward position. So if you have a van full of stacked Systainers mixed in with Systainer³ items, the front handle just flops around and slaps the Systainer as you go around corners and roll over bumps...Nice.  [doh]
Online Peter Halle
« Reply #138 on: March 15, 2020, 11:56 AM »
I guess driving styles might come into play.  I can’t see this as an issue, but others will certainly have their doubts and opinions.
Offline Gregor
« Reply #139 on: March 15, 2020, 01:49 PM »
Possibly the quality of the local streets plays a role too, thus suspecting bad habits of reckless drivers... might be a bit off the mark.
« Reply #140 on: March 15, 2020, 05:23 PM »
I drive Land Rover and Mini, sooo.. I will probably not say anything about fast cornering and uneven “roads” 🙄 - with my trailers following behind 🤓
Offline Coen
« Reply #141 on: March 27, 2020, 10:43 AM »
Another thing on the change in height;
You can make the MFT height with a SYS(-TL) 2 + the equivalent of 7 Sys1's. That ends up being 899.5mm (the MFT being 900) == the same. Those 7 Sys1's can be anything from actually 7x1, or a 5 + 4. Or 2+2+5 or ....
But with the new system you can never get as close to 900 as the old system.
Closest I can come up with is a set of 3 Systainer3's then you get to 897mm;
eg; 137+337+437. Replace '7' with '0', add it all up and add one set of feet (7mm); 130+330+430+7=897
This means the choice of Systainers is way more restrictive. You can only use 3, and those three must add up. You cannot replace one big Systainer for two smaller ones.
You can however use different combos. Eg 137+337+437 or 237+237+437 or 237+337+337
Offline edwarmr
« Reply #142 on: March 27, 2020, 01:31 PM »
I think I found a combo that works with the new Systainers:
Systainer³ SYS3 M 337 (337-7)=330
Systainer³ SYS3 M 137 (137-7)=130
Systainer³ SYS3 M 112 Feet Included
Systainer³ Organizer SYS3 ORG M 89 (89-7)=82
Total=900
Offline Coen
« Reply #143 on: March 27, 2020, 04:38 PM »
Total=900
Haha nice one. Somehow I thought the Organizers couldn't be locked together.  [unsure]
Just bought two steel cases with boxes for screws based on that assumption  [eek]
Offline tsercitpo
« Reply #144 on: March 27, 2020, 05:38 PM »
FYI I was able to order from Axminster successfully. I half expected the order to be canceled or to be delayed, but to my surprise and delight it only took 3 days from ordering to delivery from the UK to US (midwest)
Offline mrB
« Reply #145 on: April 02, 2020, 11:49 PM »
Just ordered my first festool that will come in a  bulls”:t systainer with the ‘wrong’ height. It really does take a little something off the beauty of systainers for me. And by knock on effect the value of spending on festool. .
I’ve had my small city flat/apartment kitted out for storing lots of systainers for nearly a decade now (makes owning lots of tools possible for me)
But in more recent times they’ve also become my portable work benches for lots of jobs, especially installs. With the 3D printed systainer feet kits available these days I have 4 systainer worktops. Two identical pairs, one of each type can be seen below. One is a larger MFT type, the other just a piece of ply in the sys footprint that can have other lengths of 18mm material attached as needed (the MFT top is also 2X18mm in total height)
It really does work a treat and takes so little space or effort to store, transport and setup. Additionally they are great step stools on the job as well.
If you’re new to this concept check out the products available on the ‘feskit’ web page to get a better idea of what’s going on.
Anyway, still hating on the new systainer heights :)
« Last Edit: April 03, 2020, 12:49 AM by mrB »
« Reply #146 on: April 03, 2020, 01:21 AM »
@mrB   Are those Metabo boxes the same height as Systainers?
Offline mrB
« Reply #147 on: April 03, 2020, 01:53 AM »
Yes they are the same size as the original T-loc systainers. Available in sys II, III, IV as far as I’ve seen.
They’re definitely the best (2nd to T-Loc) systainers available. The single latch is way easier and quicker than the 4 latches of the ‘Classic sys’ variants, although it doesn’t allow you to open half way down a stack like a T-loc. They’re also notably sturdier than Tanos systainers.
I prefer T-loc latches by far, but for the price these metabo ones are a winner (i paid >£20 each for these two, new and delivered)
« Last Edit: April 03, 2020, 01:55 AM by mrB »
Offline sustad
« Reply #148 on: April 03, 2020, 12:39 PM »
I second everything Mr b says on the topic.
Offline mrB
« Reply #149 on: April 03, 2020, 01:29 PM »
It’s not even the fact that the heights are different, it’s that they’re not even system compatible with them selves like the original T-Locs are.
The height of my work tops in the photo above is 2x SYS4. But this height can also be achieved with combo of Sys. . .
4+4
4+2+2
4+3+1
2+2+2+2
3+2+2+1
3+3+1+1
3+3+3
1+1+1+1+1+1
3+1+1+1+1
It barely matters what tools I bring to the job, I’ll have some good options for worktop height.  It’s so good as a system but they ruined it!
Over time tools and systainers will break, and newcomers will have new style Sys3,  and this system will be lost. . Why? Because of some racking system no one ever heard of?
I know I’ve been criticised here before for blowing it out of proportion, and I admit it’s not the end of the world. . . But it sure feels like a massive waste of a great thing.
« Reply #150 on: April 03, 2020, 02:08 PM »
@mrB
- You have a point, I agree. Van racking seems to take over the old “system”.
I really see the point of racking compatibility, but (FT!) don’t forget the original system. It can be solved by adding SYS3 systainers that complies with old and at least a couple of those will solve height issues. There can be systainers that are NOT compatible with BOTT.
In addition: CMS is also obsolete..
Forecast based economics ruin brands and products.. I suspect there are new forces (I don’t know) running Festool. Financial focused I suspect, not marketing in collaboration with creative engineers...
Offline Gregor
« Reply #151 on: April 03, 2020, 07:56 PM »
@mrB
Given that the heights are completely incompatible... I suspect the latter should be read as past tense, that ship seems to have sailed. *sigh*
« Last Edit: April 03, 2020, 08:15 PM by Gregor »
Offline mino
« Reply #152 on: April 18, 2020, 05:27 AM »
The T-Loc was designed as a direct "version 2/tuning" of the concept and so mostly displaced the Classic. But still the Classic line SKUs which did not get a functional replacement do soldier on till today like the SYS-SORTs.
Sys3 is not so. It is a compatible-but-not-a-replacement type for a product line. To me it is a side-step, not a functional replacement as it had to forego the LEGO-like height system to get into the vehicle system.
SYS3 is here to stay. And Festool will globally push to have it included by default with new tools - if for anything then for consistency and the new "fancy" thing.
But there is nothing preventing Festool (not mention TANOS) to carry the classic T-Loc line as a parallel system-storage line.
And this is what we should all tell to our Festool reps loud and clear:
"SYS3 are nice, but they are not a replacement of T-Locs.
If you do not want to lose a big part of your customer base, you need to carry both lines long term. 20 years style long term. If you do not, the community will migrate to the Makpacks and Metalocs of the world which will have a superior system on their hands."
/I know this is past the time, but should be said:/
I am totally convinced that TTS messed up in underestimating the value of the height system to their heavy users/evangelizers.
As can be seen on this thread, the height system is a go/no-go for many big adopters and the "masses" do not care so there is no real benefit giving them the vehicle-compatibility. For many it is a reason why they choose a Festool in place of a Makita or a Metabo.
They really should have talked about this with Bott and have Bott adapt/support the TANOS height system OR agree to make a few "special-Bott-aligned" sizes which would have been *in addition* to the standard 52,5 mm module ones.
I think e.g. the 130(7) and the 230(7) would be usable also for tools (at times allowing to avoid bigger SYS-2 and SYS-4 respectively) while the 330(7) and 430(7) are close-enough to SYS-4/5 they would be mostly not needed as the TANOS sizes would be close-enough.
Then the Organizes REALLY should have been 87.5(+feet) to align with the 5/6*105 module the SORTAINER is using so that 3 Organizes will be 3x87.5 = 262.5mm = 2,5x52.5 => the same as a COMBI2.
(Ref: The shelf modules of a SYS-SORT4/3 are 87.5 and the "inactive" height of it is exactly 52.5mm, so you can make a SYS-SORT"7"/6 with 6 shelfs and height of 11*52,5 modules by taking apart a couple SYS-SORTS. I am convinced this is why TANOS originally chose 105mm => it is cleanly divisible by 3 and so you can make 2/3 in addition to the 52,5 1/2 sizes which will end up with rational numbers as dimensions instead of 3,3333...)
Such approach would have allowed also the "Bott folks" to choose the smaller SYS-1/SYS-3 when they would value the TANOS LEGO system above in-vehicle efficiency or go with the Bott-optimized 130/230(maybe-330) heights when otherwise.
But well, what is borked is borked. Lets go for some damage control then.[cool]
AGC 18(@AGC 125 flange), BHC 18, C 12, CTM 36, DRC 18/4, PSC 420, RS 200, TSC 55
Narex: EDH 82, EFH 36(fixed@LR32), EVP 13 H-2CA
My Precious FS/2: 376, 376, 376 holy, 632, 1016 holy, 2520
Offline Coen
« Reply #153 on: April 18, 2020, 10:43 AM »
4+4
4+2+2
4+3+1
2+2+2+2
3+2+2+1
3+3+1+1
3+3+3
1+1+1+1+1+1
3+1+1+1+1
Given plenty of time I guess you can probably trade them for someone who goes all-in on the new system. Classic Systainers are still available too, I guess the T-loc's will stay around too.
I still don't understand why they had to change the heights for that racking system of Bott. They didn't have to conform to L-boxx width either.
Offline mrB
« Reply #154 on: April 18, 2020, 11:20 AM »
Yes I am sure there will be regular T-Locs around for a while, but it’s way less convenient and cost effective to sell new Systainers and buy old. My TID 18 just came in the new Sys3 and having seen new prices on eBay and just watched a Sys3 (from a TID 18) sell for £32. . . After postage, eBay fees and the hassle. . It’s really not worth it in my opinion.
Someone previously questioned my annoyance saying I “can just buy old Systainers” and “how many new tools do I buy a year” but that’s not overly relevant. The tools used to come in compatible Systainers and that was part of the value. Now that value is lessened. Granted they still stack and Lock and that’s still convenient, but it’s notably less useful for me.
Often in the past I’d buy a tool for a specific job that I don’t want to keep permanently. I’d use it, keep it in great condition and sell it a month later without the T-loc. I’d get about 80% of my investment back and a ‘free’ t-loc. I‘ll be less inclined to do that with the new ones.
I’m moaning mostly because I have the time on lock down, but also because I’ve made Systainers a huge part of my life and this inexplicable alteration really damages that for no reason I can see. BOTT never sold Systainers before, and don’t seem to currently sell the Systainer racking the Sys3 was designed for (from my half arsed investigation). Just can’t see why the heights needed to change. And from a company that claims your investment with them is solid for ten years of spare parts, has MFT, CMS and mitre saws that are all height compatible with the old Systainer system. . . I just can’t imagine why they changed it? I’d really LOVE to know.
Offline Spandex
« Reply #155 on: April 18, 2020, 11:31 AM »
If you have a large number of systainers then it’s also presumably possible to swap any new Sys3s that you get for systainers that never leave the home/workshop. That allows you to ensure that systainer stacks used on jobs (where the heights may be an issue) are all old t-locs.
« Reply #156 on: April 18, 2020, 11:37 AM »
The racking is Bott Vario 3. This is the best shot I could find on how the Systainers fit into the racking.
Offline mrB
« Reply #157 on: April 18, 2020, 11:56 AM »
Yes you are correct. I have 3 or 4 Systainers that never leave the house. But they’re all sys4 with paints, stains, glues etc etc. Swapping this new SYS3 137 into the mix doesn’t really help. Don’t get me wrong, I’ll find a use, but it won’t be on jobs. As I’ve said before with 4 MFT sys tops, I often end up only having this kind of work bench on smaller jobs, and whatever Systainers I packed, I’d easily find a work height that suited within that selection. In the future this won’t be possible for newcomers and people like me will end up with a growing amount of Systainers they have to be mindful of in that regard. . .
Like I said before, I’m just ranting as I have the spare time, and I keep thinking how silly this was. I’m interested in the perceived benefits of the new design decision more than tips on how I’ll manage. I know I’ll manage, this hasn’t instantly ruined my work flow, the show will go on.
Thanks for the Bott info @Cheese  I’m mildly interested in what this has all been for.
Who knows, one day I might have a van full of it and be looking to swap every thing to new sys3  [big grin] but I doubt it. .
« Reply #158 on: April 18, 2020, 05:08 PM »
(Attachment Link)
I’ve noticed also, and cannot see any real reason to change sizes, the shelves would be easy to adapt to existing systainers. Except if FT wasn’t happy with some of the sizes from what they tried to fit inside..
« Reply #159 on: April 19, 2020, 09:00 AM »
I agree with you...however I think it was Bott that drove the decision to change the Systainer height. Also, as Bott does 50,000 vehicle conversions per year, that was too lucrative a market for Festool to just walk away from.
A tweak to the Systainer tooling here & a tweak to the Systainer tooling there and suddenly Festool has opened up a brand new market for itself. And actually, Festool didn't even have to tweak the tooling, that was done by Tanos who was already producing Systainers for Bott.
So, all Festool had to do to gain entrance to a lucrative new market was to agree to switch over to the new Systainer style for packaging their tools. Kind of a no-brainer for Festool, considering the upside potential of the market.
Bott also describes the Vario 3 as a "new design" that is "redefining in-vehicle equipment".
Offline mackenzie
« Reply #160 on: April 19, 2020, 09:17 AM »
What I'd really like to know is what other manufacturers who use the systainer system will do.  Mafell and Fein for example use the T-Loc and Mafell has even adopted the Sys-Combi in one example I've seen.  Will these manufacturers convert to the new system?  Why did Metabo give up on the T-loc system, perhaps things were discussed behind closed doors relating to the new systainer3 that Metabo didn't like so they moved on?
I'm also interested to know what will happen with the obscure items that use the systainer profile such as the CT Sys or SYS PH.
« Reply #161 on: April 19, 2020, 07:26 PM »
Cheese, you’re probably right it’s a market opportunity. I didn’t know that Bott did so many conversions. And those buy in bulk, meaning for Tanos/Festool that they are most likely expanding. An added benefit is that a non Festool/Tanos user becomes aware of who equips their tools with Bott compatibility boxes - it’s a win-win. Not so much for existing Festool users.
Mackenzie, in my opinion there’s most likely new SYS PH and CT SYS in the works.
There will most likely also be new drawer slides compatible with SYS3/Bott. If cheaper and easier to mount, that could be a good thing. I don’t think all will change, as in IE the MW 1000. I think the “old” drawers will be available along with maybe new drawer slides and maybe frames with drawer slides for SYS3.
Imagine a compact small SYS port-alike with lighter system from Bott, where you can place it on top of a CT dust collector where you can pull systainers out simultaneously on both sides and have easy access to to maybe 3-4 systainers without stacking back and forth. Me want! ..SYS Ports are way too expensive, and too heavy. Plastic fantastic is fantastic! When weight is an important factor.
I have a “cart” from Keter all with drawers, it is all plastic, but it is good plastic - even the slides for the drawers, but I works remarkably well, even when I have more heavy stuff like fasteners and alike in it. And it is on wheels, so I shift it around as I please. I can split it in three parts, each with 3 drawers, put all or one in my car, it won’t scratch anything, and the drawers are lockable via central locking system so it lock all three drawers at once - just as a automotive tool cart in steel.
Offline Gregor
« Reply #162 on: April 21, 2020, 08:35 AM »
Given the format the VAC-SYS still sells here in Europe (classic systainer)... I do not share your enthusiasm.
Quote
It looks to me that Bott system does not support opening systainers without removing them fully from the stacking frame.
« Reply #163 on: April 21, 2020, 11:30 AM »
Quote
Oh well, that’s not enthusiasm - more a probable reality to what to come. Sure if systainers are now made to fit BOTT drawers, why should they exclude VAC SYS and SYS PH?
- Too bad if the systainers cannot open in-shelf.
Offline mackenzie
« Reply #164 on: April 21, 2020, 04:03 PM »
Phoned Bott today to ask for an ETA for the Bott branded Systainer3's and Vario3 racking and they said the release has been postponed until Q1 2021 due to Corona.
« Reply #165 on: April 21, 2020, 06:04 PM »
The Bott/Systainer3 system does not have drawer slides. It’s just a grid of pigeon holes for stuffing the boxes into for storage and transport.
If you want to open a Systainer on a pull-out shelf the drawer slide has to allow the back or the box to project at least 30mm beyond the front of the cabinet. With this system the back of the box will still be about 80mm short of the front of the cabinet when it starts to fall out.
« Reply #166 on: April 21, 2020, 08:14 PM »
Ah, so at a non moving shop like home shop or shop-shop, “ordinary” shelves are quite better..
Stupid of me thinking that there were to be made slides compatible with the new slots on SYS3.
« Reply #167 on: April 21, 2020, 09:55 PM »
The Bott cabinet has fixed rails that fit the slots molded into the sides of the Sys3. The benefit of the Bott cabinet compared to an ordinary shop cabinet is that there are no shelves. The Sys doesn’t sit on anything.
« Reply #168 on: April 21, 2020, 10:20 PM »
So the bottom line is this Bott thing works great in a van but not so much in a shop.  [mad]
Offline SRSemenza
« Reply #169 on: April 21, 2020, 11:32 PM »
Saves a little vertical space with no shelves. And a little more vertical or horizontal space due to the front handle. Since no space is needed to be able to get your hands on the Sys to pull it out.
I can see it saving about 6" vertical on a 48" tall Sys cabinet compared to having shelves and hand room.
Offline mino
« Reply #170 on: April 22, 2020, 12:58 PM »
This.
The SYS3 really needs to be looked at as a compatible-complement-but-not-a-replacement for classic/T-Loc "LEGO" lines.
We just need to make sure (hope ?) Festool realizes this.
« Reply #171 on: April 22, 2020, 01:16 PM »
Even more vertical space saving in a taller cabinet which is more viable with the front handles. Add a pullout shelf in the middle for a Sys3 to sit on when you pull it out and it’s almost as convenient as a costly full extension drawer.
Offline Spandex
« Reply #172 on: April 22, 2020, 01:46 PM »
The Bott racking was never meant for workshops. The integrated slider is an additional feature specifically for when the systainer is in a van rack, where opening the systainer in situ isn’t desirable - it doesn’t stop you using a sys-az at home or in the workshop, it just adds more flexibility for people who also rack their tools in a van.
It’s funny, because I remember threads on here where people complained that the sys-az wasn’t suitable for installation in a van, and now Tanos add a van-specific slider on the systainer and people are complaining that it isn’t suitable for workshop use.
« Reply #173 on: April 22, 2020, 05:11 PM »
Haha [big grin] - We’ll never be happy [wink]
We’re only happy till the next thing we’re eyeballing..
That said, as you folks knowing more about Bott’s system, it could be a workshop solution. That is when you would want to avoid T-Lock fiddling, stacking and unstacking.
You could possibly have easy reach and easier access to a systainer in a middle of a rack. Thus saving space in height, that is if these rails/sliders will be available to mount in a cabinet. You would have to decide the SYS height for each “shelf” though - ahh, maybe not very convenient - easier to mount ala LR 32 shelves or similar flexibility, as dado’ing cabinet sides for slide in shelves. I’ll speak for myself, but I hate fixed shelves, I always do them with adjustability. There’s always something you would like to put in a shelf, that of course would not fit if I had fixed shelves  [crying]
Offline mattbar1
« Reply #174 on: April 27, 2020, 08:00 AM »
 Are these available in the USA yet? And if so where?
Offline yetihunter
« Reply #175 on: May 09, 2020, 06:35 PM »
Only with some tools as stock gets replenished.  Most of the sanders now and then drills in July.
Americans interested in the Metabo “Metaloc” boxes will be pleased to know that they finally started showing up from Metabo’s US operations about a month or two ago.  No more need to import via Amazon.  The integrated side handle is nice (nicer than the new tanos/festool side handles) and you can lock and unlock the metal clasp in the middle of a stack.
For those new to Festool and reading this; when the t-loc was introduced, there was a bible sized thread either here or the now defunct other festool messageboard with people screaming bloody murder about how Festool replacing the original four latch systainer was the worst thing to ever happen to humanity or whatever.
Either Thursday or Friday, I passed mixed stacks of the old and new t-locs at the store and didn’t even notice the new ones were there until someone mentioned it.  Everyone’s concerned about the height, but most of that stuff is based on a Sys1 and they kept that the same size.
About the different parts bins, I can’t help you there.  After the dozens of different cobbled together clunky ways Festool/Tanos have offered customers to store screws and bolts, they finally smartened up and are delivering what every other modular plastic parts bin company has offered since the dawn of mankind (exaggerating somewhat).  I would believe it if you told me Bott motivated this.
Offline rst
« Reply #176 on: May 09, 2020, 07:10 PM »
I have two of the Metabo “Metaloc” boxes, my surface grinder and saw came in them and them work well with Festool and Tanos systainers.
Offline mino
« Reply #177 on: May 10, 2020, 03:06 AM »
Everyone is concerned about the height because the SystainerTM height system is one of the defining/killer features of the product.
With the new heights, you can NO LONGER (for all practical purposes, I know no one who is a SYS-1 only shop)
A) use a general stack of systainers as a mobile work surface
 => this makes the new line near useless for a lot of people
B) use *standard and universal* shelfs for efficient Systainer storage in the shop /lot of people use a SYS-5 or "SYS-6" or similar exact heights in shelfs/
 => this makes the any investment in them as a "superior" solution for shop-use /i.e. it gets a LOT harder to justify the expense/
For green field shop use B) is a nuisance, and can be compensated by wide-availability of the Bott rails (guess these can be cheaply 3D-printed)
For mobile use A) is a show (value) stopper which turns a $50 Systainer into a $10 Chinese tool case.
Combined, the value of the whole "one universal system" is lost.
The SYS3 is no longer a "system" in the same way the "Lego" ones are. It is half-broken in an intrinsic way.
The winners here are the Bott system users and a few who will appreciate the integrated sliders /a wash with point B) possibly/.
Everyone else loses. Including Festool in the long run.
For me, personally it is easy.
Having free shipping from the excellent folks at sys-classic.de for Tanos kit, I will just sell or give out any SYS3 that comes my way /except the XXL which is a beast/.
So, am I impacted - not really. Festool systainers have a "steal me" mark over here so I already use anthracite TANOS ones for tools and keep the Festool ones for home storage only.
Am I peeved - no.
But as a fan of what Festool, and TTS overall, does - I am disappointed as this will become a bad move for the company in case "Lego" line is not kept under the Festool brand moving forward or new "Lego" heights are not added to give the buyers a choice within the SYS3 ecosystem.
And if Festool is not successful, we will not have them do as much R&D on new tools so all are impacted.
Add:
I would not look for Metaloc further than the new management at Metabo which probably saw a cost-saving/profit opportunity once the original sys(tem con)tainer patents expired and they had a mostly free hand.
« Last Edit: May 10, 2020, 03:16 AM by mino »
Offline yetihunter
« Reply #178 on: May 10, 2020, 04:44 AM »
Metabo did not give up on the t-loc system.  They simply followed Makita and Hitachi’s lead and made their own personal and 100% compatible variant.  They’ve been on the market for 4 or 5 years now, I doubt that there was any sort of connection.
As far as what other companies will do, I guess the same as they did 9 years ago: slowly rollover to the new boxes when they get around to it.  Mafell took half a decade before switching over to t-locs from the classic systainer.
Offline Sourwould
« Reply #179 on: June 01, 2020, 04:54 PM »
Does anyone know if these cubed systainers are priced the same as the t-locs? I bought a sander and it came with one, but I'm going to sell it.
Offline adcolor
    • MIkey's Millworks and More
« Reply #180 on: June 27, 2020, 12:20 PM »
So, maybe somewhere between pages 1 & 6 this was mentioned. I didn't take the time to look (my apologies).
It looks to me like the new Vario3/1 (can't tell , maybe the new Vario3/2 as well) handle sticks out when it is locked to something below it (the T-loc handle pushes it out). If so, I am sure some enterprising 3d printer designer will come up with a notched handle to fix that.
I couldn't find any information on the slides (didn't say it wasn't there) for the Vario3.  My frustration in the shop for not making sliding drawers/shelves is that I have to kneel down, set the box on the floor, rummage through it, put it back on the shelf (if it's where I need to work) reverse those steps to grab what ever it is I forgot or now need, put the device away.  I wonder if there are telescoping slides for these.  Even in a van (maybe even more important) it would be nice. Not everything goes onto the job site with you.
For now, I suspect folks will either:
Give up on ever using vario3, sell them off.
Work with a blended operation. Maybe build spacers for site stacks (either for MFT/MW100 use, or just to level off the work space). Currently, I find the T-Loc style a real pain in the ass to get a flat stack anyhow (I could copy a chart off and stick it to the mft leg and the MW1000 I guess; even when not using them they are a pain).  When it is a work surface, I just live with the variability, and generally (other than a support for long material) avoid using them for general use as a work surface.  Because as soon as I do, I need into one of them anyhow (really thinking about concentrating on Sortainers for several reasons, though this is a good one).
When the variety of Vario3 models is available, and enough are already in your shop/van, sell/swap T-Loc Systainers and transition to the new ones.
The 'gotcha' may be the gen 1 Systainers. I'd love to replace what I have for my vac clamp. I have a really strong dislike for them. Hoping they replace them very soon, aside from a couple I keep extra machinery parts in on a shelf way up & in the back of my shop, I avoid using them.
Offline SonOfMI
« Reply #181 on: June 29, 2020, 02:00 PM »
The Systainer 3 are really the same as the TLOC so there’s not a huge difference. I got a systainer 3 when I got my ETS EC 125 recently. The handle on the front is nice for those that like to carry it like a Dewalt Tstak toolbox.
Offline _Ben_
« Reply #182 on: July 02, 2020, 05:33 PM »
I recently picked up a pdc 18/4 drill which came in the old style attic tloc obviously very handy for storing the drill bit sets. But l notice the very latest version of this drill comes in a systainer3 which seems to have dropped the attic.
Maybe they're working on an attic version, shame about that loss of utility in the interim.
Offline yetihunter
« Reply #183 on: July 08, 2020, 03:47 AM »
Seriously, I am a freak about having lid systainers loaded with bits.
Offline challer
« Reply #184 on: July 14, 2020, 09:07 AM »
My new drill/impact combination came in a SYS3 and I relied on the attic - a lot. There doesn't seem to be one. And the new heights screws up my Sys 1000s of which I have several.
Offline mrB
« Reply #185 on: July 14, 2020, 10:59 AM »
Realised the carrying straps that slot into the table holders don't work on the New SYSTAINER³.  I already thought it was a shame these label slots had gone from the sides of the SYSTAINER³, but now I realised new label slots don't take the clips well/easily, and with any real weight they pop out anyway.
Another downer for me with the new SYSTAINER³. I'm always moving a sys or two around with those quick fitting shoulder straps.
Offline xedos
« Reply #186 on: July 14, 2020, 02:10 PM »
Quote
Maybe not a huge, "ooooh look at what they've done now" difference.   But the cumulative effects of the small changes like the height difference, the handle staying proud when stacked, card slots going away and the strap omission along with the half baked no attic lid solution make this a loser for me.  Especially no attic lid.   Those are useful and expensive additions to the storage system.
For every one that thinks the "free" handle is the bee's knees, I'll bet there are two that think the lack of one of the other things I mentioned is a distinct drawback.   And for what ?    The ability to potentially sell some van racking systems to commercial customers ???
Good luck with that Festool.
Offline DeformedTree
« Reply #187 on: July 15, 2020, 10:41 PM »
Festool already has to manage different country specific packages.  They should have just kept with Systainer2 for their stuff, or did a systainer 2.5 if they wanted to add some features of the new design, but not mess with heights, side labels, etc.   Then offer a -V (van) option where those who want a van setup can get the tool with a systainer 3 instead.  The Bott stuff doesn't even exist in N.A. far as I know, so there is a big chunk of the market they don't have to do anything.
Just so many ways they could have handled this differently.  Of course now it's too late, even if they catch on to the mistake, it's unlikely they will go the other way and offer help to those who are stuck with some systainer 3s.
It's like taking away metric tools in N.A.   they could have added inch tools along side the metric stuff and let folks make the choice, instead they just took metric away. A completely un-needed self inflicted wound.
Offline mino
« Reply #188 on: July 16, 2020, 01:53 PM »
It is never "late" in business. Not until your are out of business.
What Festool needs to do now is keep both T-Loc and SYS-3 around as they fill different needs and neither can supersede the other functionally.
« Last Edit: August 12, 2020, 03:05 PM by mino »
Offline Coen
« Reply #189 on: August 08, 2020, 07:12 PM »
Well... the new messy Systainers make one thing easier; buying a new cordless drill. If I buy a Festool it's gonna be the oddball Sys3... if I buy a Makita I get a Sys Classic-clone, which fits in just fine. If I buy a Bosch, I get another L-boxx, that can stack with the L-boxx of my hammer drill. I could always justify the price premium of Festool because it always fitted into a system. But they now nixed the storage aspect of it..
Offline tobiaskurz
Re: SYSTAINER³ available from September – new ToolBox from January
« Reply #190 on: November 05, 2020, 05:01 PM »
Festool announced a new member of the SYSTAINER³ family: a toolbox. According to them it will be available from January in Europe.
The Systainer³ ToolBox comes in tow hights (137 & 237 mm) and is available in both M and L widths. The top handle is foldable for stacking. The M versions can be connected on top of a Classic Systainer. T-Loc Systainers And the newest generation SYSTAINER³ (including the new ToolBox) are pispele to lock under and on top of the ToolBox. The Box has a not divided space for storing what ever you like. They need a bar on the back wehr the feet of the T-Loc systainer step in. This frame has holes in it wich can holt tolls like a screw driver. Maybe for symmetric they have this bar tough to the front. As all SYSTAINER³ family members the ToolBox has a front handle. For carrying it makes no sense because everything would fall out. As on the higher systainers the only benefit is to pull it out a shelve.
https://www.festool.de/produkte/neuheiten/neuheiten/204865---sys3-tb-m-137
I Personal prefer the already available toolbox with the tow storage spaces and the classic latches. But I am although not happy with the hole SYSTAINER³ lineup. the only outstanding product is the XXL version. and this would have bean tough possible with the T-Loc.
« Last Edit: November 05, 2020, 05:07 PM by tobiaskurz »
Offline c_dwyer
« Reply #191 on: November 05, 2020, 06:33 PM »
Sort of wondering why there is a front handle under the T-loc for those.  Unless you have another systainer stacked on top, anytime you use that front handle, all your stuffs would fall out. [big grin]
Offline SRSemenza
« Reply #192 on: November 05, 2020, 11:33 PM »
It's for pulling it from a rack.
Offline phase3
« Reply #193 on: January 11, 2021, 09:43 PM »
Anyone know if racks for Systainer3 will ever be available for purchase not in a custom car, and if they'll ever be available to folks in USA?
I don't have a van, but I need to compactly store my tools in my little workshop. I'd prefer using the Bott style rack in my shop instead of drawers. For my use it seems better and allows for "grab & go" as needed to pull boxes to take to the worksite.
I just ordered a 5-pack of Tanos drawers for a few reasons, but going forward I'd prefer moving to the Systainer3 boxes and Vario3 racks.
Offline edwarmr
« Reply #194 on: January 11, 2021, 10:35 PM »
@phase3
Yes the new rails are currently available for custom shop cabinets. Here is a 4 pack set from ToolNut:
https://www.toolnut.com/festool/festool-systainers/festool-systainer/festool-204871-sys3-sn-4-systainer-rails.html
Online DynaGlide
« Reply #195 on: January 12, 2021, 08:15 AM »
Those are a heck of a lot more affordable than the SYS-AZ drawers. I'm already invested in Tloc and SYS-AZ. One of the features I love of SYS-AZ is that I can pull the systainer out, get out the tool or accessories, then close it and slide it back in without removing the systainer. From watching the video that doesn't appear to be the case with the new rails?
Instagram @matts.garage
Offline Shane Holland
  • Festool Dealer
« Reply #196 on: January 12, 2021, 08:22 AM »
Correct, you would need to remove the Systainer entirely to access the contents. The rails aren't long enough to engage and support the Systainer.
877-866-5688
Online DynaGlide
« Reply #197 on: January 12, 2021, 08:26 AM »
Thanks Shane. It's good to have choices. Hopefully Tloc and SYS-AZ don't go anywhere. The OCD part of me would not like mixing systems.
Offline Coen
« Reply #198 on: January 12, 2021, 09:53 AM »
Even Classic Systainer can still be bought. Maybe easier in the EU than in the USA, but still.
« Reply #199 on: January 12, 2021, 10:16 AM »
Certainly not a fan of those rails...they come up short in my opinion.
I did however find a handy matrix depicting Systainer³ heights, sizes & availability.
Offline mkasdin
« Reply #200 on: January 12, 2021, 11:54 AM »
2021 is turning out to be the start of Systainer-gate. I think the systainers should work out fine? Festool felt that the racking was more important and I was never a huge fan of a shelf slider system to store the systainers.
Offline Coen
« Reply #201 on: January 12, 2021, 02:09 PM »
They could have added the that racking feature without messing with the heights.
Offline phase3
« Reply #202 on: January 12, 2021, 09:45 PM »
@phase3
Thanks for that link! I see they're not shipping until Feb 1, but that's soon enough for me, since I don't yet have any Systainer3 but plan to order some of those too asap, especially for random non-Festools, replacing their annoying "FREE zippered bag".
« Last Edit: January 12, 2021, 09:59 PM by phase3 »
